ACPI
dit zal vast wel een domme vraag zijn maar ja ik ben ook maar een newbie :9~ maar wat is een ACPI?
ASPI?
  • DarkSide
  • Laatst online: 09-09 17:25
DarkSide
theres no place like ::1
Advanced Configuration and Power Interface (ACPI) is an open industry specification that defines a flexible and extensible hardware interface for the system board. Software designers use this specification to integrate power management features throughout a computer system, including hardware, the operating system and application software. This integration enables Windows 2000 to determine which applications are active and handle all of the power management resources for computer subsystems and peripherals.
ACPI enables the operating system to direct power management on a wide range of mobile, desktop and server computers and peripherals.
ACPI is the foundation for the OnNow industry initiative that allows system manufacturers to deliver computers that will start at the touch of a key on a keyboard.
ACPI design is essential to take full advantage of power management and Plug and Play in Windows 2000. If you are not sure if your computer is ACPI-compliant, check your manufacturer's documentation. To change power settings that take advantage of ACPI, use Power Options in Control Panel.
