Nee, jammer genoeg is dat het niet. Die twee filetjes bestaan helemaal niet. Andere ideeen??
Voor als het nodig is is hier mijn config:
FREESCO v0.2.7 System Report. Generated - Thu Sep 06 18:40:43 2001
----- clock -----
Thu Sep 6 18:40:44 2001
----- cat /etc/system.cfg -----
# [System]
ROUTER=ethernet# 0.dialup/leased/ethernet/bridge
HOSTNAME=local2#711.Router name
DOMAIN=localdomain#712.(Local) domain name
ENAMSQ=n # 11.Enable NAT and firewall
ENABRG=n # 12.Enable bridging mode? DONT TOUCH!!!
BIGMEM=y # 13.If 16+MB RAM start ppp bsd compression
SAVERS=0,0 # 14.Savers - screen(min),hdd(x5 sec) 0 -off
SWPSIZE=32# 15.Swap size in Kb on boot device. 0 - off
LOGSIZE=50000,5000# 16.System_log,logins_log sizes (bytes)
DEFISP=# 6.Default dialup ISP
# [Services] # y - worldwide/s - local/n - disable
ENADNS=n #411.Enable caching DNS server
LOGDNS=n#412.Enable debug info
ENADHCP=n #421.Enable DHCP server
WINSADDR=#422.WINS address (for DHCP server)
LIZTIME=604800,604800#423.default-lease-time,max-lease-time
ENAWWW=s #431.Enable Public HTTP Server
WWWPORT=81 #432.on port
ENAWWA=s #441.Enable Time Server and control via HTTP
WWAPORT=82 #442.on port
TIMADDR=#443.Host timeserver address, empty - disable
TIMZONE=+0100#444.Offset to UTC (-1200 -:- +1200)
ENALPD=s #451.Enable Print Server
LPPORT1=515#452.on port
LPDEV1=lp1#453.on output device
LPPORT2=#454.Second lp server on port, empty - disable
LPDEV2=lp2#455.on output device
ENATEL=s# 46.Enable telnet server
# [Security]
TRUSTLN=p #211.Trust local nets y/n/p{artual}
TRUSTMD=y#212.Modem links have access to local networks
RINGS=0#220.Rings before answer at login,nologin time
MonTIM=""#221.Nologin times for modem users
TueTIM=""#222
WedTIM=""#223
ThuTIM=""#224
FriTIM=""#225
SatTIM=""#226
SunTIM=""#227
# [Modems]
MODEM0= # 51.1st modem
MSPEED0=# 52.port's speed
MINIT0=""# 53.init string
MTU0=#541.Maximum Transmit Unit
MRU0=#542.Maximum Receive Unit
MADDR0=192.168.168.2# 55.ppp link remote addr (for dialin purpose)
MODEM1= # 61
MSPEED1=# 62
MINIT1=""# 63
MTU1=#641
MRU1=#642
MADDR1=192.168.168.3# 65.I said for dialin purpose.
# [leased line router]
ADRTYPE=dynamic #921.if ISP supplies us with dynamic IP, then:
LOCAL=127.0.0.2 #922.fake local side ppp IP addr
REMOTE=127.0.0.3 #923.fake remote addr
# [ethernet/leased/printer/ras router]
GATEWAY=10.1.1.5#911.Default gateway, if exist.
DNSADDR=10.1.1.5#912.Primary DNS address for ethernet connection
DNSADDR1=#913.Secondary DNS address for ethernet connection
PROXY=""#914.HTTP proxy addr[:port]
# [Hardware]
IO0=0x340#811.1st ethernet card I/O address
IRQ0=11#812.IRQ line
IO1=0#821
IRQ1=0#822
IO2=0#831
IRQ2=0#832
# [Networks]
USEDHCP0=n#720.Use DHCP client to config this interface
INTNAME0=eth0#721.Interface name (eth0|arc0e|arc0)
DHCPLOG=y#722.Enable DHCP client messages in the log
DHCPDNS=n#723 Enable auto configuration of DNS via DHCP
IPADDR0=10.1.1.2#724.IP adress of this interface
NETMASK0=255.255.255.0 #725.Network mask
NETWORK0=10.1.1.0# Network address
BRDCAST0=10.1.1.255# Broadcast address
#726.IP pool, empty disables DHCP on this interface
IPRANGE0=""
INTNAME1=eth1#731.Interface name (eth1|eth0:1|arc0e|arc0 etc)
IPADDR1=10.1.1.2#732. Second network
NETMASK1=255.255.255.0
NETWORK1=10.1.1.0
BRDCAST1=10.1.1.255
IPRANGE1=""
INTNAME2=#74x. Third network
IPADDR2=
NETMASK2=
NETWORK2=
BRDCAST2=
IPRANGE2=""
----- cat /etc/live.cfg -----
VER=0.2.7
bootdev=hda1
UPTIME="Thu Sep 6 18:10:26 2001"
DONE="echo Done"
----- cat /etc/dhcpc/dhcpcd-eth0.info -----
----- cat /etc/forward.cfg -----
#_47x._[Port_forwarding_AKA_export_services]
#_
#_tcp|udp,incoming_port,local_computer_IP_addr/port
#_
#_Example:_t,80,192.168.168.2/80
#_this_will_open_worldwide_web_server_on_local_computer_192.168.168.2
#_
#_Example:_t,21,192.168.168.3/21
#_this_will_open_worldwide_ftp_server_on_local_computer_192.168.168.2
#_
#_Comment_must_be_on_separate_line_start_with_"#_"_and_should_not_have_spaces
----- cat /etc/banlist.cfg -----
#_23._[List_of_banned_hosts/nets_one_record_per_line]
#_
#_local|external,IP_addr[/netmask_or_netbits_if_baning_a_whole_net]
#_
#_Example:_l,123.124.125.0/24_ban_local_net
#_Example:_e,123.124.125.0/255.255.255.0_ban_external_net
#_Example:_l,10.0.0.123_ban_local_host
#_
#_Comment_must_be_on_separat_lines_start_with_"#_"_and_should_not_have_spaces
----- sed -n 1,/AUTH/P /etc/chat.pwd -----
----- lsmod -----
ModulePagesUsed by
/tmp/prm/ne.o.A0 21
new_tunnel 10
ipip 10
ip_masq_ftp 10
ip_masq_irc 10
ip_masq_quake 10
ip_masq_vdolive 10
ip_masq_raudio 10
ip_masq_icq 10
ip_masq_cuseeme 10
8390 2[/tmp/prm/ne.o.A0]0
----- dmesg | grep eth -----
fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=22 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=23 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=24 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=211 S=0x00 I=25 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=26 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=27 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=211 S=0x00 I=28 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=29 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=30 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=211 S=0x00 I=31 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=211 S=0x00 I=32 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=223 S=0x00 I=33 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=223 S=0x00 I=34 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=223 S=0x00 I=35 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=223 S=0x00 I=36 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=37 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=38 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=39 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=40 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=41 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=42 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=43 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=44 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=45 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=46 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=47 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=211 S=0x00 I=48 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=211 S=0x00 I=49 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=241 S=0x00 I=50 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=51 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=52 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=53 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=54 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=55 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=56 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=57 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=58 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=59 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=96 S=0x00 I=60 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=61 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=229 S=0x00 I=62 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=229 S=0x00 I=63 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=241 S=0x00 I=64 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=241 S=0x00 I=299 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:138 10.1.1.255:138 L=202 S=0x00 I=338 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=340 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=341 F=0x0000 T=128
IP fw-in rej eth0 UDP 10.1.1.5:137 10.1.1.255:137 L=78 S=0x00 I=342 F=0x0000 T=128
----- ifconfig -----
lo Link encap:Local Loopback
inet addr:127.0.0.1 Bcast:127.255.255.255 Mask:255.0.0.0
UP BROADCAST LOOPBACK RUNNING MTU:3584 Metric:1
RX packets:13 errors:0 dropped:0 overruns:0
TX packets:13 errors:0 dropped:0 overruns:0
eth0 Link encap:10Mbps Ethernet HWaddr 00:00:B4:B3:4A:4E
inet addr:10.1.1.2 Bcast:10.1.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:309 errors:0 dropped:0 overruns:0
TX packets:222 errors:0 dropped:0 overruns:0
Interrupt:11 Base address:0x340
----- cat /proc/interrupts -----
0: 183794 timer
1: 162 keyboard
2: 0 cascade
8: 1 + rtc
11: 513 NE2000
13: 0 math error
14: 5635 + ide0
----- cat /proc/ioports -----
0000-001f : dma1
0020-003f : pic1
0040-005f : timer
0060-006f : keyboard
0070-007f : rtc
0080-009f : dma page reg
00a0-00bf : pic2
00c0-00df : dma2
00f0-00ff : npu
01f0-01f7 : ide0
02f8-02ff : serial(auto)
0340-035f : NE2000
0378-037f : lp
03c0-03df : vga+
03f0-03f5 : floppy
03f6-03f6 : ide0
03f7-03f7 : floppy DIR
03f8-03ff : serial(auto)
----- route -n -----
Kernel routing table
Destination Gateway Genmask Flags MSS Window Use Iface
255.255.255.255 * 255.255.255.255 UH 1500 0 0 eth0
10.1.1.0 * 255.255.255.0 U 1500 0 3 eth0
127.0.0.0 * 255.0.0.0 U 3584 0 1 lo
default 10.1.1.5 * UG 1500 0 2 eth0
----- cat /etc/dhcpd.leases -----
----- free -----
total: used: free: shared: buffers: cached:
Mem: 11014144 10551296 462848 7843840 3596288 2342912
Swap: 33550336 0 33550336
MemTotal: 10756 kB
MemFree: 452 kB
MemShared: 7660 kB
Buffers: 3512 kB
Cached: 2288 kB
SwapTotal: 32764 kB
SwapFree: 32764 kB
Mounted FS:
/dev/root / ext2 rw 0 0
/proc /proc proc rw 0 0
/dev/hda1 /mnt umsdos rw 0 0
Filesystem 1024-blocks Used Available Capacity Mounted on
/dev/ram0 2548 1540 1008 60% /
/dev/hda1 204960 47104 157856 23% /mnt
----- ps -----
PidStat ParentNameCommand
1 S0initinit
2 S1kflushd
3 S1kswapd
4 S1logrotatesh/bin/logrotate
6 S1syslogdsyslogd-r-h-m0
8 S1klogdklogd
19 S1daemonsh/bin/daemon-agetty 9600 tty2
24 S19agettyagetty9600tty2
214 S1lpdlpd-n1-p515-o/dev/lp1
217 S1thttpdthttpd-p82-uroot-d/wwa-l/dev/null
221 S1thttpdthttpd-p81-unobody-d/www-l/dev/null
224 S1daemonsh/bin/daemon-telnetd -debug
233 S1msql2d/mnt/router/packages/mSQL/bin/msql2d
237 S1nmbd/mnt/router/packages/smb/bin/nmbd-D
239 S1smbd/mnt/router/packages/smb/bin/smbd-D
253 S1daemonsh/bin/daemon-agetty 9600 tty1
255 S253ileile
268 S255shsh
295 S224telnetdtelnetd-debug
995 Z217usr.cgi
998 Z217usr.cgi
999 Z217usr.cgi
1002 Z217usr.cgi
1015 S4sleepsleep10
1016 S217usr.cgishusr.cgiinfo
1017 S1016thttpdthttpd-p82-uroot-d/wwa-l/dev/null
1018 S1016sysinfosh/bin/sysinfo
1019 S1016sedseds/</\<\;/g;s/>/\>\;/g
1046 R1018pssh/bin/ps
----- cat /etc/ppp/opt* -----
asyncmap 0
----- setserial -bg /dev/cua? -----
/dev/cua0 at 0x03f8 (irq = 4) is a 16550A
/dev/cua1 at 0x02f8 (irq = 3) is a 16550A
Ik doe niet aan sigs
