Humanity is acquiring all the right technology for all the wrong reasons.
Je bent in de war met de P4B, dit is het Pentium 4 bord van Asus met de i845(Brookdale) chipset van Intel met support voor SDRAM
LOL het is dus de P4B !
ja thnx had het al ontdekt stond verkeert bij me leverancier in de prijslijstOp dinsdag 04 september 2001 23:40 schreef TweakGuy het volgende:
kan dit ding overweg met de standaard boxed PIV coolersIntroduction
The P4B offers the ultimate in expandability and functionality. Built upon an ATX form factor, it features up to 3GB of SDRAM support, 6 PCI slots, 4 USB Ports, 1 AGP slot, SPDIF interface, smart card reader support and more. The P4B is ideal for home or office users who need a flexible motherboard for a wide range of work and entertainment applications.
Key Motherboard Features
Mainstream Memory Support
The P4B with the Intel Pentium 4 SDRAM chipset supports 3 DIMMs or up to 3GB of PC100/PC133 SDRAM, letting users experience today's most advanced Intel P4 technology without migrating to more expensive memory standards.
System Voice Warnings
A unique onboard speech IC chip and ASUS POST Reporter provides clear explanations of system errors for quick and easy optimization. The P4B also includes Winbond Voice Editor allowing users to add customized system voice warnings and multi-language support.
Advanced Media Support
Smart card reader support enables cutting-edge technology features such as increased security, authenticating online transactions, editing IC based information and more. Panasonic SD and Sony Memory Stick are also supported enabling enhanced storage portability.
Flexible Power Connectivity
The ASUS EZ Plug power connector lets you use your existing power supply and eliminates the need to buy a special ATX 12V power supply necessary to support your P4 CPU.
Personalized Boot Up Logos
Get rid of boring boot up screens. ASUS MyLogo personalizes and adds style to your system with customizable boot logos.
ASUS Value Added Features
Expandability
The P4B comes with 6 PCI slots, an AGP 4X slot, 2 external COM ports, 1 CNR, and 4 USB slots. Users can also connect the new ASUS iPanel? for convenient connectivity and system monitoring from the front panel.
Extreme Overclocking
ASUS P4B offers the most overclocking options available to maximize your system performance.
Easy DIP Switch or Jumperfree overclocking from BIOS
Flexible CPU Core Voltage Adjustments in 0.05V increments over defaults
Accurate 1MHz adjustments of system-bus-frequency up to 200MHz (i.e. front-side-bus up to 800MHz)
Adjustable VIO memory voltage
Adjustable FSB/PCI/MEM ratio
Rock-solid stability
ASUS Reliability
All ASUS motherboards are designed and tested to meet the highest quality standards. Responsive customer support and frequent BIOS and driver updates ensure that you're getting the fastest, most reliable performance- all the time. All ASUS motherboards are also backed by a 3-year limited warranty.
Comprehensive Software Bundle
All ASUS motherboards include a valuable software bundle of popular third party programs that enable you to enjoy the full capabilities of your ASUS product:
Trend Micro PC-cillin 2000 anti-virus program
ASUS ASUS PC Probe for system monitoring
Cyberlink PowerPlayer SE, Video Live Mail
Key Specification Summary*
Supports Intel Pentium 4 socket 478 processors
Intel Pentium 4 SDRAM chipset and ICH2 chipset
3 DIMMS slots for up to 3GB of PC100/PC133 SDRAM support
AC'97 audio
SPDIF out interface
6 PCI slots / 1 CNR slot
AGP 4X slot
ATA-100/66/33 support
4 USB ports
Ja, denk t wel, alleen je moet wel een socket 478 P4 scoren... geen 423, zoals meest gangbaar is tot nu toeOp dinsdag 04 september 2001 23:43 schreef Bamibal het volgende:
Edit: zie op prijslijst van onze leverancier dat de P4 1.9Ghz alleen s478 is, dus dat komt wel goed
Wel duur dingetje, 980,- inkoop
I know ik geloof zelf dat de 1,9 en 2,0GHz alleen in 478 leverbaar zijnOp dinsdag 04 september 2001 23:46 schreef DJSmiley het volgende:
Idd, zag ik ook op prijslijst, zie edit al bij postOp dinsdag 04 september 2001 23:47 schreef Bamibal het volgende:
