Mplayers trubbels
Hi,
eindelijk heb ik Mplayer kunnen installeren (gcc probs enzo) maar nu wil ik dus een DivX afspelen. Ik heb de codecs van mplayer.sourceforge.net gedownload en in de map /usr/lib/win32 gezet.
Nu wil ik dus starten krijg ik het volgende :
29
30
31
32
33
34
35
36
37
[root@redhat /root]# mplayer -ao pcm -vo odivx /usr/share/wine-c/Friends\ Serie\
 6\ Episode\ 22_TOW\ Pauls\'\ The\ Man.avi
MPlayer CVS-010916-06:00(C) 2000-2001 Arpad Gereoffy (see DOCS/AUTHORS)
Reading /root/.mplayer/codecs.conf: 17 audio & 37 video codecs
font: can't open file: /root/.mplayer/font/font.desc
font: can't open file: /usr/local/share/mplayer/font/font.desc
Playing /usr/share/wine-c/Friends Serie 6 Episode 22_TOW Pauls' The Man.avi
Detected AVI file format!
MainAVIHeader.dwFlags: (272) HAS_INDEX IS_INTERLEAVED
VIDEO:  [DIV3]  336x256  24bpp  25.00 fps  406.7 kbps (49.6 kbyte/s)
[V] filefmt:3  fourcc:0x33564944  size:336x256  fps:25.00  ftime:=0.0400
Detected audio codec: [mp3] drv:1 (MPEG layer-2, layer-3)
mp3lib: Processor ID: 621
mp3lib: Using AMD 3dnow-dsp(k7)! optimized decore.
AUDIO: srate=44100  chans=2  bps=2  sfmt=0x10  ratio: 6000->176400
Detected video codec: [divx] drv:2 (DivX ;-) (MS MPEG-4 v3))
Loading DLL: /usr/lib/win32/divxc32.dll  OK
VO: [odivx] 336x256 => 336x256 Packed YUY2
AO: [pcm] 44100Hz Stereo Signed 16-bit (Little-Endian)
PCM: File: audiodump.wav (WAVE) Samplerate: 44100Hz Channels: Stereo Format Sign
PCM: Info - fastest dumping is achieved with -vo null -hardframedrop.
PCM: Info - to write WAVE files use -waveheader (default), for RAW PCM -nowavehe
ader.
Start playing...
coded length: 954  -V: -0.111 ct: -0.023    9/  9   0%  0%  0.0% 0 0
coded length: 51  A-V: -0.128 ct: -0.027   10/ 10   0%  0%  0.0% 0 0
coded length: 51  A-V: -0.145 ct: -0.031   11/ 11   0%  0%  0.0% 0 0
coded length: 51  A-V: -0.161 ct: -0.035   12/ 12   0%  0%  0.0% 0 0
coded length: 51  A-V: -0.178 ct: -0.039   13/ 13   2%  3%  0.5% 0 0
coded length: 51  A-V: -0.195 ct: -0.043   14/ 14   2%  3%  0.5% 0 0
A:   0.3 V:   0.6 A-V: -0.212 ct: -0.047   15/ 15   2%  3%  0.6% 0 0
MPlayer interrupted by signal 2 in module: sleep
En dit gaat dus even door ..... geluid heb ik ook niet. Iemand ervaring met dit probleem?
  • imdos
  • Laatst online: 09:50
imdos
I use FreeNAS and Ubuntu
Ik zou ook nog even die mp_font.zip installeren in de juiste directory! En start eens mplayer op zonder die -ao en -vo en kijk wat er dan gebeurt ...
Dan kiest mplayer nl. zelf de goede waardes wel
pvoutput. Waarom makkelijk doen, als het ook moeilijk kan! Every solution has a new problem
  • odysseus
  • Laatst online: 09-09 21:59
odysseus
Debian GNU/Linux Sid
Op zondag 16 september 2001 15:59 schreef imdos het volgende:
Nope, ik weet uit eigen ervaring dat mplayer dan default-waarden neemt.
Leven is het meervoud van lef | In order to make an apple pie from scratch, you must first create the universe.
  • ajvdvegt
  • Laatst online: 15-08 12:40
Als je netjes een .deb-je hebt gemaakt, kan je zelf de default waarden kiezen.
En als je divx als output kiest (met '-vo odivx'), dan MAAKT-ie dus divx-jes voor je. Het lijkt er op dat jij DivX-jes wilt AFSPELEN. Welk formaat het bestand is dat je afspeelt, hoef je niet op te geven, dat zoekt-ie zelf uit.
Als je libsdl-dev geinstalleerd hebt, dan compileert-ie sdl support voor je mee, en dat is erg aan te raden. Je kan dan namelijk makkelijk wisselen tussen fullscreen en een windowed-versie.
Die fouten in het begin over je lettertypen zijn niet zo erg, je hebt dan alleen geen On Screen Display voor bv. volume.
I don't kill flies, but I like to mess with their minds. I hold them above globes. They freak out and yell "Whooa, I'm *way* too high." -- Bruce Baum
