Let's Encrypt ACME faalt ondanks _acme-challenge
  • MisterE
  • Laatst online: 23-09 21:56
Ik ben gisteren overgestapt op MIJN.HOST aangezien deze support heeft voor LEGO DNS-01.
Ik ben nu een validatie aan het doen op de STAGING omgeving.
We voeren het volgende commando uit:
MIJNHOST_PROPAGATION_TIMEOUT=180 MIJNHOST_API_KEY=DIE_IS_GEHEIM lego \
>   --email="ikke@mijndomein.com" \
>   --domains="dryrun.mijndomein.com" \
>   --domains="*.dryrun.mijndomein.com" \
>   --dns="mijnhost" \
>   --dns.resolvers="ns1.mijn.host:53,ns2.mijn.host:53,ns3.mijn.host:53" \
>   --server="https://acme-staging-v02.api.letsencrypt.org/directory" \
>   --path="/tmp/lego" \
>   --accept-tos \
>   run
Dit eindigt in een error
29
30
31
32
33
2025/03/23 10:30:21 [INFO] [dryrun.mijndomein.com, *.dryrun.mijndomein.com] acme: Obtaining bundled SAN certificate
2025/03/23 10:30:22 [INFO] [*.dryrun.mijndomein.com] AuthURL: https://acme-staging-v02.api.letsencrypt.org/acme/authz/191041814/16513283914
2025/03/23 10:30:22 [INFO] [dryrun.mijndomein.com] AuthURL: https://acme-staging-v02.api.letsencrypt.org/acme/authz/191041814/16513283924
2025/03/23 10:30:22 [INFO] [*.dryrun.mijndomein.com] acme: use dns-01 solver
2025/03/23 10:30:22 [INFO] [dryrun.mijndomein.com] acme: Could not find solver for: tls-alpn-01
2025/03/23 10:30:22 [INFO] [dryrun.mijndomein.com] acme: Could not find solver for: http-01
2025/03/23 10:30:22 [INFO] [dryrun.mijndomein.com] acme: use dns-01 solver
2025/03/23 10:30:22 [INFO] [*.dryrun.mijndomein.com] acme: Preparing to solve DNS-01
2025/03/23 10:30:23 [INFO] [*.dryrun.mijndomein.com] acme: Trying to solve DNS-01
2025/03/23 10:30:23 [INFO] [*.dryrun.mijndomein.com] acme: Checking DNS record propagation. [nameservers=ns1.mijn.host:53,ns2.mijn.host:53,ns3.mijn.host:53]
2025/03/23 10:30:25 [INFO] Wait for propagation [timeout: 3m0s, interval: 2s]
2025/03/23 10:30:26 [INFO] [*.dryrun.mijndomein.com] acme: Waiting for DNS record propagation.
2025/03/23 10:33:25 [INFO] [*.dryrun.mijndomein.com] acme: Waiting for DNS record propagation.
2025/03/23 10:33:27 [INFO] [*.dryrun.mijndomein.com] acme: Cleaning DNS-01 challenge
2025/03/23 10:33:29 [INFO] [dryrun.mijndomein.com] acme: Preparing to solve DNS-01
2025/03/23 10:33:29 [INFO] [dryrun.mijndomein.com] acme: Trying to solve DNS-01
2025/03/23 10:33:29 [INFO] [dryrun.mijndomein.com] acme: Checking DNS record propagation. [nameservers=ns1.mijn.host:53,ns2.mijn.host:53,ns3.mijn.host:53]
2025/03/23 10:33:31 [INFO] Wait for propagation [timeout: 3m0s, interval: 2s]
2025/03/23 10:33:31 [INFO] [dryrun.mijndomein.com] acme: Waiting for DNS record propagation.
2025/03/23 10:33:33 [INFO] [dryrun.mijndomein.com] acme: Waiting for DNS record propagation.
2025/03/23 10:36:31 [INFO] [dryrun.mijndomein.com] acme: Waiting for DNS record propagation.
2025/03/23 10:36:33 [INFO] [dryrun.mijndomein.com] acme: Cleaning DNS-01 challenge
2025/03/23 10:36:35 [INFO] Deactivating auth: https://acme-staging-v02.api.letsencrypt.org/acme/authz/191041814/16513283914
2025/03/23 10:36:35 [INFO] Deactivating auth: https://acme-staging-v02.api.letsencrypt.org/acme/authz/191041814/16513283924
2025/03/23 10:36:35 Could not obtain certificates:
    error: one or more domains had a problem:
[*.dryrun.mijndomein.com] propagation: time limit exceeded: last error: authoritative nameservers: NS ns2.mijn.host.:53 returned REFUSED for _acme-challenge.dryrun.mijndomein.com.
[dryrun.mijndomein.com] propagation: time limit exceeded: last error: authoritative nameservers: NS ns3.mijn.host.:53 returned REFUSED for _acme-challenge.dryrun.mijndomein.com.
Het gekke is dat ik eigenlijk de challenge lijk te zien. Maar toch faalt het?
host -t TXT _acme-challenge.dryrun.mijndomein.com ns1.mijn.host ; host -t TXT _acme-challenge.dryrun.mijndomein.com ns2.mijn.host ; host -t TXT _acme-challenge.dryrun.mijndomein.com ns3.mijn.host
Using domain server:
Address: 5.254.117.200#53
Aliases:
_acme-challenge.dryrun.mijndomein.com descriptive text "0km2QGgsfc0LwyayoWoEKb8v2bRg2waRd_WxYXLcnnI"
Address: 45.140.188.195#53
Aliases:
Address: 83.96.241.95#53
Aliases:
Getest met en zonder de "dns.resolvers". Lijken me overbodig toch? Hoewel de output dan wel iets anders is
2025/03/23 09:51:52 [INFO] [*.dryrun.mijndomein.com] acme: Checking DNS record propagation. [nameservers=192.168.1.1:53]
vs
  • dbzokphp
  • Laatst online: 12-10 14:22
Dat is wel gek inderdaad. Het enige wat ik kan bedenken is dat er ergens iets niet goed gaat omdat je een wildcard op een subdomein probeert aan te vragen, hoewel het normaal wel zou moeten kunnen.
Je zou dit wellicht eens kunnen testen met het root domein.
Anders misschien de MIJNHOST_PROPAGATION_TIMEOUT nog hoger zetten, hoewel dat eigenlijk ook niet zou hoeven.
  • MisterE
ik had gisteravond ook al een "test" subdomein gemaakt (wist niet zeker of nodig) en soortgelijke test gedaan maar lijkt hetzelfde te eindigen
[ Voor 10% gewijzigd door MisterE op 23-03-2025 12:26 ]
  • MisterE
Eens een test gedaan met alleen het hoofddomein met langere tijd, dus:
  --domains="domein.com"
  MIJNHOST_PROPAGATION_TIMEOUT=600
Als ik inlog op het DNS control panel van MIJN.HOST dan zie ook de entry:
  _acme-challenge.domein.com. 120 TXT    "_DPaMk4uuOXCh_qVJpixFy2EEoji_QM0O_1WtUYO46k"
Ook dit faalt. Nou is het wel zo dat ik alleen e-mail hosting gekozen heb bij MIJN.HOST. Zij moeten dus op het hoofddomein het cert regelen voor de webmail.
Maar met wat WHOIS sites zie ik ook echt de nameservers van hun.
[ Voor 3% gewijzigd door MisterE op 23-03-2025 13:23 ]
  • MisterE
Ik probeer nu met:
--dns.propagation-disable-ans="true" \
Ik heb het idee dat de 2 hosters vechten om wie de authoritative is?
2025/03/23 13:15:17 Could not obtain certificates:
[dryrun.mijndomein.com] invalid authorization: acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: During secondary validation: Incorrect TXT record "oqBA7axJAlvc04bQ6QBTRoUaqU5HTznW5HIdnvxG_Hw" found at _acme-challenge.dryrun.mijndomein.com
[ Voor 3% gewijzigd door MisterE op 23-03-2025 13:24 ]
  • MisterE
Ow bijzonder. Ging net een keer goed, toen gaf ik de opties mee:
Was wat aan het experimenteren zonder deze opties. Maar als ik nu weer hetzelfde commando uitvoer dan gaat het weer fout. Dus dat voelt alsof we geluk moeten hebben om op de juiste server(s) te komen.
invalid authorization: acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: Incorrect TXT record
  • MisterE
Ok, gevonden.
Ging een lampje branden toen dit geen resultaat gaf maar ik hem WEL bij de provider in de webgui zag.
dig TXT _acme-challenge.dryrun.mijndomein.com @ns1.mijn.host
Ik forceer namelijk poort 53 naar mijn opnsense DNS.
En dus komt request "ns1.mijn.host" vrolijk uit op Unbound.
Ik zou toch ook verwachten dat Unbound de setting ook moet overnemen? Maar wellicht is dat een timing issue. En dus de verklaring waarom het 1x goed ging.
Terug naar de tekentafel voor deze DNS hack
  • liv
  • Registratie: Augustus 2018
  • Laatst online: 14-08 10:18
liv
If it works, I'll break it
Hoe heb je dit probleem opgelost? Ik heb nu hetzelfde, draai ook OPNsense met Unbound en DNS over TLS etc. Dat wil ik natuurlijk wel graag houden :)
Als ik na enige tijd niet reageer, stuur dan even een extra berichtje. Ik mis nog wel eens wat...
  • MisterE
Uiteindelijk heb ik met de parameters zitten spelen tot LEGO het stabiel leek te doen.
Deze settings verwerkt in Traefik.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
services:
  traefik:
    image: traefik:3.3.4
    pull_policy: missing
    container_name: traefik
    hostname: traefik
    restart: always
    ports:
      - 80:80 # proxy
      - 443:443 # proxy
      - 8080:8080 # dashboard
    networks:
      - traefik-net
    volumes:
      - /mnt/tank/container_data/traefik:/var/traefik/certs
      - /var/run/docker.sock:/var/run/docker.sock:ro
      - /etc/timezone:/etc/timezone:ro
      - /etc/localtime:/etc/localtime:ro
    environment:
      - TZ=Europe/Amsterdam
      - MIJNHOST_API_KEY=MIJN_API_KEY
      - MIJNHOST_TTL=15
      - MIJNHOST_PROPAGATION_TIMEOUT=300
      - MIJNHOST_POLLING_INTERVAL=10
    labels:
      - wud.watch=true
      - wud.registry.lookup.url=https://registry-1.docker.io
      - wud.tag.include=^([0-9]\d*)\.([0-9]\d*)\.([0-9]\d*)$$
      - traefik.enable=true
      - traefik.http.routers.traefik-web.entrypoints=web
      - traefik.http.routers.traefik-web.rule=Host(`traefik.home.mijndomein.com`)
    command:
      - --log.level=DEBUG
      - --serverstransport.insecureskipverify=true
      - --providers.docker=true
      - --providers.docker.watch=true
      - --providers.docker.exposedbydefault=false
      - --api.dashboard=true
      - --api.insecure=true
      - --global.checknewversion=false
      - --global.sendanonymoususage=false
      - --entrypoints.web.address=:80
      - --entrypoints.websecure.address=:443
      - --entrypoints.websecure.http.tls=true
      - --entrypoints.websecure.http.tls.certresolver=letsencryptresolver
      - --entrypoints.websecure.http.tls.domains[0].main=home.mijndomein.com
      - --entrypoints.websecure.http.tls.domains[0].sans=*.home.mijndomein.com
      - --entrypoints.websecure.transport.respondingTimeouts.readTimeout=600
      - --certificatesresolvers.letsencryptresolver.acme.dnschallenge=true
      - --certificatesresolvers.letsencryptresolver.acme.dnschallenge.provider=mijnhost
      - --certificatesresolvers.letsencryptresolver.acme.dnschallenge.resolvers=ns1.mijn.host:53,ns2.mijn.host:53,ns3.mijn.host:53
      - --certificatesresolvers.letsencryptresolver.acme.caserver=https://acme-v02.api.letsencrypt.org/directory
      - --certificatesresolvers.letsencryptresolver.acme.email=admin@mijndomein.com
      - --certificatesresolvers.letsencryptresolver.acme.storage=/var/traefik/certs/mijnhost-acme.json
      - --certificatesresolvers.letsencryptresolver.acme.keytype=EC256
networks:
  traefik-net:
  • MisterE
liv schreef op donderdag 16 oktober 2025 @ 11:48:
* Ik had ooit het idee om normale DNS (53) verzoeken te herschrijven
* DoT blokkeren
Maar DoH is zo goed als onmogelijk zonder blacklists. Ik heb het simpelweg nooit meer aangezet
