Python: return to caller module
  • Gergely
  • Laatst online: 14-08-2025
Mijn vraag
Don’t know how to return from a called module back to the caller module:
Situation: Python prog A.py and Python prog B.py
In prog A I can jump to prog B, using the ‘import prog B’ function in prog A. Works great.
The problem is when I want to close prog B and to return to prog A (the caller)
I tried the fowolling:
- QUIT(() , EXIT() and Sys.EXIT() kills prog B, but also prog A
- root.destroy: prog B looks to be closed and cannot be called again…
Has anyone a solution?
Python 3.11.1
  • remco_k
  • Laatst online: 01:11
remco_k
een cassettebandje was genoeg
Do not use all of those.
Use return instead or just let the called function run out of scope.
Alles kan stuk.
