first time builder and PC
  • 464 views
  • Setia
  • Registratie: April 2024
  • Laatst online: 22-08 15:02
Heya
So for a long time I used a laptop for gaming and school and couldn't afford to own a pc becasue my family moved around a lot. Now that I have a more permanent living space and in conjunction with my four year old laptop going kaput this week, I've decided I want a gaming PC. I play Fortnite and Marvel Rivals mostly and the goal is to get 200+ fps on 1080p during intense parts like team fights or when there's a lot of building going on, while also achieving a good price-to-performance ratio.
I was debating between the 7500f, 7600 and 7600x, as I wanted AM5 for the future upgrade path and I felt that any money spent upgrading to like a 7600x3d could be spent on a better GPU, in terms of fps per dollar. The 7500f was the best value but the no iGPU can be a downside in that it could be useful for troubleshooting if the GPU fails and since I'm a newbie I felt that spending that little bit extra on the 7600 is worth it.
For the CPU cooler, motherboard, case and power supply I chose based on popular opinion and reviews on the internet. A kind stranger pointed out that the Lancool 207 didn't have a rear fan and that it's a good idea to install a rear fan.
For the RAM I just set the filter to 32GB DDR5 MHz 6000 CL30 and sorted by lowest price and chose the first one that had reviews on it.
For the SSD it was a similar process. My laptop had 512GB storage so 1TB feels a lot more spacious but others have told me I should go with 2TB to be safe. I feel like if I need more storage I could add another SSD later on.
For the GPU, I'm not really considering raytracing so I decided to go AMD. At the start I picked the 7700XT but after choosing different parts I fit a 7800XT while staying within the budget. I am kind of in the need of a PC so I don't think I'll be waiting for the new GPUs to be released next month.
So yea, this is my first time planning or building a pc and I'd like to hear your opinions and advice on this parts list and what you would do differently.
Thanks in advance :)
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor (€185.00 @ Megekko)
CPU Cooler: ARCTIC Freezer 36 CPU Cooler (€25.00)
Motherboard: Gigabyte B650 EAGLE AX ATX AM5 Motherboard (€145.00 @ Azerty)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (€109.90 @ Amazon Netherlands)
Storage: Western Digital Blue SN580 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€64.90 @ Alternate)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card (€489.00 @ Alternate)
Case: Lian Li Lancool 207 ATX Mid Tower Case (€85.85 @ Alternate)
Power Supply: Corsair RM850x (2024) 850 W Fully Modular ATX Power Supply (€124.00 @ Alternate)
Case Fan: ARCTIC P12 PWM PST 56.3 CFM 120 mm Fan (€7.99 @ Amazon Netherlands)
Total: €1236.64
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2024-12-26 13:32 CET+0100
  • br00ky
  • Laatst online: 00:56
br00ky
Om onduidelijke redenen heb je
Vertel ons wat je wil gaan doen met je nieuwe systeem. Welke software ga je gebruiken? Wil je gaan gamen? Videobewerken? Of gewoon huis tuin en keuken surfen en mailen?
Heb je een absolute maximumprijs? In- of exclusief verzendkosten, assemblage en dergelijke Dat hoeft geen vast bedrag te zijn maar mag ook een schatting zijn.
Wees specifiek en noem merk en model
Zijn twee videokaarten en drie voedingen wel genoeg? 16 SSD's in RAID-5? Vertel ons meer over het systeem van je dromen.
Naar welk merk gaat je voorkeur uit? Kun je vertellen waarom? Sta je open voor andere merken? Zet hier neer wat je zelf al hebt gevonden.
Denk aan grootte, het te verwachten geluidsniveau, energieverbruik. Hoe meer informatie je geeft, hoe beter we je kunnen helpen.
Ga je overklokken?
Ga je voor de maximum prestaties van je nieuwe systeem of ben je tevreden met de standaard instellingen?
Wat verwacht je van ons?
De laatste en eigenlijk belangrijkste vraag: Vertel hoe we je kunnen helpen met het maken van je keuze. Wil je het nieuwste/snelste/beste/mooiste systeem dat je je maar kunt wensen binnen je budget, of speelt geld geen rol? Wil je weten of/hoe je je build moet aanpassen om aan de gewenste doelen te kunnen voldoen? Of wil je de kosten gewoon zoveel mogelijk terugbrengen en zo veel mogelijk bang-for-buck krijgen?
weggehaald. Deze vragen zijn echter essentieel voor het geven van goed advies.
We verwachten hier ook al een eigen opzetje. Zie ook de volgende passage uit het DAA beleid.
3. Eigen onderzoek is nog steeds vereist (dit is en blijft GoT!) en we verwachten dat je zelf al een idee hebt opgedaan. Als je zelf al een configuratie hebt bedacht, post deze dan met behulp van de wenslijst in de pricewatch hier. Dat geeft je mede-Tweakers inzicht in waar je zelf aan hebt gedacht en hoe er binnen je budget betere of andere keuzes te maken zijn.
Het is dus verplicht eerst zelf met een voorstel te komen en dit voorstel te onderbouwen. Een simpele opsomming van eisen/wensen is niet wenselijk; je topic wordt in dat geval dan ook gesloten. Je kan in dat geval contact opnemen met de moderator die je topic gesloten heeft om te vragen of hij weer open mag, mits je natuurlijk wijzigingen hebt aangebracht zodat het geheel wel aan de eisen voldoet.
Een simpel antwoord als 'Ik heb heb er niet veel verstand van!' óf 'Ik ben veel sneller klaar als jullie het doen!' is uit den boze.
Dit lijkt flauw, maar enerzijds doen we dit om ervoor te zorgen dat je zélf inzicht krijgt in wat er mogelijk is en anderzijds om de kwaliteit van de topicstarts hier te bewaken. Anders vervalt dit subforum in een "ik wil een pc voor x euro, mkay dank je doei" niveau, en dat is iets dat niemand wil :). Je eerste opzet hoeft niet top te zijn, we willen alleen graag dat je er eerst over nadenkt.
Om inspiratie op te doen kun je de verschillende topics in dit subforum en de best buy guides doorzoeken.
Met de Handleiding Pricewatch dien je vervolgens een mooi lijstje te maken (dus géén copy-paste lijsten van andere sites bijv.). Met die informatie kan vervolgens gericht advies gegeven worden om het helemaal aan jouw wensen aan te passen.
Succes!
