No trees were killed in the sending of this message. However a large number of electrons were terribly inconvenienced.
Gebruik je altijd 2 cijfers achter de komma?
29
30
31
32
33
34
35
36
| <HTML>
<HEAD>
<TITLE>Number Formatting</TITLE>
<SCRIPT LANGUAGE="JavaScript">
// generic positive number decimal formatting function
function format (expr, decplaces) {
// raise incoming value by power of 10 times the
// number of decimal places; round to an integer; convert to string
var str = "" + Math.round (eval(expr) * Math.pow(10,decplaces))
// pad small value strings with zeros to the left of rounded number
while (str.length <= decplaces) {
str = "0" + str
// establish location of decimal point
var decpoint = str.length - decplaces
// assemble final result from: (a) the string up to the position of
// the decimal point; (b) the decimal point; and (c) the balance
// of the string. Return finished product.
return str.substring(0,decpoint) + "." + str.substring(decpoint,str.length);
// turn incoming expression into a dollar value
function dollarize (expr) {
return "$" + format(expr,2)
</SCRIPT>
</HEAD>
<BODY>
<H1>How to Make Money</H1>
<FORM>
Enter a positive floating point value or arithmetic expression to be converted to a currency format:<P>
<INPUT TYPE="text" NAME="entry" VALUE="1/3">
<INPUT TYPE="button" VALUE=">Dollars and Cents>" onClick="this.form.result.value=dollarize(this.form.entry.value)">
<INPUT TYPE="text" NAME="result">
</FORM>
</BODY>
</HTML> |
Eerlijk gejat, je moet alleen even die dollarize function eruit slopen. (ik had geen zin om zelf script te bouwen).
(Tenminste dat is de bedoeling
De echte functie is maar 6 regels........hele prestatie dat jij het dan in 7 regels doetOp dinsdag 18 september 2001 13:07 schreef BtM909 het volgende:
Bovenstaand script had ik ook, maar ik moest het iets anders gebruiken, dus heb ik het herschreven in 7 regels
Touché, maar ik heb andere functionaliteit erin gebakken!Op dinsdag 18 september 2001 13:10 schreef McVirusS het volgende:
De echte functie is maar 6 regels........hele prestatie dat jij het dan in 7 regels doet.
