The DFI PA61
VIA Apollo Pro133 mainboard
Wednesday, December 15, 1999
The Features (continued)
Other features included with PA61 motherboard, include: Wake on LAN, Wake on Modem, Power on from the mouse/keyboard/alarm, USB connectors, Power Failure Recovery, PS/2 connectors, IRDA connectors, an SB-Link, and hardware monitoring of fan speeds, CPU temperature, and system voltages. An additional thermal sensor is also included with the package, and can be used to monitor the temperature of another element. This motherboard is meeting the PC99 color codes standards.
Below, a photo of the PA61 provides us with a nice view of its components;
Click here for the big image...
Note: Click here for detailed specifications.
Installation
More than ever, the installation procedure of this motherboard is as easy and simple as a kid game. As a fact, if you're going to use a PII processor, all you will have to do will be to install the board in the computer casing, plug all your hardware and peripherals, Power on the board and jump into the BIOS at boot-up to complete the settings.
The Software bundle
The only stuff that comes on the installation CD of this motherboard is: the 4-in-1 VIA drivers pack, the CD version of the users manual and the Hardware Doctor hardware monitoring utility.
Suite: the test results.
PA61
Chipset
VIA 693A/596B
CPU Socket
Slot 1
CPU Supported
Support 133MHz FSB
Pentium® III 533-733MHz/133MHz
Pentium® III 450-600MHz/100MHz
Pentium® II 350-450MHz/ 100MHz
Pentium® II 233-333MHz/ 66MHz
SEPP Celeron 266-433MHz /66MHz
Memory
3 DIMM sockets
max. 768MB (registered)
Supports PC 133 and ECC
PCI IDE
Dual PIO mode 3/4 EIDE channels up to 4 IDE devices
UltraDMA/66 transfer rate up to 66MB/sec
Super I/O
2 x NS16C550A compatible UARTs
1 x SPP/ECP/EPP parallel port
External Connectors
2 x USB, 2 x DB-9, 1x DB-25, 1x PS/2 Mouse, 1 x PS/2 Keyboard
Internal Connectors
1x IrDA, 2 x IDE, 1x Floppy, 1 x ATX power, 3 x fan, 1 x SB-Link, 1 x WOL
Power Management
ACPI and OS direct power management
Wake-on event: RTC/Modem/LAN/KB/Mouse
Hardware Monitor
System, processor temperature, voltage and fan speed
Expansion Slots
1 AGP slot
3 PCI slots
2 ISA slots
1 PCI/ISA slot
BIOS
Award / 2Mbit
Form Factors
ATX, 4 layers
30.48 cm x 17 cm
12.0 inch. x 6.7 inch.
