Ik gebruik phpadmin 2.2 (in PHP3)
heb het ook nog geprobeert met 2.3..
Als iemand kan zeggen waar ik een recente kan downloaden let me know~! of plant hier even de juiste config.php3, dat ik het zelf even kan langs lopen
KE hier is dan mijn config meschien dat iemand ziet wat ik foet doe
<?php
/* $Id: config.inc.php3,v 1.33 2001/08/28 17:50:53 loic1 Exp $ */
* phpMyAdmin Configuration File
* All directives are explained in Documentation.html
* Bookmark Table Structure
* CREATE TABLE bookmark (
* id int(11) DEFAULT '0' NOT NULL auto_increment,
* dbase varchar(255) NOT NULL,
* user varchar(255) NOT NULL,
* label varchar(255) NOT NULL,
* query text NOT NULL,
* PRIMARY KEY (id)
* Your phpMyAdmin url
* Complete the variable below with the full url ie
http://www.your_web.net/path_to_your_phpMyAdmin_directory/
$cfgPmaAbsoluteUri = 'http://queen/phpMyAdmin-2.2.0/';
* Server(s) configuration
// The $cfgServers array starts with $cfgServers[1]. Do not use $cfgServers[0].
// You can disable a server config entry by setting host to ''.
$cfgServers[1]['host'] = 'localhost'; // MySQL hostname
$cfgServers[1]['port'] = ''; // MySQL port - leave blank for default port
$cfgServers[1]['socket'] = ''; // Path to the socket - leave blank for default socket
$cfgServers[1]['connect_type'] = 'tcp'; // How to connect to MySQL server ('tcp' or 'socket')
$cfgServers[1]['adv_auth'] = FALSE; // Use advanced authentication?
$cfgServers[1]['stduser'] = ''; // MySQL standard user (only needed with advanced auth)
$cfgServers[1]['stdpass'] = ''; // MySQL standard password (only needed with advanced auth)
$cfgServers[1]['user'] = 'administrator'; // MySQL user (only needed with basic auth)
$cfgServers[1]['password'] = '*****'; // MySQL password (only needed with basic auth)
$cfgServers[1]['only_db'] = ''; // If set to a db-name, only this db is accessible
// It may also be an array of db-names
$cfgServers[1]['verbose'] = ''; // Verbose name for this host - leave blank to show the hostname
$cfgServers[1]['bookmarkdb'] = ''; // Bookmark db - leave blank for no bookmark support
$cfgServers[1]['bookmarktable'] = ''; // Bookmark table - leave blank for no bookmark support
$cfgServers[2]['host'] = '';
$cfgServers[2]['port'] = '';
$cfgServers[2]['socket'] = '';
$cfgServers[2]['connect_type'] = 'tcp';
$cfgServers[2]['adv_auth'] = FALSE;
$cfgServers[2]['stduser'] = '';
$cfgServers[2]['stdpass'] = '';
$cfgServers[2]['user'] = 'administrator';
$cfgServers[2]['password'] = '*****';
$cfgServers[2]['only_db'] = '';
$cfgServers[2]['verbose'] = '';
$cfgServers[2]['bookmarkdb'] = '';
$cfgServers[2]['bookmarktable'] = '';
$cfgServers[3]['host'] = '';
$cfgServers[3]['port'] = '';
$cfgServers[3]['socket'] = '';
$cfgServers[3]['connect_type'] = 'tcp';
$cfgServers[3]['adv_auth'] = FALSE;
$cfgServers[3]['stduser'] = '';
$cfgServers[3]['stdpass'] = '';
$cfgServers[3]['user'] = 'administrator';
$cfgServers[3]['password'] = '*****';
$cfgServers[3]['only_db'] = '';
$cfgServers[3]['verbose'] = '';
$cfgServers[3]['bookmarkdb'] = '';
$cfgServers[3]['bookmarktable'] = '';
// If you have more than one server configured, you can set $cfgServerDefault
// to any one of them to autoconnect to that server when phpMyAdmin is started,
// or set it to 0 to be given a list of servers without logging in
// If you have only one server configured, $cfgServerDefault *MUST* be
// set to that server.
$cfgServerDefault = 1; // Default server (0 = no default server)
$cfgServer = '';
unset($cfgServers[0]);
* Other core phpMyAdmin settings
$cfgConfirm = TRUE; // confirm 'DROP TABLE' & 'DROP DATABASE'
$cfgPersistentConnections = FALSE; // use persistent connections to MySQL database
$cfgShowBlob = FALSE; // display blob field contents in browse mode
$cfgProtectBlob = TRUE; // disallow editing of blob fields in edit mode
$cfgAllowUserDropDatabase = FALSE; // disallow users to delete their own database
$cfgShowSQL = TRUE; // show SQL queries as run
$cfgSkipLockedTables = FALSE; // mark used tables, make possible to show
// locked tables (since MySQL 3.23.30)
$cfgMaxRows = 30; // maximum number of rows to display in browse mode
$cfgOrder = 'ASC'; // default for 'ORDER BY' clause (valid
// values are 'ASC', 'DESC' or 'SMART' -ie
// descending order for fields of type
// TIME, DATE, DATETIME & TIMESTAMP,
// ascending order else-)
$cfgOBGzip = TRUE; // GZIP output buffering
$cfgGZipDump = TRUE; // Allow the use of gzip/bzip compression
$cfgBZipDump = TRUE; // for dump files
* Link to the official MySQL documentation
* Be sure to include no trailing slash on the path
$cfgManualBase = 'http://www.mysql.com/documentation/mysql/bychapter';
* Language settings
// Default language to use, if not browser-defined or user-defined
$cfgDefaultLang = 'en';
// Force: always use this language - must be defined in select_lang.inc.php3
// $cfgLang = 'en';
// Loads language file
require('./select_lang.inc.php3');
* Customization & design
$cfgBorder = 0; // border width on tables
$cfgThBgcolor = '#D3DCE3'; // table header row colour
$cfgBgcolorOne = '#CCCCCC'; // table data row colour
$cfgBgcolorTwo = '#DDDDDD'; // table data row colour, alternate
$cfgTextareaCols = 40; // textarea size (columns) in edit mode
$cfgTextareaRows = 7; // textarea size (rows) in edit mode
$cfgLimitChars = 50; // max field data length in browse mode
$cfgModifyDeleteAtLeft = TRUE; // show edit/delete links on left side of browse
$cfgModifyDeleteAtRight = FALSE; // show edit/delete links on right side of browse
$cfgLeftWidth = 150; // left frame width
* MySQL settings
// Column types
$cfgColumnTypes = array(
'TINYINT',
'SMALLINT',
'MEDIUMINT',
'INT',
'BIGINT',
'FLOAT',
'DOUBLE',
'DECIMAL',
'DATE',
'DATETIME',
'TIMESTAMP',
'TIME',
'YEAR',
'CHAR',
'VARCHAR',
'TINYBLOB',
'TINYTEXT',
'TEXT',
'BLOB',
'MEDIUMBLOB',
'MEDIUMTEXT',
'LONGBLOB',
'LONGTEXT',
'ENUM',
'SET'
// Atributes
$cfgAttributeTypes = array(
'BINARY',
'UNSIGNED',
'UNSIGNED ZEROFILL'
// Available functions
$cfgFunctions = array(
'ASCII',
'CHAR',
'SOUNDEX',
'ENCRYPT',
'LCASE',
'UCASE',
'NOW',
'PASSWORD',
'ENCODE',
'DECODE',
'MD5',
'RAND',
'LAST_INSERT_ID',
'COUNT',
'AVG',
'SUM',
'CURDATE',
'CURTIME',
'FROM_DAYS',
'FROM_UNIXTIME',
'PERIOD_ADD',
'PERIOD_DIFF',
'TO_DAYS',
'UNIX_TIMESTAMP',
'USER',
'WEEKDAY'
* Unset magic_quotes_runtime - do not change!
set_magic_quotes_runtime(0);
Als ik nu mijn intranet pagina open kijg ik deze error..
Fatal error: Call to unsupported or undefined function extract() in ./grab_globals.inc.php3 on line 14
Lijkt erop dat dit geen fout is die in de config op te lossen is...
