[Perl / Python] Parrot version 0.0.1 eindelijk uit
  • unclero
  • Laatst online: 19:18
unclero
MB EQA ftw \o/
Het is zover...
Wat begon als een 1-april grap (zie http://www.perl.com/pub/a/2001/04/01/parrot.htm ), waar alle Python en Perl programmeurs intrapten en in paniek raakten. Is nu toch werkelijkheid geworden.
Parrot-interpreter v.0.0.1 is uitgebracht.
Even een quootje uit een meeltje die ik vanochtend kreeg van de NL Perl Meelinglist:
It's happening time ...
Because the game of hide-and-seek was still going on, it took Edmund
and Lucy some time to find the others. But when at last they were all
together (which happened in the long room, where the suit of armour
was) Lucy burst out: "Peter! Susan! It's all true. Edmund has seen it too. There is a
country you can get to through the wardrobe. Edmund and I both got in.
We met one another in there, in the wood. Go on, Edmund; tell them all
about it." - "The Lion, The Witch and the Wardrobe",
CS Lewis I suppose (unlike Edmund did) I should tell you all about it. What we're releasing today is a very, very early alpha of the Parrot interpreter. At the moment, we have support for some simple operations on integer, floating
point and string registers, and the ability to read in and execute bytecode.
We also have an assembler which can generate bytecode output from Parrot assembly. You can get the source tarball in (currently) two different ways:
From CPAN: http://www.cpan.org/authors/id/S/SI/SIMON/parrot-.0.1.tar.gz
http://www.cpan.org/src/parrot-0.0.1.tar.gz
(once the mirrors have updated)
From CVS: See the Parrot CVS home page at http://cvs.perl.org/ Once you've unpacked parrot, you should be able to "make test_prog", and use the Parrot assembler to turn assembly into bytecode:
make test_prog
perl assemble.pl test.pasm > test.pbc
./test_prog test.pbc
perl assemble.pl test2.pasm > test2.pbc
./test_prog test2.pbc
The first test program will add some numbers together, count to 10,000,000, and tell you how long it took; the second test program will print a familiar greeting. In the next email, coming in a couple of minutes, I'll outline two areas
where I really, really need some patches before we go much further; you should also note that Parrot has a bug/request tracking system at
http://parrotbugs.develooper.com/ which will be filled with some more things that I'd like people to take a
look at. Patches should be sent to the perl6-internals mailing list, where I'll take a look at them and apply them to the CVS tree. As time goes by, people who regularly submit good patches will be given committer access to the tree, and can help me out applying other patches from the list. IMPORTANT! Please note that we haven't decided the final license for Parrot yet. You currently receive Parrot under the same terms as Perl 5: your choice of either the Artistic or General Public Licenses.
Have fun,
Simon --
set_s_sc S1, "Just Another Parrot Hacker, "
print_s S1
--------------------- Original Message Ends ----------------
> From CPAN:
http://www.cpan.org/authors/id/S/SI/SIMON/parrot-0.0.1.tar.gz
> From CVS: See the Parrot CVS home page at http://cvs.perl.org/ OK, I screwed that one up good and proper. :( Be nice, I'm new to this game. Please use the anon CVS where you can, because that'll always be up to date, and won't suffer from any packaging issues. Emergency fixed package available at
http://www.netthink.co.uk/downloads/parrot-0.0.1.tar.gz I've even tested this one. Sorry, and this time, have more fun. Simon
En nou een lekker avondje porten... (dat het ding ook onder DOS wil draaien..)
Quelle chimère est-ce donc que l'homme? Quelle nouveauté, quel monstre, quel chaos, quel sujet de contradiction, quel prodige!
  • Orphix
ok, ff voor de newbies een stukje parrot code:
    # copy stdin to stdout, except for lines starting with #
    while left_angle_right_angle:
      if dollar_underscore[0] =eq= "#":
        continue_next;
      print dollar_underscore;
:+ Let vooral op de brackets, de : en } :)
