  • mbenni00
  • Registratie: Mei 2024
  • Laatst online: 22-05-2024
Mijn vraag
Hi allen! ik ben bezig met mijn thesis die klaar moet zijn voor vrijdag. Helaas heb ik wat probleempjes met de code die stata in VBA. Die mij een aantal errors aangeeft. hopelijk kunnen jullie mij een werkende code geven die ik ka gebruiken : Option Explicit
Sub UpdatePromt()
Dim Prompt As String, SentFrom As String, CompName As String, CompContact As String
Dim VarName1 As String, VarName2 As String, VarName3 As String, VarName4 As String
Dim VarValue1 As String, VarValue2 As String, VarValue3 As String, VarValue4 As String
Dim SendTo As String, Tone As String
SentFrom = Admin.Range("D5").Value 'Sent From Name
CompName = Admin.Range("D6").Value 'Sent From Company
CompContact = Admin.Range("D7").Value 'Company Contact Info
With EmailGen
Tone = .Range("O5").Value 'Email Tone
SendTo = .Range("R5").Value 'Send to Name
Prompt = .Range("H10").Value 'Prompt With Variables
VarName1 = "[" & .Range("I7").Value & "]" 'Variable Name 1
VarName2 = "[" & .Range("K7").Value & "]" 'Variable Name 2
VarName3 = "[" & .Range("M7").Value & "]" 'Variable Name 3
VarName4 = "[" & .Range("O7").Value & "]" 'Variable Name 4
VarValue1 = .Range("R7").Value 'Variable Value 1
VarValue2 = .Range("T7").Value 'Variable Value 2
VarValue3 = .Range("V7").Value 'Variable Value 3
VarValue4 = .Range("X7").Value 'Variable Value 4
'Update Formats if not General
If .Range("R7").NumberFormat <> "General" Then VarValue1 = Format(VarValue1, .Range("R7").NumberFormat)
If .Range("T7").NumberFormat <> "General" Then VarValue2 = Format(VarValue2, .Range("T7").NumberFormat)
If .Range("V7").NumberFormat <> "General" Then VarValue3 = Format(VarValue3, .Range("V7").NumberFormat)
If .Range("X7").NumberFormat <> "General" Then VarValue4 = Format(VarValue4, .Range("X7").NumberFormat)
'Replace from Email Settings
Prompt = Replace(Replace(Replace(Replace(Replace(Prompt, "[Tone]", Tone), "[Send To]", SendTo), "[Sent From]", SentFrom), "[Company Name]", CompName), "[Company Contact]", CompContact)
'Replace variables with values
.Range("H23").Value = Replace(Replace(Replace(Replace(Prompt, VarName1, VarValue1), VarName2, VarValue2), VarName3, VarValue3), VarName4, VarValue4)
End With
End Sub
Sub Generate_Response()
Dim oXMLHTTP As Object
Dim Response As String, AIBody As String, Prompt As String, SecretKey As String, ParsedAnswer As String, Subject As String
Dim URL As String, SendTo As String, SiteLink As String, Model As String, Temp As String, EmailType As String
UpdatePromt 'Run Macro to Update prompt
'Determine API Request Variables
With Admin
EmailType = .Range("G4").Value 'Email Type
SecretKey = .Range("G6").Value 'Secret Key
Model = .Range("G7").Value 'Model
Temp = .Range("G8").Value 'Temperature
End With
If SecretKey = "" Then
MsgBox "Please make sure to enter a secret key on the Admin sheet"
Exit Sub
End If
With EmailGen
Prompt = Replace(Replace(Replace(.Range("H23").Value, Chr(34), "\" & Chr(34)), vbNewLine, "\n"), Chr(10), "\n") 'Prompt
If Prompt = "" Then
MsgBox "Please make sure to enter a prompt"
.Range("H10").Select
Exit Sub
End If
.Shapes("GenTextMsg").Visible = msoCTrue 'Display Generating Response Shape
Application.ScreenUpdating = True
DoEvents
Set oXMLHTTP = CreateObject("MSXML2.ServerXMLHTTP")
oXMLHTTP.Open "POST", "https://api.openai.com/v1/completions", False 'Set Open Posts For Text
AIBody = "{""model"": """ & Model & """, ""prompt"": """ & Prompt & """, ""temperature"": " & Temp & " , ""max_tokens"": 3500}" 'Request Body For Text Response
Debug.Print AIBody
oXMLHTTP.SetRequestHeader "Content-Type", "application/json" 'Set Header Type
oXMLHTTP.SetRequestHeader "Authorization", "Bearer " & SecretKey 'Set Header Authorization
oXMLHTTP.Send AIBody
Response = oXMLHTTP.responseText 'Extract Response
Debug.Print Response
If InStr(Response, "Incorrect API key provided") > 0 Then
MsgBox "Incorrect API key provided. You can find your API key at " & vbCrLf & "https://platform.openai.com/account/api-keys."
Exit Sub
End If
If InStr(Response, "maximum context length") > 0 Then
MsgBox "The length of the prompt and response is too long, please break it up into smaller parts or reduce the temperature."
Exit Sub
End If
End With
End Sub
Sub ParseResponse()
Dim ParsedAnswer As String
' Example response for testing
' Check if the response contains the expected pattern
Dim textPos As Long
Dim Subject As String
textPos = InStrRev(Response, "[{" & Chr(34) & "text" & Chr(34) & ":" & Chr(34))
If textPos > 0 Then
' Remove the first part of the coded response
ParsedAnswer = Right(Response, Len(Response) - textPos - 9)
' Remove the first two empty lines
ParsedAnswer = Right(ParsedAnswer, Len(ParsedAnswer) - 4)
' Remove the last part of the coded response
Dim endPos As Long
endPos = InStrRev(ParsedAnswer, "}") ' Adjust this part based on the actual structure of your response
If endPos > 0 Then
ParsedAnswer = Left(ParsedAnswer, endPos - 1)
End If
' Replace new lines with carriage return characters and handle quotation marks
ParsedAnswer = Replace(Replace(ParsedAnswer, "\n", Chr(10)), "\" & Chr(34), Chr(34))
' Output the parsed answer (for testing purposes)
MsgBox ParsedAnswer
Else
MsgBox "Pattern not found in response"
End If
'Extract Subject
Debug.Print ParsedAnswer;
If InStr(ParsedAnswer, "Subject Line:") > 0 Then 'If Response contains 'Subject Line
Subject = Replace(Left(ParsedAnswer, InStr(ParsedAnswer, Chr(10)) - 1), "Subject Line: ", "")
ParsedAnswer = Replace(ParsedAnswer, "Subject Line: " & Subject & Chr(10), "")
Else 'If Response only contains 'Subject:'
Subject = Replace(Left(ParsedAnswer, InStr(ParsedAnswer, Chr(10)) - 1), "Subject: ", "")
ParsedAnswer = Replace(ParsedAnswer, "Subject: " & Subject & Chr(10), "")
End If
With EmailGen
If Left(ParsedAnswer, 1) = Chr(10) Then
ParsedAnswer = Right(ParsedAnswer, Len(ParsedAnswer) - 1) ' Remove any beginning carriage returns if they exist
End If
.Range("R10").Value = Subject
.Range("Q12").Value = ParsedAnswer
.Shapes("GenTextMsg").Visible = msoFalse ' Hide Information text shape
End With
End Sub
Sub Create_Email()
Dim OutApp As Object, OutMail As Object
Dim DispEmail As String, EmailType As String, Subject As String, Message As String, EmailTo As String
Dim EmailRow As Long
With EmailGen
EmailTo = .Range("V5").Value 'Email to
Subject = .Range("R10").Value 'Subject
Message = .Range("Q12").Value 'Message
End With
DispEmail = Admin.Range("G5").Value 'Email Option (Yes/no)
Set OutApp = CreateObject("Outlook.Application")
Set OutMail = OutApp.CreateItem(0)
With OutMail
.To = EmailTo
.Subject = Subject
.Body = Message
If DispEmail = "Yes" Then .Display Else .Send
End With
With EmailLog
EmailRow = .Range("A99999").End(xlUp).Row + 1
.Range("A" & EmailRow).Value = Now 'Set Day and time
.Range("B" & EmailRow).Value = EmailTo 'Sent To
.Range("C" & EmailRow).Value = Subject 'Email Subject
.Range("D" & EmailRow).Value = Message ' Email Message
.Range(EmailRow & ":" & EmailRow).WrapText = False
End With
End Sub
sk-proj-WBRVSTVrGCGg01ut40AaT3BlbkFJ1FTFO6aKCX1s6w3Udj2f
Ik gebruik ChatGPT en VBA met prompting
Ik ben al bezig geweets om via videos en chatgpt de code aan te passen en meerdere mensen gevraagd om te helpen helaas nog niet gelukt...
  • pagani
Gezien je vrijdag klaar moet zijn met je thesis neem ik aan dat je al zeker een half jaar bezig bent en niet twee dagen voor het inlevermoment deze code gaat schrijven. Dus, werkte de code eerst wel?
  • g0tanks
  • Registratie: Oktober 2008
  • Laatst online: 17:34
g0tanks
Moderator CSA
Tweakers is helaas geen helpdesk. Ik mis een duidelijke beschrijving van het probleem, waar je tegen aan loopt en wat je zelf al hebt geprobeerd. Daarom gaat dit topic dicht.
