• theduke1989
  • Laatst online: 13:22
Afbeeldingslocatie: https://tweakers.net/i/UDCwAHmxKXz10RFDryDTcwea_P0=/800x/filters:strip_icc():strip_exif()/f/image/FZozueKlyq50QLLnKMZlpN3E.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/-V7mnXqnNBsiKORM76HLEofoUFs=/800x/filters:strip_icc():strip_exif()/f/image/Jo5p0JZDkqNXDn0usibKrUbQ.jpg?f=fotoalbum_large
Processor
MediaTek Dimensity 7300-Ultra4nm manufacturing processCPU: Octa-core processor, up to 2.5GHzGPU: Mali-G615 MC2
Storage & RAM
8+256GB, 12+256GB, 12+512GBLPDDR4X + UFS2.2*Available storage and RAM are less than the total memory due to storage of the operating system and software pre-installed on the device.
Dimensions
Height: 162.33mmWidth: 74.42mmThickness:Coral Green & Midnight Black 8.4mm丨Lavender Purple 8.55mmWeight: 190gDAS
Display
6.67" CrystalRes AMOLED displayResolution: 2712 x 1220 (1.5K resolution)Refresh rate: Up to 120HzTouch sampling rate: Up to 480HzBrightness: 3000nits peak brightnessColor depth: 12bitContrast ratio: 5,000,000:1DCI-P3 wide color gamutCorning® Gorilla® Glass Victus® 2Supports Dolby Vision®Reading mode1920Hz PWM dimming|20,000-level brightness adjustment|HDR10+ | TÜV Rheinland Low Blue Light (Hardware Solution) Certified | TÜV Rheinland Flicker Free Certified | TÜV Rheinland Circadian Friendly Certified
Rear camera
200MP main cameraOISf/1.6516-in-1 binning into one large 2.24μm pixel1/1.4” sensor size7P lens8MP ultra-wide cameraf/2.22MP macro cameraf/2.4Dynamic shots | Motion tracking focus | Lightning Burst | filmFrame | Portraits | Document | Night mode | Dual video | Steady videoRear camera video recording4K at 24/30fps1080p at 30/60fps720p at 30fpsSlow motion: 1080p at 120fpsSlow motion: 720p at 120/240fps
Front camera
20MP front cameraf/2.2Soft-light ring | AI beautify | Night mode | Portrait mode | Palm Shutter | Selfie timerFront camera video recording1080p at 30/60fps720p at 30fps
Battery and charging
5110mAh (typ)45W turbo charging45W in-box charger
AI features
Circle to Search with Google, Google Gemini, AI image editing
Cooling system
Graphite technology
Security
In-screen fingerprint sensorAI Face Unlock
Network and Connectivity
Dual SIM (nano SIM + nano SIM or nano SIM + eSIM)*Use of eSIM requires a wireless service plan. This service plan may be subject to certain restrictions of use on switching service providers and roaming (even after contract expiration). eSIM availability may vary depending on country/region and carrier. For more details, please contact your carrier for more information.2G: GSM: 850 900 1800 1900MHz3G: WCDMA:1/2/4/5/6/8/194G: LTE FDD:1/2/3/4/5/7/8/12/13/17/18/19/20/26/28/32/664G: LTE TDD:38/40/41/42/485G: n1/2/3/5/7/8/20/28/38/40/41/48/66/77/78Bluetooth 5.4Wi-Fi: Wi-Fi 6/Wi-Fi 5/Wi-Fi 4/802.11a/b/g
Supports 2.4GHz Wi-Fi | 5GHz Wi-Fi
Supports 1*1,Wi-Fi Direct
Water & Dust Resistance
IP68*The device has been tested and certified to be resistant to splash, water, and dust in the presence of specific laboratory conditions with the classification IP68 ingress protection based on IEC 60529:1989+A1:1999+A2:2013.
Please be noted that the test conditions of water resistance include: submersion in static freshwater up to a depth of 1.5 meters, up to 30 minutes, with a temperature delta between the water and product being 5K or less. Such water resistance features only pertain to specific conditions tested in a laboratory environment, which do not correspond to the normal conditions of use by consumers.
Therefore, ingress protection is not assured if the product is subjected to environments beyond the test conditions.
We recommend that you do not test it by yourself. Not advised for beach or pool use. Ingress protection might deteriorate from daily wear and tear, physical damage and/or disassembly needed in case of repair.
Avoid charging the product, operating the physical buttons, or removing the SIM tray when product is exposed to moisture.
Please carefully refer to user's manual for other safety instructions. The warranty will not cover the liquid damage caused in the environments beyond the IP68 test condition.
NFC
Yes
Navigation
Beidou:B1I|GPS:L1|Galileo:E1
GLONASS:G1|QZSS:L1 | A-GPS supplementary positioning
Wireless network | Data network||Sensor Assisted Positioning
Audio
Dual speakersDolby Atmos®
Sensor
Proximity sensor | Ambient light sensor | Accelerometer | Electronic compass | IR blaster| Gyroscope | X-axis linear motor
Operating system
Xiaomi HyperOS
Package content
Mobile Phone / Adapter / USB Type-C Cable / SIM Eject Tool / Protective Case / Quick Start Guide and Warranty Card / Safety Information*Contents in the package may differ across different regions.
KLEUREN BESCHIKBAAR:
  • Midnight Black
  • Coral Green
  • Lavender Purple
[ Voor 89% gewijzigd door theduke1989 op 10-01-2025 11:36 ]
  • theduke1989
Versiebeheer:
TOPIC WORDT NOG BEWERKT!
  • RepareerDroid
  • Registratie: September 2022
Waardeloze sidegrades. De Chinese Pro+ had potentie met een zoom camera en een dikke 6000+mAh batterij, maar dat hebben ze er uitgesloopt in de Europese versies. Opladen van de Pro 4G en Pro 5G modellen is ook trager. Vorig jaar nog 67W, nu maar 45W. En de 3.5mm jack is dit jaar niet meer aanwezig bij de Pro's. Enkel de basis Redmi Note 14 heeft deze nog.
Ook komen de toestellen weer met Android 14, waardoor je meteen een OS upgrade kwijt bent zometeen als Android 15 naar deze toestellen komt(bekend trucje van Xiaomi om een upgrade minder te hoeven doen).
  • Brotuck
  • Registratie: Mei 2018
  • Laatst online: 08:47
Ik zie het voordeel niet van deze toestellen. Zeker niet als je het vergelijkt met de net gelanceerde Poco X7 Pro. Deze is goedkoper en sneller.
Just here for the fun
  • theduke1989
Brotuck schreef op vrijdag 10 januari 2025 @ 21:18:
Display grote is anders? Redmi note series zijn vaak veel groter
  • Brotuck
theduke1989 schreef op vrijdag 10 januari 2025 @ 23:12:
nee is exact hetzelfde.....
Afbeeldingslocatie: https://tweakers.net/i/4dkEVa88HeR1YA8gBziwlAZwtF0=/800x/filters:strip_icc():strip_exif()/f/image/5ptZWgLLqMgGjg0Xm4fbYxBy.jpg?f=fotoalbum_large
