[javascript] search knop?
  • Rene59
  • Laatst online: 01-09 23:33
Hoe kan ik het zoek venster openen van de browser?
window.search() oid werkt allemaal niet.
Is het überhaupt mogelijk?
tnx :)
  • ACM
ACM
Software Architect
Werkt hier
Tsja: [topic=185180/1/50]
moved dus
  • Rene59
sorry!
  • BtM909
BtM909
Watch out Guys...
Ik ken wel een custom search die zoekt in je huidige pagina:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
<script language="JavaScript">
Find In Page Script-
By Mike Hall (MHall75819@aol.com)
Permission granted to Dynamicdrive.com to feature script in archive
For full source code, visit http://dynamicdrive.com
var NS4 = (document.layers);    // Which browser?
var IE4 = (document.all);
var win = window;    // window to search.
var n   = 0;
function findInPage(str) {
  var txt, i, found;
  if (str == "")
    return false;
  // Find next occurance of the given string on the page, wrap around to the
  // start of the page if necessary.
  if (NS4) {
    // Look for match starting at the current point. If not found, rewind
    // back to the first match.
    if (!win.find(str))
    while(win.find(str, false, true))
      n++;
    else
    n++;
    // If not found in either direction, give message.
    if (n == 0)
    alert("Not found.");
  if (IE4) {
    txt = win.document.body.createTextRange();
    // Find the nth match from the top of the page.
    for (i = 0; i <= n && (found = txt.findText(str)) != false; i++) {
    txt.moveStart("character", 1);
    txt.moveEnd("textedit");
    // If found, mark it and scroll it into view.
    if (found) {
    txt.moveStart("character", -1);
    txt.findText(str);
    txt.select();
    txt.scrollIntoView();
    n++;
    // Otherwise, start over at the top of the page and find first match.
    else {
    if (n > 0) {
      n = 0;
      findInPage(str);
    // Not found anywhere, give message.
    else
  return false;
</script>
<form name="search" onSubmit="return findInPage(this.string.value);">
<font size=3><input name="string" type="text" size=15 onChange="n = 0;"></font>
<input type="submit" value="Find">
</form>
Werkt supercool
  • RM-rf
  • Laatst online: 14:59
RM-rf
1 2 3 4 5 7 6 8 9
voor msie kun je misschien ook NavigateAndFind gebruiken, onderdeel van het window en external object:
http://msdn.microsoft.com/library/default.asp?url=/workshop/author/dhtml/reference/methods/NavigateAndFind.asp
en dan aanroepen via een prompt
Intelligente mensen zoeken in tijden van crisis naar oplossingen, Idioten zoeken dan schuldigen
  • BtM909
BtM909
Watch out Guys...
Werkt alleen niet zoals gevraagd door de poster (In IE CTRL+F -> search), da's jammer...
"Mijn" scrippe is trouwens cross-browser vanaf versie 4!
  • Bosmonster
  • Laatst online: 29-08 19:47
Bosmonster
*zucht*
Uhh.. document.all en document.layers... Da ga niet werken in NS6 hoor....
  • BtM909
BtM909
Watch out Guys...
hmm, moet ik ze bij dynamicdrive.com maar ff mailen. Zij zetten erbij dat hij "ALL BROWSERS" compatible is :9
Wat gebruik je dan voor NS6 ??
  • RM-rf
RM-rf
1 2 3 4 5 7 6 8 9
Op dinsdag 18 september 2001 17:05 schreef BtM909 het volgende:
document.getElementById()
(ook voor msie5+ (te prefereren boven document.all)
Kan ik dan gewoon
veranderen in:
var NS4 = (document.getElementById); // Which browser?
Want ik kom er niet echt uit ben ik bang. In IE werkt het perfect, in Netscape 6 niet :'(
  • RM-rf
RM-rf
1 2 3 4 5 7 6 8 9
Op woensdag 19 december 2001 16:21 schreef whistler het volgende:
Kan ik dan gewoon
veranderen in:
heb je daar nu drie maanden op zitten frutten, had je best eerder mogen vragen, hoor ;)
document.getElementById returned true voor netscape6/mozilla en msie5+
het is bij gebruik redelijk te vergelijken met document.all[] voor msie en vaak uitwisselbaar (maar niet altijd)
<javascriptdodomode>
Het was niet 3 maanden, ik ben een andere user :) Maar het kan dus niet op de manier zoals ik gister zei? Dat heb ik nl. geprobeerd en dat werkte dus niet :)
Of moet er in de function voor de var NS4 ook wat veranderd worden om hem geschikt te maken voor Netscape 6?
</javascriptdodomode> :+
  • crisp
  • Laatst online: 21:24
crisp
Devver
Pixelated
Maak er gewoon een var DOM bij:
var DOM = (document.getElementById);
var IE4 = (document.all && !DOM);
Intentionally left blank
Helaas, dat werkt niet, en in IE werkt het dan ook niet meer :'(
En het vervelende is dat ik geen idee heb van wat het doet...je maakt een nieuwe variable genaamd DOM (haha) en die roep je weer aan bij de IE4 functie??
