[debian] apt-gelazer
  • 0siris
  • Laatst online: 06-09 09:59
Hallo.
Ik gebruik Debian stable release, was wat aan het klungelen om toch een nieuwere versie van PHP te hebben, dus zelf wat .deb-jes proberen te installen met dpkg -i. Flink veel dependency problems, en ik heb het maar opgegeven (tja, dan maar GEEN nieuwe PHPversie).
Maar als ik nu iets probeer te installen, bijv pas2html, dan krijg ik dit:
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run `apt-get -f install' to correct these:
Sorry, but the following packages have unmet dependencies:
  apache: Depends: apache-common (< 1.3.10) but 1.3.20-1.1 is to be installed
  apache-common: Depends: libdb2 (>= 2:2.7.7-4) but 2:2.4.14-2.7.7.1.c is to be installed
  libc6-dev: Depends: libc6 (= 2.1.3-18) but 2.2.4-1 is to be installed
  locales: Depends: libc6 (= 2.1.3-18) but 2.2.4-1 is to be installed
  php4: Depends: libbz2-1.0 but it is not installable
      Depends: libexpat1 (>= 1.95.1-2) but it is not installable
      Depends: libmm11 but it is not installable
      Depends: libpcre3 but it is not installable
      Depends: apache-common (< 1.3.19.1) but 1.3.20-1.1 is to be installed
  php4-imap: Depends: php4 (= 4.0.3pl1-0potato1) but 4.0.4.5rc6-2 is to be installed
  php4-mysql: Depends: libmysqlclient10 but it is not installable
          Depends: php4 (= 3:4.0.5.6rc3-3) but 4.0.4.5rc6-2 is to be installed or
                 php4-cgi (= 3:4.0.5.6rc3-3) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Nou krijg ik dus al als oplossing "apt-get -f install", maar als ik dat run krijg ik dit:
Correcting dependencies... Done
The following packages will be REMOVED:
  apache apache-common g++ horde libapache-mod-ssl libc6-dev libncurses5-dev
libstdc++2.10-dev locales php4 php4-imap
  php4-mysql task-c++-dev task-c-dev
0 packages upgraded, 0 newly installed, 14 to remove and 0 not upgraded.
3 packages not fully installed or removed.
Need to get 0B of archives. After unpacking 33.5MB will be freed.
Do you want to continue? [Y/n]
Hmjah...daar word ik niet vrolijk van, maar als het echt niet anders kan....
Iemand betere ideeen dan "apt-get -f install" of "rm -rf /" ? :'(
ach...in een volgend leven lach je er om!
die zul je eerst moeten verwijderen, dan pas zal je weer kunnen apt-getten....
Dus apt-get -f install, ja.
En de packages die je wilt houden daarna alsnog met apt-get install herinstallen, en nu wel goed ;)
  • wouzer
Probeer eens een goeie sources.list, hier de mijne:
deb http://ftp.nl.debian.org/debian stable main contrib non-free
deb http://non-us.debian.org/debian-non-US stable/non-US main contrib non-free
deb http://security.debian.org/ stable/updates main contrib non-free
deb http://http.us.debian.org/debian dists/proposed-updates/
deb http://non-us.debian.org/debian-non-US dists/proposed-updates/
  • 0siris
die sourceslist is altijd goed geweest, dus ik vrees dat de oplossing van beelzebubu helaas de enige juiste is ;(
  • 0siris
ok... apt-get -f install gedaan, toen met apt-get install weer alles geinstalleerd, sweeeeeeet :)
Op woensdag 12 september 2001 12:40 schreef 0siris het volgende:
apt-get is gewoon sweet :D
  • wimpie
  • Registratie: September 1999
apt-get update misschien eerst ff update..anders denk ik da php gewoon een unstable .deb bestand is.. tjah.. en die zal dan ook wel van unstable andere .deb bestanden afhankelijk zijn uh
Divide and conquer.
