• lordgrimz
  • Registratie: Augustus 2024
  • Laatst online: 12-09-2024
Hello everybody,
I am a newbie, never really build my own PC.. But I think it's high time I actually make time for it since it has been a year long project of mine and never really had the time for it.
I am planning to use it mainly for gaming, maybe now and then streaming and/or editing videos and photos. I have read some topics here and there, did some research, maybe not enough but I am hoping some of you might help me out with it. I will be using a Samsung Odyssey 32" 4K 144Hz display, please advise if the parts I have chosen are good enough or maybe even an overkill.
I am probably gonna play CoD, RDR2, Cyberpunk, FF, you get the high demand :P The idea behind such an expensive build would be that it should be set for a few years before I decide to upgrade at all.
IF it is necessary to upgrade of course hahah :P
These are the parts I have chosen:
PC CASE: Corsair iCUE 4000D RGB AIRFLOW Mid-Tower Black
CPU: AMD Ryzen 9 5900x
GPU: AMD Radeon RX 7800 XT 16GB or GeForce RTX 3080 12GB
RAM: Corsair Dominator Platinum RGB 32GB 2x 16GB DDR4 3600MHz
LOGIC BOARD: ROG STRIX B550-A GAMING
COOLING SYSTEM: AK620 Zero Dark
EXHAUST COOLING FANS: Acrtic P12, 3 or 5 fans
POWER SUPPLY: CORSAIR RM850e 80+ GOLD
STORAGE M.2: SAMSUNG 990 EVO 2 TB SSD
EXTRA SSD: Samsung QVO 870 4TB
Please let me know what you think of it :)
Thanks!
  • sjaakwortel
  • Laatst online: 09:47
lordgrimz schreef op dinsdag 27 augustus 2024 @ 15:56:
Hello everybody,
RAM: Corsair Dominator Platinum RGB 64GB 2x 32GB DDR4 3600MHz
STORAGE M.2: 2x SAMSUNG 990 EVO 2 TB SSD
Thanks!
For gaming a 5800x3d would be a better choice.
  • Uszka
  • Registratie: Maart 2018
Waarom geen AM5? Een 7600X presteert hetzelfde als een 5800X3D en op AM5 kan je later nog upgraden.
RM850e is geen goede keuze en dan vooral om de ventilator. uitvoering: DeepCool PX850G is beter en goedkoper.
  • br00ky
  • Laatst online: 09-11 22:50
br00ky
Om onduidelijke redenen heb je
Vertel ons wat je wil gaan doen met je nieuwe systeem. Welke software ga je gebruiken? Wil je gaan gamen? Videobewerken? Of gewoon huis tuin en keuken surfen en mailen?
Heb je een absolute maximumprijs? In- of exclusief verzendkosten, assemblage en dergelijke Dat hoeft geen vast bedrag te zijn maar mag ook een schatting zijn.
Wees specifiek en noem merk en model
Zijn twee videokaarten en drie voedingen wel genoeg? 16 SSD's in RAID-5? Vertel ons meer over het systeem van je dromen.
Naar welk merk gaat je voorkeur uit? Kun je vertellen waarom? Sta je open voor andere merken? Zet hier neer wat je zelf al hebt gevonden.
Denk aan grootte, het te verwachten geluidsniveau, energieverbruik. Hoe meer informatie je geeft, hoe beter we je kunnen helpen.
Ga je overklokken?
Ga je voor de maximum prestaties van je nieuwe systeem of ben je tevreden met de standaard instellingen?
Wat verwacht je van ons?
De laatste en eigenlijk belangrijkste vraag: Vertel hoe we je kunnen helpen met het maken van je keuze. Wil je het nieuwste/snelste/beste/mooiste systeem dat je je maar kunt wensen binnen je budget, of speelt geld geen rol? Wil je weten of/hoe je je build moet aanpassen om aan de gewenste doelen te kunnen voldoen? Of wil je de kosten gewoon zoveel mogelijk terugbrengen en zo veel mogelijk bang-for-buck krijgen?
weggehaald. Deze vragen zijn echter essentieel voor het geven van goed advies.
We verwachten hier ook al een eigen opzetje. Zie ook de volgende passage uit het DAA beleid.
3. Eigen onderzoek is nog steeds vereist (dit is en blijft GoT!) en we verwachten dat je zelf al een idee hebt opgedaan. Als je zelf al een configuratie hebt bedacht, post deze dan met behulp van de wenslijst in de pricewatch hier. Dat geeft je mede-Tweakers inzicht in waar je zelf aan hebt gedacht en hoe er binnen je budget betere of andere keuzes te maken zijn.
Het is dus verplicht eerst zelf met een voorstel te komen en dit voorstel te onderbouwen. Een simpele opsomming van eisen/wensen is niet wenselijk; je topic wordt in dat geval dan ook gesloten. Je kan in dat geval contact opnemen met de moderator die je topic gesloten heeft om te vragen of hij weer open mag, mits je natuurlijk wijzigingen hebt aangebracht zodat het geheel wel aan de eisen voldoet.
Een simpel antwoord als 'Ik heb heb er niet veel verstand van!' óf 'Ik ben veel sneller klaar als jullie het doen!' is uit den boze.
Dit lijkt flauw, maar enerzijds doen we dit om ervoor te zorgen dat je zélf inzicht krijgt in wat er mogelijk is en anderzijds om de kwaliteit van de topicstarts hier te bewaken. Anders vervalt dit subforum in een "ik wil een pc voor x euro, mkay dank je doei" niveau, en dat is iets dat niemand wil :). Je eerste opzet hoeft niet top te zijn, we willen alleen graag dat je er eerst over nadenkt.
Om inspiratie op te doen kun je de verschillende topics in dit subforum en de best buy guides doorzoeken.
Met de Handleiding Pricewatch dien je vervolgens een mooi lijstje te maken (dus géén copy-paste lijsten van andere sites bijv.). Met die informatie kan vervolgens gericht advies gegeven worden om het helemaal aan jouw wensen aan te passen.
Succes!
