Third monitor Detected but cant display anything on Windows
  • 597 views
  • GlobackX
  • Registratie: Juli 2024
  • Laatst online: 29-07-2024
Hi everyone, I just bought 3 4K 160hz displays but when I connect them ( all three with dp 2.1) only 2 work the other one is detected but doesn’t display anything (when i disconnect one the other jumps ons and works fine) I’ve tried doing NVIDIA surround but when I enable it it just reboots my pc and turns surround off again. I’ve tried lowering the resolution , Hz and turning HDR on and off but I can’t get the three monitors to work simultaneously. I have reinstalled the Drivers ,Reset the monitors (and deleted them from device manager) used different cables (connecting them in order) etc. i tried it on Linux (ubuntu) and it worked fine 3x 4k 144Hz. but on windows 11 only 2 display anything at one time. Any help is appreciated.
System information:
Windows 11 10.022631 Build 22631
(Fresh windows install)
Nvidia Driver 560.70
(removed and reinstalled it a couple times)
Bios version F4
AMD Ryzen 9 7900X
B650M Gaming X AX (rev. 1.0/1.1/1.2)
Gainward GeForce RTX™ 4070 Ghost OC
not 100% sure about the brand but 32gb 4800Mt's from crucial
PSU i dont remember but its 850 watt
Monitor 3X TCL 27r83uAfbeeldingslocatie: https://tweakers.net/i/TTDl2x4W-oeGBNhw8BHm7gFQmdQ=/800x/filters:strip_exif()/f/image/uscKIQ3Umb1cLLFamH7FTypf.png?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/kSIhB7RBkerEcSATqIJiGYmviHA=/800x/filters:strip_exif()/f/image/AgxFCudF8wmkklz1NeTEhEjR.png?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/Lim48dV93YkIa64og-QplyO8E1E=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/EReKtRHPVftKl4vK3ODGUTjq.png?f=user_large
Afbeeldingslocatie: https://tweakers.net/i/FmIbDPzE2EshnCw07yqoIUAcho4=/800x/filters:strip_exif()/f/image/L1BhwAWDQe5YR6cs3RaqTYIz.png?f=fotoalbum_large
[ Voor 51% gewijzigd door GlobackX op 27-07-2024 11:44 . Reden: geupdate met systeem info en fotos ]
  • nelizmastr
  • Laatst online: 12-11 21:18
nelizmastr
Goed wies kapot
Officieel ondersteunt de 4070 maar 4K 120Hz met meer dan 2 monitoren. Heb je er al eens een geprobeerd aan te sluiten op HDMI? Of alle teruggezet naar 120?
With an HDMI port and 3x DisplayPort connections, it can accommodate up to 4x independent monitors at 120Hz. Although at 240Hz, it can only support 2x 4K monitors or 8K at 60Hz with DSC using DP or HDMI.
[ Voor 3% gewijzigd door nelizmastr op 28-07-2024 08:08 ]
  • GlobackX
ik heb ze alle 3 al ns op 1080p 60Hz, en geen HDR gezet maar heb nogsteeds het zelfde rpobleem
  • dion_b
  • Laatst online: 23:43
dion_b
say Baah
Tot nader orde spreken we hier Nederlands. Als je dat prima kunt is een copy/paste van EN-talige text gewoon gebrek aan eigen inzet. Dicht.
Oslik, blyat! Oslik!
