mpg > DivX ?
  • 105 views sinds 30-01-2008
  • 0 Henk 'm!
kan je dat converteren? zo ja hoe?
  • 0 Henk 'm!
  • Unknown
zoiets denk ik
How to Rip from DVD to MPEG4 (DiVX) -
_____________________________________
Step 1 - The necessary tools
______
You will need - DeCSS
Mpeg2AVi
DiVX Codecs
VOB Snoopy
AC3ED
AudioActive Production Studio
External L3ENC codecs
Get all of this stuff BEFORE you begin.
Step 2 - Ripping the MPEG
______
1. Load DeCSS, it will auto-detect your DVDROM and DVD
2. Select ALL the Vob files available, and merge them into one.
3. Put it in a directory (e.g. C:\Ripped) call it 01.vob
4. Make sure you have at least the same amount of space free as the new VOB file takes up, converting it to mpeg and ripping the sound will take up lots of space.
Step 3 - Converting MPEG to DivX AVI
______
1. Open a DOS Box
2. Copy your mpeg2avi into your C:\Ripped
3. Figure out if your DVD is NTSC or PAL (it'll say on the cover, so if you can't read you're fucked)
4. Enter the following command line -
PAL - mpeg2avi -b C:\ripped\01.vob -f - 1 720 480 -07 output.avi
NTSC - mpeg2avi -b C:\ripped\01.vob -f0 -3y 416 - 1 720 320 output.avi
5. At the prompt select the DiVX Codec.
6. Change the KEY to 1
7. Leave everything else at its defaults
You've got your moving pictures.
Step 4 - Converting the Sound
______
1. Load VobSnoopy and click on your VOB file
2. Click extract and select *m2a,*mpa,*ac3,*wav
3. Wait for the fucker to extract to C:\ripped
4. Open a DOS box again, and copy AC3ED to C:\ripped
5. Type in - AC3ed audio01.ac3 sound.wav
6. Leave the codec as default
7. Load up Virtual DUB (part of Audioactive Pro. Studio)
8. Select the wav, and convert it using the following information -
Audio conversion 44100 or 48000 depending on format of the wav
Audio Interleaving Preload 10 000 ms
Interleave audio every 250
Audio Wav Audio (select the wav)
AudioFull processing mode
Audio Compression Format Mpeg Layer 3
Attribute : 96 Kbit/s 44,100 ou 44,800, Stereo
Wow, a new bigass MP3.
Step 5 - Merging the sound and video
______
1. Load virtual dub again
2. Open your AVI
3. Copy the Video Frame Rate
4. Click Change so the video duration matches the Audio
5. Click on 44100hz Audio
Interleaving Preload 10000ms
Interleave Audio every 250
Audio WAV Audio
6. After that, click on your WAV and select Full Processing Made, FileSave Extended AVI.
7. Put in whatever filename you want
You should now have your working DiVX. w00p!
  • 0 Henk 'm!
  • zetje01
  • Registratie: Augustus 1999
  • Laatst online: 15:00
ah, da's duidelijk. Ik ga het ff proberen...
edit: het is gelukt hoor!
[ Voor 33% gewijzigd door zetje01 op 06-11-2005 19:03 ]
