voor iedereen met een te hoge temp install als je geen koetje draait vcool en je temp trouble is over we zijn gelijk van alle temp topics af denk ik
have fun
ps: vcool How it works
The Athlon (or Duron) enters a lower power state only when its system bus is disconnected. However the (VIA-)Northbridge will only disconnect the bus if its "Bus Disconnect Enable" bit is set and the CPU is in STPGNT state.
VCool allows you to enable this bit so your CPU can relax when there's nothing to do.
Setting this bit might not be enough on some systems as the idle loop provided with the OS will not put the CPU into the STPGNT state recognized by the Northbridge.
For those cases VCool includes an internal idle loop that forces the CPU into the STPGNT mode required by the Northbridge to initiate a bus disconnect.
have fun
