Python Key error
  • klump4u
klump4u
Full electric in Zuid-Limburg
Ik draai op een raspberri pi 4 maal het onderstaande python script, allemaal op een andere gpio pin.
Nu wil ik dit scipt nogmaals erbij doen op een andere pin en krijg ik steeds de volgende foutmelding,
  File "kwhP.py", line 94, in <module>
    main()
  File "kwhP.py", line 55, in main
    ELEC_COUNTER = int(float(res['result'][0]['Data'][:-4]) * 1000)
KeyError: 'result'
Wat gaat nu fout?
Python:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
#!/usr/bin/env python
import time
import json
import urllib2
import threading
import logging
import logging.handlers
import os
from gpiozero import DigitalInputDevice
GET_URL = 'http://192.168.0.20:8080/json.htm?type=devices&rid=%d'
SET_URL = 'http://192.168.0.20:8080/json.htm?type=command&param=udevice&idx=%d&svalue=%d'
ELEC_DELTA = 0
ELEC_IDX = 83
ELEC_GPIO = 27
ELEC_COUNTER_LOCK = threading.Lock()
ELEC_LAST_TIME = 0
ELEC_POST_TIME = 0
def elec_intr():
    tme = time.time()
    global ELEC_DELTA
    global ELEC_LAST_TIME
    global ELEC_POST_TIME
    with ELEC_COUNTER_LOCK:
        ELEC_LAST_TIME = tme
        if ELEC_POST_TIME == 0:
            ELEC_POST_TIME = ELEC_LAST_TIME
        else:
            ELEC_DELTA += 0.5
    logging.debug( 'Electricity counter tick: %d' % ELEC_DELTA )
def main():
    global ELEC_DELTA
    global ELEC_COUNTER
    syslog = logging.handlers.SysLogHandler(address='/dev/log', facility='local1')
    syslog.setFormatter(logging.Formatter('local_sensors.py: %(levelname)s %(message)s'))
    logging.getLogger().addHandler(syslog)
    logging.getLogger().setLevel(logging.INFO)
    while True:
        try:
            res = json.load(urllib2.urlopen(GET_URL % ELEC_IDX))
            if res['status'] != 'OK':
                raise Exception('Domoticz json error')
            break
        except Exception as e:
            logging.warning( e )
        time.sleep(30.0)
#    ELEC_COUNTER = <Your initial count here * 1000, don't forget to remove after Domoticz updated!>
    logging.info( 'Current electricity counter is: %d' % ELEC_COUNTER )
    elecSensor = DigitalInputDevice(ELEC_GPIO, pull_up=True)
    elecSensor.when_deactivated = elec_intr
    os.nice(-20)
    logging.info('Polling loop starting')
    while True:
        time.sleep(60)
            if ELEC_LAST_TIME > ELEC_POST_TIME:
                ELEC_LOAD = ELEC_DELTA * 3600 / ( ELEC_LAST_TIME - ELEC_POST_TIME )
            else:
                ELEC_LOAD = 0
            ELEC_COUNTER += ELEC_DELTA
            ELEC_DELTA = 0
            ELEC_ZERO = 0
        if ELEC_LOAD != 0:
                res = json.load(urllib2.urlopen((SET_URL+';%d') % (ELEC_IDX, int(ELEC_LOAD), ELEC_COUNTER)))
                logging.info('Elec load %.2f counter %d' % (ELEC_LOAD, ELEC_COUNTER) )
        if ELEC_LOAD == 0:
if __name__=="__main__":
    main(
Beste antwoord (via klump4u op 09-12-2023 20:46)
  • Webgnome
  • Laatst online: 20:17
Assumption is the mother of all... Meten is weten. Simpele log regel toevoegen met de inhoud en je weet het zeker
[ Voor 53% gewijzigd door Webgnome op 09-12-2023 19:46 ]
Strava | AP | IP | AW | SM
  • Illusion
  • Laatst online: 23:10
Illusion
(the art of)
Je variable res heeft geen key met de naam ‘result’
Kijk eens in de faq bij de tips voor zelf debuggen: Softwareontwikkeling FAQ - Algemeen
  • klump4u
klump4u
Illusion schreef op zaterdag 9 december 2023 @ 18:06:
Ik heb dat doorgelezen maar kom er niet wijs uit, ik snap niet dat de andere scripts wel werken en deze niet.
Geef ik in de code een beginwaarde door dan krijg ik geen melding en wordt die waarde netjes geupload naar domoticz, haal ik dan de # weg voor de betreffende regel dan krijg ik weer die foutmelding
  • Creepy
Creepy
Tactical Espionage Splatterer
Je res variable bestaat daar nog helemaal niet. Waar had die res variabele vandaan moeten komen?
Of wel, want scope en Python.. affijn. Dus of dat of res bevat gewoon niet wat je denkt, wat illusion ook al zegt.
[ Voor 39% gewijzigd door Creepy op 09-12-2023 19:36 ]
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
  • Webgnome
@klump4u wat is de inhoud van 'res'?
  • klump4u
klump4u
Ik neem aan de stand van de counter.
  • Beste antwoord ✓
  • Webgnome
  • klump4u
klump4u
Ik heb alles verwijdert, pi opnieuw gereboot en toen weer script toegevoegd en nu doet hij het.
Ik maar een beginner en moet het vaak hebben van knippen en plakken maar ik kan weer vooruit.
Ooit zal dit ook nog eens naar python3 moeten.
