Hoi,
Is in het engels, anders moest ik het helemaal weer vertalen. Lukt zo ook wel denk ik.
I have been trying to install windows 2000 om my new computer. I'll first give the specs.
chaintech 5agm2 mobo
K6-2 500Mhz
128 pc-100 dimm
s3 savage4 16 mb pci video card
WD 4.2 hd 5400 udma-2
The problem is that after installing windows 2000 the first time w2k starts and finishes setup it hangs and gives an error
Error:
*** STOP: 0x0000001E (0xc000001D,0x80434B0E,0x00000000,0x00000000) KMODE_EXEPTION_NOT_HANDLED
***Address 80434B0E base at 80400000, Date STamp 348d9b17 - ntoskrnl.exe
Bussy starting phisic memorydump
physic memorydump complete. Contact your systemmanager or technical support.
Ok that's one of the errors I get.
What I thouhgt could be the ploblem was my memory. I put some other memory in also 128mb pc100 out of my other computer that works ok but no change. Also I have tried normal fat32 format an NTFS format. Both the same problem. Also tried all three memory slots, no change.
don't know what to do now. Maybe my memory slots are not good any more or is it something else? Any one have an Idea?
Thnx,
Sjaak
K6-2 500Mhz
128 pc-100 dimm
Error:
Thnx,
Sjaak
