Met de InStr functie kun je op strings binnen een string zoeken:
InStr Function
Returns the position of the first occurrence of one string within another.
InStr([start, ]string1, string2[, compare])
Arguments
start
Optional. Numeric expression that sets the starting position for each search. If omitted, search begins at the first character position. If start contains Null, an error occurs. The start argument is required if compare is specified.
string1
Required. String expression being searched.
string2
Required. String expression searched for.
compare
Optional. Numeric value indicating the kind of comparison to use when evaluating substrings. See Settings section for values. If omitted, a binary comparison is performed.
Settings
The compare argument can have the following values:
Constant Value Description
vbBinaryCompare 0 Perform a binary comparison.
vbTextCompare 1 Perform a textual comparison.
Return Values
The InStr function returns the following values:
If InStr returns
string1 is zero-length 0
string1 is Null Null
string2 is zero-length start
string2 is Null Null
string2 is not found 0
string2 is found within string1 Position at which match is found
start > Len(string2) 0
Remarks
The following examples use InStr to search a string:
Dim SearchString, SearchChar, MyPos
SearchString ="XXpXXpXXPXXP" ' String to search in.
SearchChar = "P" ' Search for "P".
MyPos = Instr(4, SearchString, SearchChar, 1) ' A textual comparison starting at position 4. Returns 6.
MyPos = Instr(1, SearchString, SearchChar, 0) ' A binary comparison starting at position 1. Returns 9.
MyPos = Instr(SearchString, SearchChar) ' Comparison is binary by default (last argument is omitted). Returns 9.
MyPos = Instr(1, SearchString, "W") ' A binary comparison starting at position 1. Returns 0 ("W" is not found).
Note The InStrB function is used with byte data contained in a string. Instead of returning the character position of the first occurrence of one string within another, InStrB returns the byte position.
Requirements
Version 1
See Also
InStrRev Function
PS: Dit staat gewoon in de MSDN en op een miljard andere asp sites hoor!
