FS XGSPON SFP+ Module Setup with UniFi Pro Max HELP
  • Cemil2565
  • Registratie: Oktober 2018
  • Laatst online: 14-08 13:48
Dear Networking Experts,
I am seeking advice on configuring a 10G XGSPON SFP+ module from FS.com (product link) to replace my Nokia ONT and connect it directly to my UniFi Pro Max. ISP is Proximus
Issue Details:
XGSPON Serial Number: I’ve located the correct GPON serial number and entered it into my ISP’s "Install Your Own Equipment" portal. My old Nokia ONT was disabled successfully, but I am still not receiving Ethernet from the SFP module. Even tho Unifi sees the Module connected (picture)
Possible Cloning Requirements: It may require additional details from the Nokia ONT, such as cloning certain settings (e.g., serial number, MAC address, or other identifiers) onto the SFP module or not idk.
Questions:
UniFi Configuration: Are there any specific settings I need to apply on the UniFi Pro Max for XGSPON SFP+ compatibility?
Cloning ONT Details: Has anyone successfully cloned a Nokia ONT’s configuration (serial number, MAC address, etc.) to an SFP module for ISP activation? If so, what tools or commands were used? and do i need that is that my problem?
Telnet or Console Access: Should I access the SFP+ module via Telnet to confirm or modify its settings for ISP requirements? (FS customer support said dont change Gpon id or password.)
Also i can only Telnet the sfp module only when its in lan port, when i change its port again to wan from unifi, i cant access telnet, it needs to be in lan mode, thats normal right?
Current Setup:
ISP: Belgium-based Fiber ISP
Device: UniFi Pro Max
Module: FS.com 10G GPON SFP+
Any guidance on how to proceed with cloning or configuring the module to ensure full compatibility with the ISP would be greatly appreciated.
Thank you for your help!
Afbeeldingslocatie: https://tweakers.net/i/XDR6K15zwL3n9QU4uIg8LK89M_k=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/igZBXprvaCWX4hY2ms70yIop.png?f=user_large
  • Cemil2565
It works now, after the command “python fs_xgspon_mod.py overrideslot GPONXXXXXXX 1”
