Deinstalleer die dos emulatie/drivers reut voor je soundblaster. Sinds ik dat heb gedaan is mijn systeem echt 100 maal stabieler en hij sluit zelfs helemaal goed af nu. (vroeger bleef hij hangen bij "u kunt u computer uitzetten")
Hoe?:
SYMPTOMS
How to Disable the SB16 Emulation in Windows 98
RESOLUTION
Right click on the My Computer icon and choose Properties. The System Properties window should open. Click on the Device Manager tab. Click on the plus sign next to Creative Miscellaneous Devices. Highlight Creative SB 16 emulation and click the Properties button. Under the General tab you will see a Device Usage category. This will towards the bottom of the page and there are two options that you can select: Exists in all hardware profiles and Disable in all hardware profiles. Check the box next to disable and uncheck the box next to exists. Click Ok. Close the System Properties window.
Click the Start button and then click Run. Type CTSYN.INI and then click Ok. This will open the file in notepad. Find the line that says SBEnable=true. Delete the word true from this line and type false in its place. Click the File pull down menu in the top left corner and then click Save. Close the Ctsyn.ini window.
Click the Start button and then click Run. Type MSCONFIG then click Ok. This will open the System Configuration Utility. If you see a message that says Environment variables were found in the legacy files... just click on Ok and the System Configuration Utility will open. Click on the Autoexec.bat tab. Find the line C:\Progra~1\Creative\Sblive\dosdrv\SBEINIT.com and uncheck the box to the left of it. Click on Ok and you will be prompted to restart your computer. Click yes.
Suc6
