MSSQL importeren csv problemen
  • Stefke
  • Laatst online: 28-10 10:40
Ik moet csv files importeren in SQL server. Om de een of andere reden heb ik daar altijd ruzie mee. Ogenschijnlijk zijn de T-sql instructies daarvoor niet zo complex, maar bij mij wil het nooit zo maar werken.
Dit is de CSV file die ik moet importeren:
ExportDate;AdminNo;RelNo;InvoiceNo;ItemType;InternalNmbr;InvoiceDate;InvoiceDueDate;DaysTerm;Description;CurrencyCode;OriginalAmount;PaidAmount;OpenAmount;VATAmount;VatPercentage;BaseCurrencyCode;BaseOriginalAmount;BaseOpenAmount;BaseVatAmount;Factor
"2023-12-08 23:30:54";"BLABLA";"477180186";"13723FACLI1205632";"VENTE";"";"2023-12-08";"2024-02-06";"60";"";"EUR";"66271.36";"0.0";"66271.36";"";"";"EUR";"66271.36";"66271.36";"0";"1"
17 kolommen (factuurdata)
IF OBJECT_ID('TEMPDB..#StagingTableDebtors') IS NOT NULL DROP TABLE #StagingTableDebtors;
CREATE TABLE #StagingTableDebtors (
    ExportDate          nvarchar(100) NULL,     --1
    AdminNo             nvarchar(100) NULL,     --2
    RelNo               nvarchar(100) NULL,     --3
    CompanyName         nvarchar(100) NULL,     --4
    Street              nvarchar(300) NULL,     --5
    Street_2            nvarchar(300) NULL,     --6
    Street_3            nvarchar(300) NULL,     --7
    Zipcode             nvarchar(50) NULL,      --8
    City                nvarchar(50) NULL,      --9
    CountryCode         nvarchar(2) NULL,       --10
    PostalStreet        nvarchar(300) NULL,     --11
    PostalStreet_2      nvarchar(300) NULL,     --12
    PostalStreet_3      nvarchar(300) NULL,     --13
    PostalZipCode       nvarchar(50) NULL,      --14
    PostalCity          nvarchar(50) NULL,      --15
    PostalCountryCode   nvarchar(2) NULL,       --16
    CreditorAmount      nvarchar(100) NULL      --17 --decimal(15, 2) NOT NULL
INSERT INTO #StagingTableDebtors
SELECT *
FROM OPENROWSET(
   BULK 'D:\Data\TST\BLABLA\out_Customers_20231208.csv',
   FORMATFILE = 'D:\Data\DBasics\csv_file_import_set.fmt',
   FIRSTROW = 2
) AS Data;
DIt is de formatfile:
1 SQLCHAR   0   100     ";"     1   ExportDate
2 SQLCHAR   0   100     ";"     2   AdminNo
3 SQLCHAR   0   100     ";"     3   RelNo
4 SQLCHAR   0   100     ";"     4   CompanyName
5 SQLCHAR   0   300     ";"     5   Street
6 SQLCHAR   0   300     ";"     6   Street_2
7 SQLCHAR   0   300     ";"     7   Street_3
8 SQLCHAR   0   50      ";"     8   Zipcode
9 SQLCHAR   0   50      ";"     9   City
10 SQLCHAR  0   2       ";"     10  CountryCode
11 SQLCHAR  0   300     ";"     11  PostalStreet
12 SQLCHAR  0   300     ";"     12  PostalStreet_2
13 SQLCHAR  0   300     ";"     13  PostalStreet_3
14 SQLCHAR  0   50      ";"     14  PostalZipCode
15 SQLCHAR  0   50      ";"     15  PostalCity
16 SQLCHAR  0   2       ";"     16  PostalCountryCode
17 SQLCHAR  0   100     "\n"   17  CreditorAmount
Helaas krijg ik deze foutmelding:
Msg 4823, Level 16, State 1, Line 87
Cannot bulk load. Invalid column number in the format file "D:\Data\csv_file_import_set.fmt"
Ik heb de kolommen in de code en de formatfile geknipt/geplakt om fouten te voorkomen, ik heb ze genummerd om telfouten te voorkomen, maar ik blijf deze fout krijgen.
Als ik de CSV file in Visual Studio Code open dan zie ik UTF-8 en LF aangegeven staan, dus volgens mij is "\n" correct als line terminator. "\r\n" werkt iig ook niet.
Ik heb het idee dat de fout iets anders is maar de melding verkeerd?
Al tientallen pagina's bekeken, videoinstructies op youtube, ChatGPT geraadpleegd. Ik kom er niet uit.
Vervolgens dit gemaakt (CSV, formatfile en TSQL) als testsetup
ExportDate;Column2
"bla";"test"
"bla2";"test2"
14.0
2 SQLCHAR   0   100     "\n"     2   Column2
    Column2             nvarchar(100) NULL,
SELECT *
FROM OPENROWSET(
   BULK 'C:\temp\test.csv',
   FORMATFILE = 'C:\temp\test.fmt',
   FIRSTROW = 2
) AS Data;
maar dezelfde foutmelding. Iemand een idee wat ik verkeerd doe? Ik kijk vast over iets heel stoms heen.
[ Voor 3% gewijzigd door Stefke op 10-12-2023 13:34 ]
Beste antwoord (via Stefke op 11-12-2023 17:36)
  • LuukRuyter
  • Laatst online: 27-10 15:18
Voor je test file mis je volgens mij zowel de collation als de new row.
Text qualifiers via bulk insert is ook wel een uitdaging
1 SQLCHAR   0   100     ";"        1   ExportDate    SQL_Latin1_General_CP1_CI_AS
2 SQLCHAR   0   100     "\r\n"     2   Column2       SQL_Latin1_General_CP1_CI_AS
  • Crazy D
  • Laatst online: 18:03
Crazy D
Heb je een enter gegeven na de laatste regel in je format file?
Exact expert nodig?
  • Voutloos
En mag je de column collation eigenlijk wel weglaten in de formatfile?
{signature}
  • Merethil
  • Laatst online: 18:41
Kan het zijn dat je csv row terminator "\r\n" is ipv "\n"? Als ie dan aan het einde van je regel komt en niet de juiste row terminator tegenkomt wil hij waarschijnlijk domweg kolom 18 gaan bepalen en die heb je (logischerwijs) niet.
  • Stefke
Crazy D schreef op zondag 10 december 2023 @ 13:55:
Die was er niet, net toegevoegd maar ik krijg dezelfde foutmelding
Voutloos schreef op zondag 10 december 2023 @ 13:58:
Ik heb collation toegevoegd, nu krijg ik deze fout
Msg 213, Level 16, State 1, Line 52
Column name or number of supplied values does not match table definition.
1 SQLCHAR   0   100     ";"     1   ExportDate  SQL_Latin1_General_CP1_CI_AI
2 SQLCHAR   0   100     "\n"  2   Column2     SQL_Latin1_General_CP1_CI_AI
Merethil schreef op zondag 10 december 2023 @ 15:03:
Beide geprobeerd, maar dan ook de melding m.b.t. het aantal kolommen. Ook in combinatie met de 2 bovenstaande aanpassingen (al krijg ik met collation dus een iets andere foutmelding)
  • MatHack
MatHack
Dev by day, Gamer by night
Moet de laatste niet "\r\n" zijn ipv "\n"? Ik neem aan dat dit vanaf een Windows machine gebeurd.
There's no place like 127.0.0.1
  • ocwil
  • Laatst online: 26-10 16:32
Probeer eens SQLVARCHAR en een lengte van 0 inplaats van 100 in de Format file?
~ Portal 2 maps: linkje ~ LoL (EUW): Ocwil ~
  • Stefke
MatHack schreef op maandag 11 december 2023 @ 11:52:
WIndows inderdaad, maar \r\n of \n maakt geen verschil
ocwil schreef op maandag 11 december 2023 @ 12:03:
Dat geeft deze fout:
Msg 4824, Level 16, State 1, Line 52
Cannot bulk load. Invalid data type for column number 1 in the format file "C:\temp\test.fmt".
Als ik de 2e kolom SQLVARCHAR maak en de eerste SQLCHAR krijg ik de melding op de 2e kolom
https://learn.microsoft.c...ver?view=sql-server-ver16
Als ik hier kijk, dan maken ze een csv file zonder kolomheaders. Moet ik nog ergens aangeven dat de 1e rij kolomheaders zijn misschien? Ik zie dit niet terug in de instructies op deze pagina
[ Voor 19% gewijzigd door Stefke op 11-12-2023 13:01 ]
  • LuukRuyter
Wellicht dat je de "import and export Data" wizzard is kan draaien om het handmatig met 1 file te proberen.
Op die manier kan je ieder geval is testen of het inlezen goed werkt.
Dit zit praktische altijd standaard mee geïnstalleerd bij de SQL server installatie.
Afbeeldingslocatie: https://tweakers.net/i/p3Oi2N1Flo3Z9gxHHLL5dyk-kcY=/800x/filters:strip_exif()/f/image/xLpmO59T0ErdtmmuwoSruvXW.png?f=fotoalbum_large
  • Stefke
Dat zal ik straks even doen (nu niet in de gelegenheid), maar het gaat nu om mijn testfile van 2 kolommen en 2 records, zie boven. Zelfs dat krijg ik niet geimporteerd
  • Beste antwoord ✓
  • LuukRuyter
  • Stefke
Met jouw versie krijg ik een andere maar soortgelijke foutmelding:
Wat zou "number of supplied values" kunnen betekenen? Klinkt alsof het gaat over de data, mijn 2 records in de test-csv?
Je laatste opmerking snap ik niet helemaal?
[ Voor 20% gewijzigd door Stefke op 11-12-2023 16:27 ]
  • LuukRuyter
Hij wil nog verplicht een enter na lijn 4:
Afbeeldingslocatie: https://tweakers.net/i/UGZNCjah2fry3QGt9d7dMYdK6Rg=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/cBqwDAe0XMjLA7LZjhKFYlW2.png?f=user_large
Edit: De code viewer van Tweakers haalt automatisch lege regels weg.
Flatfiles zijn de grootste rotzakken die er zijn.
Volgens mij is het niet mogelijk om via Bulk Insert ook velden met tekst als tekst te zien.
Je kan geen text qualifiers aangeven zoals ".
Hij zal "bla" dus ook letterlijk als "bla" inlezen en niet als bla.
[ Voor 41% gewijzigd door LuukRuyter op 11-12-2023 16:41 ]
  • Stefke
Ik ben er uit, maar wat het probleem nou was weet ik niet.
Ik had een nieuwe test-csv gemaakt met Excel. Die kwam met een bestand zonder " en , als scheidingsteken. Daar de test-formatfile op aangepast en die werd ingelezen.
Toen weer omgezet naar ; en met ", die werd ook ingelezen :?
Vervolgens de oude test-csv aangepast, en die wordt nu ook ingelezen, terwijl er volgens mij niets anders is... Op één parameter na
format='CSV'
Die zag ik nog staan in een youtubeinstructie
Nu de klantfile nog eens bekeken; volgens notepad++ toch echt een CRLF als rowterminator. Nog eens alles nagelopen en nu wordt ook de klantfile geimporteerd.
Blijkbaar was de format='CSV' nodig, zonder doet ie het niet
29
30
    ExportDate          datetime NULL,          --1
    CreditorAmount      nvarchar(100) NULL      --17--decimal(15, 2) NOT NULL
SELECT *
FROM OPENROWSET(
   BULK 'D:\Data\DBasics\TST\COFEL\COFEL_137\out_Customers_20231208.csv'
   ,FORMATFILE = 'C:\temp\csv_file_import_set.fmt'
   ,FIRSTROW = 2
   ,FORMAT='CSV'
) AS Data;
Laat ik die formatparameter weg dan krijg ik deze meldingen:
Bulk load data conversion error (type mismatch or invalid character for the specified codepage) for row 2, column 1 (ExportDate).
Mogelijk op een andere manier op te lossen, maar het werkt zo iig eindelijk...
Verder was de functie in Notepad++ die de tekens weergeeft nieuw voor mij :) achteraf logisch dat dit kan met Notepad.
Ben er nu wel achter dat de klant niet alle files met dezelfde rowterminator aanlevert... handig :') (wisselend LF en CRLF)
edit: ik weet het wel :
Deze fout slaat op de tijdelijke SQL-tabel: ondanks dat ik die elke keer verwijder voor het aanmaken raakt SQL server toch op de een of andere manier in de war. De import zal waarschijnlijk wel gelukt zijn al een paar keer, maar ergens ging dus wat fout met de SQL-tabel.
@LuukRuyter En je had gelijk over de ", die wordt geimporteerd als tekst. Maar als ik de parameter format='CSV' gebruik dan wordt de " niet geimporteerd
Het werkt nu, bedankt voor t meedenken
[ Voor 10% gewijzigd door Stefke op 11-12-2023 17:36 ]
