[Bind 9.1.0] Zone probleempjes
  • RoRoo
  • Registratie: Mei 2001
  • Laatst online: 02-06 14:20
RoRoo
Certified Prutser
Ik heb wat probleempjes met mijn nameserver.
soms werken de domeinen wel maar meestal niet. dit is heel irritant aangezien er flink bezocht en gemailed wordt naar sommige domeinen.
Ik zal mijn zonefile ff posten want ik snap er geen fluit meer van.
$ttl 86400
@          IN   SOA     ns.taononstop.com. webmaster.taononstop.com. (
                      2001090603 ; Serial
;                    21600   ; Refresh 6 hours
                      14400   ; Refresh 4 hours
;                    10800   ; Refresh 3 hours
                      3600    ; Retry   1 hour
                      604800 ; Expire  7 days
                      86400 ) ; Minimum 24 hours
taononstop.com.   IN    NS  ns.taononstop.com.
            IN  NS  ns.enigmavoice.com.
            IN  MX  50 smtp.gambitsplace.com.
            IN  A    xxx.xxx.xxx.xxx
localhost          IN   A    127.0.0.1
www            IN   A    xxx.xxx.xxx.xxx
ftp            IN   A    xxx.xxx.xxx.xxx
mail              IN    A    xxx.xxx.xxx.xxx
smtp              IN    A    xxx.xxx.xxx.xxx
pop3              IN    A    xxx.xxx.xxx.xxx
                IN  MX  50 mail.gambitsplace.com.
ns              IN  A    xxx.xxx.xxx.xxx
dolly            IN A    xxx.xxx.xxx.xxx
mijn named.conf
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
// generated by named-bootconf.pl
options {
      directory "/var/named";
       * If there is a firewall between you and nameservers you want
       * to talk to, you might need to uncomment the query-source
       * directive below.  Previous versions of BIND always asked
       * questions using port 53, but BIND 8.1 uses an unprivileged
       * port by default.
      // query-source address * port 53;
// a caching only nameserver config
zone "." IN {
      type hint;
      file "named.ca";
zone "localhost" IN {
      type master;
      file "localhost.zone";
      allow-update { none; };
zone "0.0.127.in-addr.arpa" IN {
      type master;
      file "named.local";
zone "0.0.10.IN-ADDR.ARPA"{
      type master;
      file "0.0.10.rev";
      notify yes;
#key "key" {
#    algorithm hmac-md5;
#     secret "AvMoDXpiYXwQjnLYlFsWhJanowwztFfrf0IkxRVZNwsEZBGiWWMeyhUGINDa";
zone "babeforce.com" in { type master; file "babeforce.com"; };
zone "gambitsplace.com" in { type master; file "gambitsplace.com"; };
zone "taononstop.com" in { type master; file "taononstop.com"; };
zone "nirvanadiscography.com" in { type master; file "nirvanadiscography.com"; };
zone "tattooshop-hilversum.nl" in { type master; file "tattooshop-hilversum.nl"; };
zone "saiyan-power.com" in { type master; file "saiyan-power.com"; };
zone "hiele-online.com" in { type master; file "hiele-online.com"; };
zone "bonesplace.com" in { type master; file "bonesplace.com"; };
zone "bikez-n-stuff.com" in { type master; file "bikez-n-stuff.com"; };
zone "rasputinfo.com" in { type master; file "rasputinfo.com"; };
zone "borismoose.com" in { type master; file "borismoose.com"; };
It's not DNS. There's no way it's DNS. It was DNS. --The Sysadmin haiku
  • RoRoo
RoRoo
Certified Prutser
Heeeeeldemaal niemand?? :(
demn..
O+ Pleaaase??? O+
  • [Yellow]
Volgens mij staat je TTL op een belachelijk hoge waarde. 86400 hops voordat een pakket niet meer geroet moet worden? Wil je Jupiter bereiken :* ?
In het volgende stukje staan volgens mij 2 IN A's
Verder begrijp ik dus dat jij de nameserver voor al die andere zone's bent? (En dus niet alleen een caching nameserver draait :) )
Tja TTL stat inderdaad aardig hoog, maar dat mag geen problemen geven.
Zo te zien verhoog je ook elke keer netjes het serial nummer.
Ik kan er eigenlijk geen foutje uithalen om eerlijk te zijn.
Wat geeft "rndc status" op dat moment of een directe dig opdracht op de server?
Gooi anders eens het debuglevel omhoog en kijk wat er in de logfiles verschijnt.
  • igmar
  • Laatst online: 09-09 19:53
igmar
ISO20022
Op donderdag 06 september 2001 18:00 schreef _Yellow_ het volgende:
Doe je huiswerk voordat je dit soort onzin uitkraamt. TTL is named heeft niks met de IP TTL te maken. TTL in named is de waarde die aangeeft hoelang de gecachde waarde geldig is. 86400 is de standaard waarde die ervoor gebruikt word.
  • igmar
igmar
ISO20022
Op donderdag 06 september 2001 10:47 schreef Kakarot het volgende:
$ttl 86400
                      2001090603 ; Serial
;                    21600   ; Refresh 6
Haal die ; weg, ze kunnen problemen geven.
NSns.toanonstop.com.
IN ervoor mag geloof ik zelfs niet eens. Zeker weten doe ik het niet.
Ik zal morgen wel effe een zonecheck doen.
Op donderdag 06 september 2001 23:27 schreef igmar het volgende:
$ttl 86400
                      2001090603 ; Serial
;                    21600   ; Refresh 6
Zonecheck had ik ook al gedaan en die gaf aan dat alles OK was :)
Verder mag IN bij mijn weten nog steeds wel. De ";" geeft waarschijnlijk dus ook geen problemen, aangezien de zonecheck aangaf dat alles okee is. Hoewel ik ze er niet tussen zou zetten, om het in ieder geval uit te sluiten.
  • igmar
igmar
ISO20022
Ook een zonecheck op de secondary ? zou niet de eerste keer wezen dat die het probleem is :)
  • RoRoo
RoRoo
Certified Prutser
zou het ook aan de secondary kunnen liggen?? hmmmm is een server van een maatje van me winnt met simpleDNS..
ik zal es een nieuwe transfer initiaten..
