kan 'epson-inkjet-printer-escpr' niet updaten (fedora)
  • DutchGlory
  • Laatst online: 28-11-2024
SYSTEM INFO
System:
Kernel: 6.11.8-300.fc41.x86_64 arch: x86_64 bits: 64 compiler: gcc v: 2.43.1-2.fc41 clocksource: tsc
Desktop: Cinnamon v: 6.2.9 tk: GTK v: 3.24.43 wm: Muffin vt: 1 dm: LightDM v: 1.32.0
Distro: Fedora Linux 41 (Forty One)
CPU:
Info: dual core model: Intel Core2 6700 bits: 64 type: MCP smt: <unsupported> arch: Core2 Merom rev: 6 cache: L1: 128 KiB L2: 4 MiB
Speed (MHz): avg: 2664 min/max: 1596/2660 cores: 1: 2664 2: 2664 bogomips: 10655
Graphics:
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nouveau v: kernel arch: Pascal pcie:
speed: 2.5 GT/s lanes: 16 ports: active: DVI-I-1 empty: HDMI-A-1,VGA-1 bus-ID: 01:00.0
chip-ID: 10de:1c82 class-ID: 0300 temp: 39.0 C
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: nouveau gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 338x270mm (13.31x10.63") s-diag: 433mm (17.03")
Monitor-1: DVI-I-1 model: HP L1740 serial: <filter> res: 1280x1024 hz: 60 dpi: 96
size: 338x270mm (13.31x10.63") diag: 426mm (16.8") modes: max: 1280x1024 min: 720x400
API: OpenGL v: 4.3 vendor: mesa v: 24.2.7 glx-v: 1.4 es-v: 3.1 direct-render: yes
renderer: NVC3 device-ID: 10de:1c82
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Memory:
total: 6 GiB available: 5.71 GiB used: 2.68 GiB (46.9%)
kan 'epson-inkjet-printer-escpr' package from 1.8.5-1 niet updaten naar 1.8.6-1. 1.8.6-1, pakket beschadigd..??
Updating and loading repositories:
Repositories loaded.
Package Arch Version Reposit Size
Upgrading:
epson-inkjet-printer-escpr x86_64 1.8.6-1 @comman 5.7 MiB
replacing epson-inkjet-printer-escpr x86_64 1.8.5-1 @comman 5.6 MiB
Transaction Summary:
Upgrading: 1 package
Replacing: 1 package
Total size of inbound packages is 5 MiB. Need to download 0 B.
After this operation, 51 KiB extra will be used (install 6 MiB, remove 6 MiB).
Is this ok [y/N]: y
Running transaction
terminate called after throwing an instance of 'libdnf5::AssertionError'
what(): libdnf5/rpm/transaction.cpp:193: void libdnf5::rpm::Transaction::fill(const libdnf5::base::Transaction&): Assertion 'implicit_ts_elements.empty()' failed: The rpm transaction contains more elements than requested
Afgebroken (made memorydump)
  • mrmrmr
mrmrmr
𓅓 𓂋 𓅓 𓂋 𓅓 𓂋
De command line opdracht ontbreekt in je post.
Als je dnf5 gebruik lijkt het op dit probleem.
Misschien kun je dan eerst geforceerd dnf5 updaten? Voer je de update uit als root?
Ik gebruik geen Fedora, maar ik vraag me af of dit werkt: dnf upgrade dnf5 met of zonder --refresh.
