  • Alexandros0124
  • Laatst online: 11-08-2024
Hi,
with Gigabyte Z790 AORUS ELITE AX can I use internal graphics and graphics from the card at the same time ?
I need to use 2 ports from the graphic card and one port from the internal graphic, for total 3 monitors.
note : I am not playing games so i don't need any high frame rates etc.
Feel free to reply in dutch.
Thanks
  • Majestici
  • Registratie: Juli 2013
  • Laatst online: 15-10 21:23
Depends on whether the CPU has an integrated GPU or not. If it does, I dont see why it wouldn't work.
But do note that they operate independently, so you can only run a videogame on either/or. You can't use the third screen to span it over 3 screens during gameplay for example.
If you provided a use-case (and your CPU), someone could give you a more definitive answer.
  • Alexandros0124
Thanks for the reply Majestici,
Planning to Combine Gigabyte Z790 AORUS ELITE AX with the I9 14900k.
For the graphic card i will reuse my old Asus GeForce ® GTX 1050 Ti, 4GB
