Idle temps soms naar 79-80c na restart windows 11.
  • Oggfish
  • Registratie: Maart 2020
  • Laatst online: 26-03-2025
Hi Tweakers
Ik had het bericht in het engels geschreven voor een ander forum maar ik post het eerst hier. Misschien heeft iemand een idee om dit op te lossen?
Hi guys, I have a weird cpu temp issue which occurs sometimes when I restart the computer. Normal idle temps are as low as 28/35c, but sometimes it runs idle at 70-85c after a restart.
System: 13900KF, grizzly contact frame, Asus Proart Z790 wifi, 128GB Kingston Fury DDR5 6000mhz (running at 5600mhz xmp2 stable), Asrock 6700xt, EK Nucleus Lux 360 AIO.
I carefully tweaked this system for optimal performance for my work. The things I did are:
1) Set Core Parking OFF with Parkcontrol app.
2) Set windows 11 power scheme to Ultimate performance
3) Setting Proc perf core parking, demote threshold, idle disable, idle promote threshold, max and minimum proc state to 100%.
4) Debloaded windows 11
5) Deactivate unused devices in device manager.
6) Enforced all cpu limits in asus bios to keep the wattage at 253w max. In tests it occured that removing limits did not help me a lot in speed, while temps/throttling increased.
7) Bios update to latest, vid driver to latest, full win11 updates and Mobo/chipset updates.
After these tweaks my latency problems where gone in Latency Mon. Before that I had latency spikes all over the place. Those spikes are a big no-no in real-time audio production. But I have those finally under control.
When I start windows 11, the chance is like 50/50 having the extreme high idle temps. Restarting windows does not always solve it. Turning off/on the computer helps most of the time. Then idle temps are back to normal and stay normal.
How is it possible that this temp problem does not occur every time but only half of the time? Where can I start to tackle this problem?
  • GarBaGe
  • Registratie: December 1999
  • Laatst online: 14:07
Waarom vind je dit een probleem?
Je zit nog veilig van de maximale temperatuur verwijderd, dus geen throttling.
Het is eerder onhandig, dat ie zegt dat ie idle is, maar dat is ie kennelijk niet.
Immers, als je proc 75 graden of warmer is, dan moet ie wel wat aan het doen zijn :)
Wellicht dat je "ultimate performance" powerscheme ervoor zorgt dat je processor heel snel opschakelt... wellicht ook bij taken waar dit helemaal niet nodig is?
  • Oggfish
GarBaGe schreef op maandag 26 juni 2023 @ 13:15:
Dat ie idle is blijkt uit Core temp monitor waar alle cores op 0 tot 4% bezigheid staan. Pc doet verder niks, geen app open. Zoveel mogelijk background tasks eruit gesloopt. Vandaar ik dit raar vind en niet wenselijk dat de cpu meteen 80c wordt, direct na opstarten windows. Dit kan toch niet een gebruikelijk gang van zaken zijn? Het feit dat hij het soms wel of niet doet zonder enig verschil in load, is op z`n minst een vreemde gang van zaken. Of hij is tussen de 29 en 35c OF hij vliegt meteen naar de 70-80c. Als het aan ultimate performance zou liggen, zou je toch altijd dat probleem moeten hebben?
[ Voor 7% gewijzigd door Oggfish op 26-06-2023 14:17 ]
  • GarBaGe
Als je CPU zo heet wordt, terwijl die idle is.
Is ie dan ook echt idle?
Kijk eens in Task Manager onder de tab Details en sorteer deze eens op CPU.
Dan zou "System Idle Process" bovenaan moeten staan met meer dan 90% CPU load.
Klopt dat?
  • Oggfish
Dat ga ik zo meteen checken zodra hij weer zo reageerd! thanks
  • Oggfish
In taskmanager details staat bij system idle process 99 onder cpu. Ik heb gewone core temps na 7 restarts en het probleem (nog) niet gehad. Bij core temp monitor staan de cores op 0/1% gebruik en tussen de 30 en 42c.
Zodra na restart de temp naar 80c vliegt dan check ik et nog een keer. Die 99 komt dat van die ultimate perf af met de core parking tweaks ik gedaan heb?
  • Oggfish
GarBaGe schreef op maandag 26 juni 2023 @ 14:21:
Klopt dat?
