Black screen met geluid rtx 3070
  • corydorras
  • Laatst online: 02-09 06:26
recent krijg ik helaas regelmatig een black screen tijdens het gamen geluid blijft wel werken en fans gaan behoorlijk hard draaien
momenteel gebruik ik voor de gpu drivers versie 531.68 helaas hielp deze update niet
onderdelen
MSI rtx 3070 ventus
asrock b550m steel legend
amd 3700x
2x8gb ddr4 3200 mhz
Cooler Master MasterWatt 750
na het kijken in de minidump vermoed ik iets met de nvidia drivers maar ik weet het niet zeker daarom dat ik jullie om hulp vraag
Hier onder staat de info uit de minidump als er nog meer info nodig is hoor ik het graag
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
DISPATCH_LEVEL or above.
Arg2: 0000000000001e00, The watchdog period (in ticks).
Arg3: fffff807274fb320, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
additional information regarding the cumulative timeout
Arg4: 0000000000000000
Debugging Details:
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: TickPeriods ***
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2077
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 2071
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 546
Key : Analysis.Init.Elapsed.mSec
Value: 10491
Key : Analysis.Memory.CommitPeak.Mb
Value: 95
Key : Bugcheck.Code.DumpHeader
Value: 0x133
Key : Bugcheck.Code.Register
Value: 0x133
Key : Dump.Attributes.AsUlong
Value: 8
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
FILE_IN_CAB: 042123-8953-01 (2).dmp
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
BUGCHECK_CODE: 133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff807274fb320
BUGCHECK_P4: 0
DPC_TIMEOUT_TYPE: DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: System
STACK_TEXT:
fffff807`29aa5e18 fffff807`26c43714 : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff807`274fb320 : nt!KeBugCheckEx
fffff807`29aa5e20 fffff807`26a813c3 : 00003441`db4403c0 fffff807`216f0180 00000000`00000000 fffff807`216f0180 : nt!KeAccumulateTicks+0x1bfaf4
fffff807`29aa5e80 fffff807`26a80eaa : fffff807`274f39c0 fffff807`29a97380 fffff807`28a11500 00000000`00009101 : nt!KeClockInterruptNotify+0x453
fffff807`29aa5f30 fffff807`26b3e965 : fffff807`274f39c0 00000000`00000000 00000000`00000000 ffff5f71`f58cdb5a : nt!HalpTimerClockIpiRoutine+0x1a
fffff807`29aa5f60 fffff807`26bfdbaa : fffff807`29a97380 fffff807`274f39c0 fffff807`29a97620 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0xa5
fffff807`29aa5fb0 fffff807`26bfe377 : 00000000`00000002 fffff807`29a974f0 00000000`00000000 00000000`000000a8 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff807`29a97300 fffff807`26a1e76b : ffffb985`734ef000 00000000`00000000 ffffb985`73581000 ffffb985`734ef000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff807`29a97490 fffff807`4799bd73 : fffff807`29a97678 fffff807`29a97620 ffffb985`73581000 fffff807`29a97620 : nt!KzLowerIrql+0x1b
fffff807`29a974c0 fffff807`29a97678 : fffff807`29a97620 ffffb985`73581000 fffff807`29a97620 fffff807`29a97670 : nvlddmkm+0xabd73
fffff807`29a974c8 fffff807`29a97620 : ffffb985`73581000 fffff807`29a97620 fffff807`29a97670 fffff807`4799d74d : 0xfffff807`29a97678
fffff807`29a974d0 ffffb985`73581000 : fffff807`29a97620 fffff807`29a97670 fffff807`4799d74d fffff807`29a97670 : 0xfffff807`29a97620
fffff807`29a974d8 fffff807`29a97620 : fffff807`29a97670 fffff807`4799d74d fffff807`29a97670 ffffb985`73581000 : 0xffffb985`73581000
fffff807`29a974e0 fffff807`29a97670 : fffff807`4799d74d fffff807`29a97670 ffffb985`73581000 ffffff95`b319847b : 0xfffff807`29a97620
fffff807`29a974e8 fffff807`4799d74d : fffff807`29a97670 ffffb985`73581000 ffffff95`b319847b ffffb985`73581000 : 0xfffff807`29a97670
fffff807`29a974f0 fffff807`29a97670 : ffffb985`73581000 ffffff95`b319847b ffffb985`73581000 fffff807`216f0180 : nvlddmkm+0xad74d
fffff807`29a974f8 ffffb985`73581000 : ffffff95`b319847b ffffb985`73581000 fffff807`216f0180 fffff807`4798a475 : 0xfffff807`29a97670
fffff807`29a97500 ffffff95`b319847b : ffffb985`73581000 fffff807`216f0180 fffff807`4798a475 ffffb985`734ef000 : 0xffffb985`73581000
fffff807`29a97508 ffffb985`73581000 : fffff807`216f0180 fffff807`4798a475 ffffb985`734ef000 ffffb985`73581000 : 0xffffff95`b319847b
fffff807`29a97510 fffff807`216f0180 : fffff807`4798a475 ffffb985`734ef000 ffffb985`73581000 ffffb985`734ef000 : 0xffffb985`73581000
fffff807`29a97518 fffff807`4798a475 : ffffb985`734ef000 ffffb985`73581000 ffffb985`734ef000 ffffb985`73581000 : 0xfffff807`216f0180
fffff807`29a97520 ffffb985`734ef000 : ffffb985`73581000 ffffb985`734ef000 ffffb985`73581000 ffffb985`00000004 : nvlddmkm+0x9a475
fffff807`29a97528 ffffb985`73581000 : ffffb985`734ef000 ffffb985`73581000 ffffb985`00000004 fffff807`47514203 : 0xffffb985`734ef000
fffff807`29a97530 ffffb985`734ef000 : ffffb985`73581000 ffffb985`00000004 fffff807`47514203 000000ff`00000900 : 0xffffb985`73581000
fffff807`29a97538 ffffb985`73581000 : ffffb985`00000004 fffff807`47514203 000000ff`00000900 00000000`00000001 : 0xffffb985`734ef000
fffff807`29a97540 ffffb985`00000004 : fffff807`47514203 000000ff`00000900 00000000`00000001 fffff807`27527a00 : 0xffffb985`73581000
fffff807`29a97548 fffff807`47514203 : 000000ff`00000900 00000000`00000001 fffff807`27527a00 0000ffff`f8072942 : 0xffffb985`00000004
fffff807`29a97550 00000000`0889d8cb : 00004db6`1823a1d8 00004db6`35f106d8 00004db6`35f106d8 00004db6`8f5935d8 : amdppm!GetCpcDifferentialFeedback+0x33
fffff807`29a97580 00004db6`1823a1d8 : 00004db6`35f106d8 00004db6`35f106d8 00004db6`8f5935d8 00000000`00000000 : 0x889d8cb
fffff807`29a97588 00004db6`35f106d8 : 00004db6`35f106d8 00004db6`8f5935d8 00000000`00000000 00000000`00000000 : 0x00004db6`1823a1d8
fffff807`29a97590 00004db6`35f106d8 : 00004db6`8f5935d8 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00004db6`35f106d8
fffff807`29a97598 00004db6`8f5935d8 : 00000000`00000000 00000000`00000000 00000000`00000000 00000022`00000000 : 0x00004db6`35f106d8
fffff807`29a975a0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000022`00000000 00000000`00000000 : 0x00004db6`8f5935d8
SYMBOL_NAME: nvlddmkm+abd73
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
STACK_COMMAND: .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET: abd73
FAILURE_BUCKET_ID: 0x133_ISR_nvlddmkm!unknown_function
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {f97493a5-ea2b-23ca-a808-8602773c2a86}
Followup: MachineOwner
