since 21aug'04: Asus K8VSE Deluxe, AMD Athlon 64 3400+, Twimos 1 GB PC3200, Maxtor U133/7200 160GB+120GB, Asus V9999GE and SunBeam Aryclic Case
Misschien kan je iets fouts vinden in .config file voor kernel-compilatie...
# Code maturity level options
CONFIG_EXPERIMENTAL=y
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODVERSIONS=y
CONFIG_KMOD=y
# Networking options
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_NETLINK=y
CONFIG_RTNETLINK=y
# CONFIG_NETLINK_DEV is not set
CONFIG_NETFILTER=y
CONFIG_NETFILTER_DEBUG=y
CONFIG_FILTER=y
CONFIG_UNIX=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_RTNETLINK=y
CONFIG_NETLINK=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_FWMARK=y
CONFIG_IP_ROUTE_NAT=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_TOS=y
CONFIG_IP_ROUTE_VERBOSE=y
# CONFIG_IP_ROUTE_LARGE_TABLES is not set
# CONFIG_IP_PNP is not set
CONFIG_NET_IPIP=y
CONFIG_NET_IPGRE=y
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE=y
# CONFIG_IP_PIMSM_V1 is not set
# CONFIG_IP_PIMSM_V2 is not set
CONFIG_ARPD=y
# CONFIG_INET_ECN is not set
CONFIG_SYN_COOKIES=y
# IP: Netfilter Configuration
CONFIG_IP_NF_CONNTRACK=y
CONFIG_IP_NF_FTP=y
CONFIG_IP_NF_IRC=y
CONFIG_IP_NF_EGG=y
# CONFIG_IP_NF_CTNETLINK is not set
CONFIG_IP_NF_QUEUE=y
CONFIG_IP_NF_IPTABLES=y
CONFIG_IP_NF_MATCH_LIMIT=y
CONFIG_IP_NF_POOL=y
CONFIG_IP_POOL_STATISTICS=y
CONFIG_IP_NF_MATCH_MAC=y
CONFIG_IP_NF_MATCH_PKTTYPE=y
CONFIG_IP_NF_MATCH_MARK=y
CONFIG_IP_NF_MATCH_MULTIPORT=y
CONFIG_IP_NF_MATCH_MPORT=y
CONFIG_IP_NF_MATCH_TOS=y
CONFIG_IP_NF_MATCH_TTL=y
CONFIG_IP_NF_MATCH_TIME=y
CONFIG_IP_NF_MATCH_PSD=y
CONFIG_IP_NF_MATCH_NTH=y
CONFIG_IP_NF_MATCH_LENGTH=y
CONFIG_IP_NF_MATCH_IPV4OPTIONS=y
CONFIG_IP_NF_MATCH_AH_ESP=y
CONFIG_IP_NF_MATCH_TCPMSS=y
CONFIG_IP_NF_MATCH_REALM=y
CONFIG_IP_NF_MATCH_STATE=y
CONFIG_IP_NF_MATCH_RPC=y
CONFIG_IP_NF_MATCH_IPLIMIT=y
CONFIG_IP_NF_MATCH_UNCLEAN=y
CONFIG_IP_NF_MATCH_STRING=y
CONFIG_IP_NF_MATCH_OWNER=y
CONFIG_IP_NF_FILTER=y
CONFIG_IP_NF_TARGET_REJECT=y
CONFIG_IP_NF_TARGET_NETLINK=y
CONFIG_IP_NF_TARGET_MIRROR=y
CONFIG_IP_NF_NAT=y
CONFIG_IP_NF_NAT_NEEDED=y
CONFIG_IP_NF_TARGET_MASQUERADE=y
CONFIG_IP_NF_TARGET_REDIRECT=y
CONFIG_IP_NF_NAT_SNMP_BASIC=y
CONFIG_IP_NF_NAT_IRC=y
CONFIG_IP_NF_TARGET_SAME=y
CONFIG_IP_NF_TARGET_NETMAP=y
CONFIG_IP_NF_NAT_FTP=y
CONFIG_IP_NF_MANGLE=y
CONFIG_IP_NF_TARGET_TOS=y
CONFIG_IP_NF_TARGET_FTOS=y
CONFIG_IP_NF_TARGET_MARK=y
CONFIG_IP_NF_TARGET_LOG=y
CONFIG_IP_NF_DROPTABLE=y
CONFIG_IP_NF_TARGET_TTL=y
CONFIG_IP_NF_TARGET_TCPMSS=y
# CONFIG_IPV6 is not set
# CONFIG_KHTTPD is not set
# CONFIG_ATM is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_DECNET is not set
# CONFIG_BRIDGE is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_LLC is not set
# CONFIG_NET_DIVERT is not set
# CONFIG_ECONET is not set
CONFIG_WAN_ROUTER=m
# CONFIG_NET_FASTROUTE is not set
# CONFIG_NET_HW_FLOWCONTROL is not set
# Network device support
CONFIG_NETDEVICES=y
# ARCnet devices
# CONFIG_ARCNET is not set
CONFIG_DUMMY=m
CONFIG_BONDING=m
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# CONFIG_ETHERTAP is not set
# CONFIG_NET_SB1000 is not set
# Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
# CONFIG_ARM_AM79C961A is not set
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
CONFIG_NET_VENDOR_3COM=y
# CONFIG_EL1 is not set
# CONFIG_EL2 is not set
# CONFIG_ELPLUS is not set
# CONFIG_EL16 is not set
# CONFIG_EL3 is not set
# CONFIG_3C515 is not set
CONFIG_VORTEX=m
# CONFIG_LANCE is not set
# CONFIG_NET_VENDOR_SMC is not set
# CONFIG_NET_VENDOR_RACAL is not set
# CONFIG_AT1700 is not set
# CONFIG_DEPCA is not set
# CONFIG_HP100 is not set
# CONFIG_NET_ISA is not set
CONFIG_NET_PCI=y
# CONFIG_PCNET32 is not set
# CONFIG_ADAPTEC_STARFIRE is not set
# CONFIG_AC3200 is not set
# CONFIG_APRICOT is not set
# CONFIG_CS89x0 is not set
# CONFIG_TULIP is not set
# CONFIG_DE4X5 is not set
# CONFIG_DGRS is not set
# CONFIG_DM9102 is not set
CONFIG_EEPRO100=m
# CONFIG_FEALNX is not set
# CONFIG_NATSEMI is not set
# CONFIG_NE2K_PCI is not set
# CONFIG_8139TOO is not set
# CONFIG_SIS900 is not set
# CONFIG_EPIC100 is not set
# CONFIG_SUNDANCE is not set
# CONFIG_TLAN is not set
# CONFIG_VIA_RHINE is not set
# CONFIG_WINBOND_840 is not set
# CONFIG_NET_POCKET is not set
# Ethernet (1000 Mbit)
# CONFIG_ACENIC is not set
# CONFIG_DL2K is not set
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
# CONFIG_SK98LIN is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
# CONFIG_PLIP is not set
CONFIG_PPP=m
# CONFIG_PPP_MULTILINK is not set
# CONFIG_PPP_FILTER is not set
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPPOE=m
# CONFIG_SLIP is not set
CONFIG_MODULES=y
CONFIG_KMOD=y
CONFIG_PACKET=y
CONFIG_NETLINK=y
CONFIG_RTNETLINK=y
CONFIG_NETFILTER=y
CONFIG_FILTER=y
CONFIG_UNIX=y
CONFIG_INET=y
CONFIG_RTNETLINK=y
CONFIG_NETLINK=y
CONFIG_NET_IPIP=y
CONFIG_NET_IPGRE=y
CONFIG_IP_MROUTE=y
CONFIG_ARPD=y
CONFIG_IP_NF_FTP=y
CONFIG_IP_NF_IRC=y
CONFIG_IP_NF_EGG=y
CONFIG_IP_NF_POOL=y
CONFIG_IP_NF_NAT=y
CONFIG_WAN_ROUTER=m
CONFIG_NETDEVICES=y
# ARCnet devices
CONFIG_DUMMY=m
CONFIG_BONDING=m
CONFIG_VORTEX=m
CONFIG_NET_PCI=y
CONFIG_EEPRO100=m
CONFIG_PPP=m
CONFIG_PPP_ASYNC=m
CONFIG_PPPOE=m
ik heb het probleem ontdekt...
De iptables-installatie (versie 1.2.3) hebben sommige netlink sources kapot-gepatched. ik kon de *.c.orig bestanden terugzetten naar *.c of gewoon het herinstallatie kernel 2.4.9...
