• Setia
  • Registratie: April 2024
  • Laatst online: 22-08 15:02
Heya
So for a long time I used a laptop for gaming and school and couldn't afford to own a pc becasue my family moved around a lot. Now that I have a more permanent living space and in conjunction with my four year old laptop going kaput this week, I've decided I want a gaming PC and this is the most relevant place to get advice for me.
What do you want to do with your new system?
I play Fortnite and Marvel Rivals mostly and the goal is to get 200+ fps on 1080p during intense parts like team fights or when there's a lot of building going on, while also maintaining a good price-to-performance ratio. If it's reasonable enough I'm also considering going to 240Hz 1440p, but that's much later on.
How much will the system cost?
1300€ maximum
Are there any components or peripherals that you already have and want to take with you to your new system?
I have a 170Hz 1080p monitor and a KBM, I just need the PC itself.
What do you think you need?
I think list below can be used as a starting point.
Do you have any specific (brand) preferences?
No
Do you have any specific requirements/wishes?
I want to go with AM5 for the future upgrade path. I'm not considering raytracing. I'm kind of in need of a PC so I don't think I'll be waiting for the new GPUs to be released next month. My laptop had 512GB of storage so 1TB feels a lot more spacious but others have told me I should go with 2TB to be safe. I feel like if I need more storage I could add another SSD later on.
Are you going to overclock?
I don't plan to since it's my first time.
What do you expect from us?
This is my first time planning or building a PC and I'd like to hear your opinions and advice on this parts list and what you would do differently given the budget or points of improvement. Thank you in advance :)
1ProcessorsAMD Ryzen 5 7600 Boxed€ 184,90€ 184,90
1MoederbordenGigabyte B650 EAGLE AX€ 144,99€ 144,99
1VideokaartenPowercolor AMD Radeon RX 7800 XT 16GB€ 499,-€ 499,-
1BehuizingenLian Li Lancool 207 Zwart ATX€ 79,90€ 79,90
1ProcessorkoelingArctic Freezer 36€ 25,99€ 25,99
1VentilatorsArctic P12 PWM PST Zwart, 120mm€ 5,08€ 5,08
1Geheugen internCorsair Vengeance CMK32GX5M2B6000Z30€ 109,90€ 109,90
1VoedingenCorsair RM850x (2024)€ 124,-€ 124,-
1SSD'sWD Blue SN580 1TB€ 57,70€ 57,70
Bekijk collectie
Importeer producten
Totaal€ 1.231,46
  • RAW_
  • Laatst online: 17-09 09:27
Your suggested config already looks very decent!
You could potentially save some money on a few components:
  • The AMD Ryzen 5 7500F Tray is essentially a 7600 without the integrated graphics and stock cooler for € 30 less. Since you're going to use an dedicated graphics card and cooler, you won't be needing these features.
  • An 850W PSU is going to be overkill for this configuration. You could save a few bucks by opting for a 650 or 750W PSU: uitvoering: ASUS Prime 750W Gold, retail
  • Setia
RAW_ schreef op vrijdag 27 december 2024 @ 09:38:
Thanks! I feel like the 7500f is the best value but the no iGPU can be a downside in that it could be useful for troubleshooting if the GPU fails and since I'm a newbie I felt that spending a bit extra on the 7600 is worth it.
I saw online that the case I chose had some trouble fitting some 160mm PSUs, so I looked for 750W PSUs that people have already tried fitting on the case, one of them being the RM750x (the 850W version is currently listed the same price as the 750W so I just went with the 850W version.) But yea yours saves money and is also 150mm, good call!
1VoedingenASUS Prime 750W Gold, retail€ 95,05€ 95,05
Bekijk collectie
Importeer producten
Totaal€ 1.202,51
  • RAW_
Looks good.
I hear your argument on the (potential) usefulness of an iGPU for troubleshooting. You could however question the likelihood of a GPU failure occurring vs. the additional costs of the 7600.
You could probably squeeze an RTX 4070 Super (or a Radeon RX 7900 GRE) within your budget if you would consider the 7500f:
1ProcessorsAMD Ryzen 5 7500F Tray€ 152,99€ 152,99
1VideokaartenInno3D GeForce RTX 4070 SUPER TWIN X2€ 629,-€ 629,-
1Geheugen internPatriot Viper Venom PVV532G600C30K€ 99,90€ 99,90
Bekijk collectie
Importeer producten
Totaal€ 1.290,60
  • Setia
Great, I think this is it I'm p sure, thanks!
1VideokaartenASRock AMD Radeon RX 7900 GRE Challenger 16GB OC€ 595,99€ 595,99
Bekijk collectie
Importeer producten
Totaal€ 1.267,59
