[Xiaomi Redmi Note 12/Pro] Ervaringen & Discussie Overzicht Laatste deel
  • theduke1989
  • Laatst online: 23-11 03:26
Afbeeldingslocatie: https://tweakers.net/i/yYPRtElvNJxmkBgchou7wX41iKU=/800x/filters:strip_icc():strip_exif()/f/image/huWX34lI1x8OsLS6DVHj7sju.jpg?f=fotoalbum_largeAfbeeldingslocatie: https://tweakers.net/i/ONVmb8n7sKitLgFCH-BeP_AaOdk=/800x/filters:strip_icc():strip_exif()/f/image/6WUVkHnmiTlRzM2jzXV6vihm.jpg?f=fotoalbum_large
Specificaties
NETWORK
  • Technology
  • GSM / HSPA / LTE / 5G
LAUNCH
  • Announced: 2022, October 27
  • Status: Available. Released 2023, January 11
BODY
  • Dimensions: 165.9 x 76.2 x 8 mm (6.53 x 3.00 x 0.31 in)
  • Weight: 188 g (6.63 oz)
  • SIM: Hybrid Dual SIM (Nano-SIM, dual stand-by) IP53, dust and splash resistant
DISPLAY
  • Type: AMOLED, 120Hz, 1200 nits (peak)
  • Size: 6.67 inches, 107.4 cm2 (~85.0% screen-to-body ratio)
  • Resolution: 1080 x 2400 pixels, 20:9 ratio (~395 ppi density)
  • Protection: Corning Gorilla Glass 3
PLATFORM
  • OS: Android 12, MIUI 14 (International), MIUI 13 (India)
  • Chipset: Qualcomm SM4375 Snapdragon 4 Gen 1 (6 nm)
  • CPU: Octa-core (2x2.0 GHz Cortex-A78 & 6x1.8 GHz Cortex-A55)
  • GPU: Adreno 619
MEMORY
  • Card slot: microSDXC (uses shared SIM slot)
  • Internal: 128GB 4GB RAM, 128GB 6GB RAM, 256GB 8GB RAM UFS 2.2
MAIN CAMERA
  • Triple: 48 MP, f/1.8, (wide), PDAF 8 MP, f/2.2, 120˚ (ultrawide), 1/4", 1.12µm 2 MP, f/2.4, (macro)
  • Features: Dual-LED dual-tone flash, HDR, panorama
  • Video: 1080p@30fps
SELFIE CAMERA
  • Single: 13 MP, f/2.5, (wide), 1/3.0"
  • Features: HDR
SOUND
  • Loudspeaker: Yes
  • 3.5mm jack: Yes 24-bit/192kHz audio
COMMS
  • WLAN: Wi-Fi 802.11 a/b/g/n/ac, dual-band
  • Bluetooth 5.1, A2DP, LE
  • Positioning: GPS, GLONASS
  • NFC Yes (market/region dependent)
  • Infrared port: Yes
  • Radio: Unspecified
  • USB: USB Type-C 2.0, OTG
FEATURES
  • Sensors: Fingerprint (side-mounted), accelerometer, gyro, proximity, compass
BATTERY
  • Type: Li-Po 5000 mAh, non-removable Charging 33W wired, 50% in 22 min (advertised)
MISC
  • Colors: Frosted Green, Matte Black, Mystique Blue
  • Models: 22111317I, 22111317G
  • Price: € 209.00 / $ 225.00 / £ 216.20 / ₹ 16,999
  • theduke1989
Gereserveerd
Versiebeheer:
21.06.2023 - Xiaomi Redmi Note 12/Pro topic aangemaakt.
21.06.2023 - Specificaties toegevoegd
  • hars73
  • Laatst online: 12-11 22:36
Ik heb de Redmi Note 12 Pro sinds bijna een week. Heb eigenlijk maar 1 issue waar ik last van heb. De WiFi verbinding met mn Deco M4 accesspoints is niet stabiel. Regelmatig een disconnect, WiFi icoontje even weg, komt weer en maakt weer verbinding. Duurt een paar seconden in totaal.
Dit gebeurt soms paar keer per minuut. Soms paar keer per 10 minuten.
Statisch ip adres hielp niet. Wifi throtting in developer settings uitzetten of aanzetten hielp ook niet. Netwerk instellingen resetten ook niet. Deco's een update gegeven en dus herstart. Ook geen verbetering . Alle WiFi netwerken vergeten en opnieuw verbinding maken. Ook niks.
Uiteindelijk echt van alles geprobeerd en de Mesh Technology setting voor dit apparaat uitzetten in de Deco app lijkt te werken. Echter daardoor dus soms in het huis niet het beste WiFi bereik. Dus niet de mooiste oplossing.
Alle andere apparaten in huis hebben hier geen last van. Mijn vorige Mi Note 10 lite ook niet.
Verder een fijn toestel tot nu toe. Lange accuduur. Scherm een hoge helderheid. Prima snelheid. Camera moet ik nog een beetje uitproberen.
[ Voor 32% gewijzigd door hars73 op 22-06-2023 23:31 ]
  • justguyver
  • Laatst online: 21-11 15:18
Ik heb hetzelfde probleem maar dan met een deco m5. Van alles al geprobeerd wat ik op internet kon vinden. Maar nog geen oplossing gevonden.
  • Stark
  • Laatst online: 00:54
Hebben jullie de normale of de 5G? Die komt namelijk met een andere chip.
  • justguyver
Ik heb de 5g versie. Ik heb het voor nu weten op te lossen door snelle roaming uit te zetten in de deco. Hierdoor word het overschakelen tussen de punten iets langzamer, maar het internet lijkt wel beter te werken.
  • louzy82
  • Laatst online: 26-11 12:33
Hoe is jullie ervaring met de telefoon?
Ik ben ook voornemens de Redmi note 12 pro 5g 8gb aan te schaffen (heb nu een redmi note 9 pro waar ik altijd heel tevreden mee ben geweest)
[ Voor 7% gewijzigd door louzy82 op 19-09-2023 13:35 ]
Louzy#2475
  • Vlassie1980
  • Laatst online: 22:50
Omdat mijn Motorola Edge 20 na 3 reparaties alsnog beschadigd was mocht ik uit coulance een ander toestel kiezen. Ik heb nu voor een Redmi Note 12 pro gekozen. Ze boden me een kleiner toestel aan dus hopelijk is dit akkoord.
Ik heb deze gekozen vanwege het grote scherm, snel opladen, 256GB opslag en vingerafdrukscanner in de powerknop. Lijkt me een prima toestel om het resterende jaar van mijn contract te overbruggen.
  • RepareerDroid
  • Registratie: September 2022
De Redmi Note 13 serie is inmiddels ook officieel onthuld:
https://www.gsmarena.com/...7200_ultra-news-59986.php
https://www.gsmarena.com/...o_unveiled-news-59987.php
De Redmi Note 13 Pro+ krijgt IP68 waterbestendigheid en regen touch voor beter gebruik in de regen. Wel een gebogen scherm en helaas nog altijd een zeer matige 2MP macro cam met vaste focus.
  • Vlassie1980
Toestel ontvangen en inmiddels in gebruik. Doet me aardig denken aan mijn oude Oppo Reno 2Z.
Ik moest om het always on display aan te laten staan een trucje doen met de developer mode:
YouTube: Remove Always on Display 10 Second Limit /From Redmi Note 10 Pro / M...
Waarom ze dat nou defaulft uitzetten terwijl het Always On Display heet? :')
Maar ik heb het in ieder geval werkend.
Telefoon ziet er verder goed uit, gelukkig een vingerafdrukscanner in de powerknop.
  • theduke1989
Vlassie1980 schreef op maandag 25 september 2023 @ 15:57:
Het ergste is, dat het onder developer mode staat. Terwijl het een feature is die bekend is.
Dit hoort gewoon in de instellingen menu te staan.
  • Vlassie1980
theduke1989 schreef op maandag 25 september 2023 @ 16:10:
Klopt, beetje aparte gedachtegang daar bij Xiaomi...
  • louzy82
Ik heb de Note 12 pro nu ongeveer een week in gebruik. Ben er erg blij mee.
Had deze always on workaround ook gevonden maar heb het voor nu nog even uit laten staan.
Ik vind de batterij een beetje tegenvallen.
Hij gaat makkelijk een dag mee maar ik moet hem na een dag wel opladen en ik had eigenlijk verwacht dat hij het langer vol zou houden.
Dat komt omdat mijn Redmi note 9 pro van 3,5 jaar oud ook nog steeds makkelijk een dag mee ging en ik ervanuit ging dat een nieuw toestel het weer langer vol zou houden (zoals mijn note 9 pro in het begin)
Louzy#2475
  • Vlassie1980
Batterij viel me ook een beetje tegen, misschien dat het Always on Display toch de nodige power slurpt. Mijn Motorola Edge 20 was zeker zuiniger terwijl die ook een kleinere accu had. Maar die had dan geen Always On scherm. Maar met die 67W charger gaat hij ook weer als de brandweer vol. Kan je nagaan hoe snel dat gaat met de Pro + met 120W charger :D
Al die vervelende ads inmiddels ook uit kunnen zetten, erg vervelend als dat allemaal aan staat.
[ Voor 16% gewijzigd door Vlassie1980 op 27-09-2023 11:58 ]
  • DH-64
  • Laatst online: 03-08-2024
Iemand al een Android versie 13 update gekregen op de Redmi Note 12 Pro + 5G.
Sinds een maand het toestel in gebruik en heb wel een update gehad naar MIUI-versie 14.0.6
  • RepareerDroid
DH-64 schreef op zaterdag 7 oktober 2023 @ 22:33:
Heb je MIUI Global? Die heeft de update nog niet. Soms krijg je ook nieuwere updates als je de regio even naar een andere Europees land zet (in de Instellingen app bij aanvullende instellingen -> regio).
  • DH-64
RepareerDroid schreef op zondag 8 oktober 2023 @ 13:48:
Bedankt voor je reactie en tip. Inderdaad heb ik MIUI-versie Global 14.0.6. Ik zal de andere Europese landen is gaan proberen. Ik kom hierop terug of het heeft gewerkt :)
[ Voor 7% gewijzigd door DH-64 op 08-10-2023 14:44 ]
  • Vlassie1980
Nou, nadat ik de Xiaomi Redmi Note 12 Pro uit coulance kreeg voor de Motorola Edge 20 perikelen blijkt deze nu ook een issue in het scherm te hebben :(
Je ziet op een witte achtergrond dat de tekst naar rechts toe een soort schaduw heeft die doorloopt tot de rechter kant van het scherm. Als je er echt op let is het duidelijk zichtbaar. Dus we gaan maar weer Belsimpel contacten....
  • DH-64
Het veranderen van de regio heeft helaas geen invloed gehad op een mogelijke update naar versie 13 dus misschien nog dit jaar, we gaan het zien.
Update::
Vandaag (18-10-2023) dan toch eindelijk de gewenste update ontvangen: Android-versie 13 TP1A.220624.014
[ Voor 11% gewijzigd door DH-64 op 18-10-2023 19:59 ]
  • hars73
Ik kreeg deze update al in augustus voorgeschoteld, toen ik in Italie op vakantie was. Toen niet gedaan vanwege geen wifi. Na de vakantie thuis was de update even niet meer beschikbaar, maar 2 dagen later kon ik hem toch uitvoeren. Fijn dat het NFC icoontje weer aan de rechterkant staat ipv aan de linkerkant. Verder merk ik geen verschil eigenlijk.
En behalve dat het roamen met mijn Deco systeem nog steeds niet werkt, mijn wifi daarom soms niet optimaal is qua snelheid (verbonden met een Deco AP die te ver weg staat), bevalt het toestel nog steeds prima.
  • daffie82
  • Laatst online: 00:53
daffie82
Minisforum UM773 Lite
Heb een Redmi Note 12 Pro+ v14.0.3.0 (TMOEUXM)
Heb bizar probleem. Iemand een idee wat hier aan te doen is? Behalve een factory reset. Daar heb ik geen zin in.
Zowat elke 6 weken werkt bluetooth op een gegeven moment niet meer. Na 20 tal seconden muziek afspelen op een device kapt die er telkens mee. Elk device.
Reset WiFi/netwerk/bluetooth en het gaat weer zonder problemen voor een 6-tal weken.
Na 6-tal weken opnieuw hetzelfde probleem en dezelfde oplossing.
Iemand idee?
[ Voor 51% gewijzigd door daffie82 op 02-11-2023 22:50 ]
LG G1 65'' | Nakamichi DRAGON 11.4.6 w/ Dual-Opposing 8'' Subs | Panasonic UB820 | Ugoos AM6B+ (CE w/ p3i fork) I iFi ZEN DAC 3 + Sennheiser HD490
  • hars73
Ik heb gistermiddag op advies van iemand ergens een TP-Link forum de instelling 'Beveiliging' bij de wifi instellingen in de Deco software van WPA/WPA2 naar WPA2 omgezet.
Daarna 'Mesh Technologie' voor mijn Redmi Note 12 Pro weer aangezet in de Deco software. En sinds die tijd heb ik nog geen Wifi disconnects gezien.
Heb mijn netwerk gewoon op 2.4/5Ghz gecombineerd staan. Paar keer per dag kijk ik sinds gisteren op welke AP ik geconnect ben en dat lijkt wel telkens dezelfde te zijn en dan de 5Ghz versie.
Voorlopig fingers crossed...
  • theduke1989
@hars73 goed om te weten voor de gene die er problemen mee hebben, dank voor de info.
  • hars73
Nu een paar dagen verder lijkt het nog steeds prima. Geen disconnects, vrijwel altijd het 5ghz netwerk en er worden zo door de dag heen wel eens automatisch andere AP's gekozen, maar niet vaak. Ik zie in ieder geval nooit een disconnect. Voor mij is dit helemaal prima zo.
[ Voor 5% gewijzigd door hars73 op 09-11-2023 23:47 ]
  • daffie82
daffie82
Iemand een idee waarom ik nog steeds op 14.0.3.0 TMOEUXM zit voor mijn Redmi Note 12 Pro +
Hij zegt geen updates...
Als ik handmatig via MIUI downloader app de 14.0.10.0 versie download (https://bigota.d.miui.com...OEUXM_e2ac99f0af_13.0.zip) en deze wil installeren krijg ik volgende melding :
Afbeeldingslocatie: https://tweakers.net/i/oDr831b6cIalSjZFEFrmR-cGofg=/x800/filters:strip_icc():strip_exif()/f/image/GAMCIgcEeArgK4p78FrfnpXo.jpg?f=fotoalbum_large
  • RepareerDroid
daffie82 schreef op donderdag 30 november 2023 @ 19:08:
Heb je al geprobeerd de regio op je telefoon te veranderen naar een ander Europees land, bijv. Finland (in de Instellingen app bij aanvullende instellingen -> regio)? Vaak krijg je dan alsnog de updates die je op je lokale regio niet krijgt.
[ Voor 7% gewijzigd door RepareerDroid op 01-12-2023 15:11 ]
  • daffie82
daffie82
@RepareerDroid thanks man!
Via Finland nu 14.0.8.0 erop staan.
Gewoon op Finland laten staan?
  • Emcee
  • Laatst online: 23-11 14:33
Is er iemand die een redmi note 12 pro of pro+ 5G heeft? Zit dfaar een sd card slot in voor extra geheugen?
Op internet vind ik tegenstrijdige berichten helaas.
  • subwaysurfer
  • Laatst online: 21-11 13:40
Emcee schreef op woensdag 31 januari 2024 @ 23:35:
Ik heb de Pro 12 5G. Er is ruimte voor een sd card maar niet als je 2 simkaarten gebruikt (zoals ik). Heb de telefoon sinds september maar nu helaas fingerprint sensor problemen, zie volgende post.
  • subwaysurfer
Sinds dinsdag heb ik problemen met m'n fingerprint sensor. Hij reageert vaak helemaal niet - maar soms werkt ie ineens wel. En moet ik dus unlocken met een wachtwoord.
Reboot helpt niet, heb daarna met bovenstaande truc (regio naar Finland) geupdate naar 14.0.12 en dat hielp ook niet. Uiteindelijk factory reset gedaan maar nog steeds exact hetzelfde gedrag: 9 van de 10 keer werkt ie niet, geen response (ook geen trilling).
Door 6x op de kernal versie te klikken kun je o.a. de fingerprint sensor een selftest laten doen, als de sensor niet werk, faalt de test ook. Als de sensor het toevallig doet en ik dus zo heb unlocked, slaagt de selftest...
Iemand ideeën wat er aan de hand kan zijn? Ik kan op internet niets vinden. Is er nog een andere manier om de hardware te testen?
  • daffie82
daffie82
subwaysurfer schreef op donderdag 1 februari 2024 @ 11:56:
Gevalletje reparatie. Lijkt me dat je alles geprobeerd hebt.
bij mij werkt die gewoon altijd goed. Heb hem sinds mei 2023.
  • hars73
Gisteravond de HyperOS update ontvangen op mijn 12 Pro 5G. Versie 1.0.1.0.UMOEUXM inclusief de januari Android beveiligingsupdate. Ik zie nog niet zo heel veel verschil met MIUI, behalve wat kleine details hier en daar in vormgeving. Nou gebruik ik ook Novalauncher, dus alle nieuwe dingen in de Xiaomi launcher, zie ik sowieso niet.
In ieder geval weer een beetje up-to-date.
  • daffie82
daffie82
hars73 schreef op maandag 5 februari 2024 @ 08:36:
Kleuren en helderheid zijn anders. Lijken feller.
Ook tekst in browser is anders. Zoals hier op Tweakers while im typing.
[ Voor 5% gewijzigd door daffie82 op 05-02-2024 09:27 ]
  • hars73
daffie82 schreef op maandag 5 februari 2024 @ 09:14:
Ja nou je het zegt, het lijkt inderdaad allemaal iets feller te zijn ofzo.
Heb jij in de Chrome browser op sommige pagina's ook dat er stukken van de pagina herhaald worden waardoor de pagina een beetje in de soep draait? De beginpagina van Tweakers heeft er bijvoorbeeld ook last van. Soms helpt een refresh om het te verhelpen. Soms komt het dan ook weer terug. Ik had het al voor deze update trouwens hoor.
Als voorbeeld zie je ook hier iemand die hier last van heeft. Blijkbaar niet alleen op Xiaomi telefoons:
https://www.reddit.com/r/...e_repeats_bits_of_a_page/
  • daffie82
daffie82
@hars73
Ik gebruik geen Chrome, ik gebruik Edge. En daar heb ik er geen last van.
  • hars73
Ik was met er niet eens van bewust, maar met deze update naar HyperOS is Android ook van versie 13 naar 14 gegaan. Het leek alsof de eerste dag de accuduur behoorlijk slechter geworden was, maar ik geloof dat die na een update weer wat dagen nodig heeft om te calibreren. Gisteren was het al wat beter.
  • hars73
subwaysurfer schreef op donderdag 1 februari 2024 @ 11:52:
Ik weet niet of jij dan wel de Redmi Note 12 Pro 5G hebt/had? Want die van mij heeft geen SD slot hoor. De 4G versie heeft die mogelijkheid wel, maar dat is eigenlijk een hele andere telefoon met andere specs.
https://www.mi.com/global/product/redmi-note-12-pro-5g/
https://www.mi.com/global/product/redmi-note-12-pro/specs/
  • theduke1989
hars73 schreef op donderdag 8 februari 2024 @ 09:01:
Persoonlijk zou ik voor de non 5G gaan dan. Die heeft een Qualcomm soc, wat voor mij veel beter is.
Qua ROM support.
rare is wel dat bij xda forums bij de 5g aangetoond wordt dat het wel een Qualcomm soc heeft?
https://xdaforums.com/f/redmi-note-12-5g.12689/?prefix_id=33
  • hars73
theduke1989 schreef op donderdag 8 februari 2024 @ 10:21:
Dat is de gewone Redmi Note 12, niet de pro versie.
  • RepareerDroid
hars73 schreef op vrijdag 9 februari 2024 @ 08:42:
Van de Pro modellen heeft inderdaad alleen de 4G en de vorige generatie Redmi Note 11 Pro (4G en 5G) ruimte voor een SD kaart. Bij de nieuwe Redmi Note 13 Pro heeft ook alleen het 4G model SD kaart ondersteuning.
  • SamSid
  • Registratie: November 2022
  • Laatst online: 26-11 15:21
RepareerDroid schreef op vrijdag 9 februari 2024 @ 16:46:
Ik snap niet waarom ze geen SD ondersteuning geven. Er is vraag ernaar. Toch halen ze het weg bij de topmodellen.
  • daffie82
daffie82
hars73 schreef op maandag 5 februari 2024 @ 10:31:
Die pagina's die soms in de soep draaien heb ik ook op Edge browser.
Weet jij of hier al een oplossing voor is?
  • hars73
daffie82 schreef op woensdag 21 februari 2024 @ 12:53:
Even Edge geprobeerd net en inderdaad, ook daar doet bijvoorbeeld de Tweakers pagina het niet goed. Het is niet Chrome gerelateerd dus.
Ik heb nog geen oplossing helaas.
  • louzy82
Ik heb laatst een update geinstalleerd op mijn redmi note 12 pro 5G en draai nu
OS Version: Xiaomi HyperOS 1.0.1.0.UMOEUXM
Android Version: 14 UP1A.231005.007
Ik gebruik lawnchair als launcher.
Sinds de update is mijn telefoon regelmatig na unlocken unresponsive. Apps werken niet, app drawer swipe werkt niet. Als ik lock en opnieuw unlock werkt alles weer als normaal.
Zeer irritant dus, heeft iemand anders dit probleem ook?
Louzy#2475
  • daffie82
daffie82
Geen probleem. Ik gebruik echter geen launcher.
  • daffie82
daffie82
daffie82 schreef op donderdag 2 november 2023 @ 22:45:
Iemand idee?
Dit probleem is nog steeds aanwezig nu ik op versie Xiaomi HyperOS 1.0.1.0.UMOEUXM zit.
Dacht dat het met updaten naar deze versie verholpen was maar helaas... Echt irritant. Lijkt wel of na een poosje het bluetooth geheugen vol is, en hij het niet meer aankan. Gelukkig werkt die ''fix'' ook nog steeds, maar irritant is het wel.
  • rverhulst
  • Laatst online: 15-06 12:12
Ik heb die update HyperOs android 14 ook gekregen.(Redmi 12 pro
Maar sinds de update hoor ik telkens een soort ratelend geluid(seconden die weg tikken idee).
Dacht eerst dat het een melding was van openstaande apps maar nee).
Iemand een idee?.
  • daffie82
daffie82
@rverhulst Wanneer hoor je dat geluid? Maak eens een opname hiervan.
Met de huidige info is het onmogelijk om je te helpen
  • louzy82
daffie82 schreef op vrijdag 22 maart 2024 @ 14:26:
Ik ben teruggegaan naar de default launcher en sindsdien speelt het probleem niet meer dus het probleem zat hem in Lawnchair.
Louzy#2475
  • hars73
Ik heb net onderstaande setting in Chrome aangepast op advies van iemand in mijn eerdere genoemde reddit topic. En de eerste test lijkt goed te zijn. Ik zal het de komende tijd eens aankijken.
Go to chrome://flags
Scroll down until you find GPU rasterization
Disable it
Save and relaunch Chrome
  • daffie82
daffie82
@hars73 thanks. En in Edge? Ik gebruik Chrome niet.
  • hars73
daffie82 schreef op dinsdag 2 april 2024 @ 14:24:
Als ik een beetje Google, lijkt die dezelfde flag ook te hebben. Probeer eens ;)
  • hherrie
  • Laatst online: 25-11 21:41
Voor zover ik weet, is edge://flags niet bruikbaar in de mobiele Edge-app.
  • hars73
hherrie schreef op dinsdag 2 april 2024 @ 15:40:
Even getest en bij mij kan ik in de Edge app gewoon deze flag vinden en omzetten. Ook het probleem van de dubbele inhoud lijkt niet meer voor te komen.
  • hherrie
Oh, dan is dat blijkbaar inmiddels veranderd! Te lang geleden dat ik Edge op mobiel heb gebruikt blijkbaar...
  • daffie82
daffie82
Yes werkt. Thanks!
edge://flags/#enable-gpu-rasterization
  • hars73
daffie82 schreef op dinsdag 2 april 2024 @ 16:00:
Yes werkt. Thanks!
Beter he? Ik had al een paar keer webshops die verderop in het bestelproces bij de keuze van betalingsmethode ook alles 10-dubbel weergaven. Hierdoor was bestellen eigenlijk wel ingewikkeld.
  • daffie82
daffie82
hars73 schreef op dinsdag 2 april 2024 @ 16:06:
Ja had ik ook soms haha. Echt wel beter! Dank voor het delen ;)
  • Suffolk
  • Registratie: Maart 2014
  • Laatst online: 24-11 09:22
hars73 schreef op dinsdag 2 april 2024 @ 14:04:
Disable it
Heb hier ook last van, maar waar vind ik dat 'chrome://flags' :X
  • hars73
Suffolk schreef op dinsdag 2 april 2024 @ 16:26:
Gewoon dat stukje wat je noemt letterlijk zo ingeven in de adresbalk van Chrome. Alsof je een website ingeeft.
  • Vlassie1980
Iemand die na de update naar HyperOS ook merkt dat de batterij sneller leeg gaat?
Heb het idee dat die wat meer drain heeft, gaat om een Note 12 Pro.
  • hars73
Vlassie1980 schreef op woensdag 3 april 2024 @ 11:13:
In de eerste dagen vond ik dat inderdaad ook. Maar na een week ofzo merk ik eigenlijk geen verschil.
  • Vlassie1980
hars73 schreef op woensdag 3 april 2024 @ 14:28:
Okay, dan kijk ik het nog even aan :)
  • daffie82
daffie82
Nieuwe versie eindelijk uit. Tenminste als je regio op Finland zet.
v1.0.3.0 is meest recente nu met veiligheidsupdates bijgewerkt tot 1/4/24
[ Voor 35% gewijzigd door daffie82 op 28-04-2024 20:07 ]
