• Tosti55
  • Registratie: Mei 2017
  • Laatst online: 02-11 11:24
Kan niet wachten op de volgende DLC.
  • G_Dragon
  • Laatst online: 19:21
G_Dragon
Whatever you do, do it well.
Nieuwe update (Version: 2008.007.003.005.004):
Game Mode Adjustments
  • Legendary Warrior Face-Off (New): This mode, where you can face-off against an
  • extremely powerful character, has been added for a limited time. (You cannot select
  • this mode outside of the period.)
  • Episode Battle: It is now possible to change the difficulty even when using a Dragon
  • Orb.
  • Custom Battle: More situations, effects, and text that you can set have been added.
  • Ranked Match: A wait time has been added before matching begins as a penalty based
  • on the number of times you have disconnected.
  • Battle Setup: You can now see the controls explanation when selecting a character.
  • Training: The option "Guarding After Attacks" has been added when playing against
  • a CPU.
Player Match:
  • Quick Match has been changed so that you do not enter a room and instead get immediately matched with an opponent.
  • We have also added "Quick Room Search" for Quick Match.
Battle System Adjustments
  • Charge Attacks (Smash Attack or Rush Chain): You will no longer recoil while
  • charging when receiving a Rush Attack or Rush Ki Blast from an opponent in
  • Sparking! Mode.
  • Rush Attack: It is now harder to mistakenly input a Smash Attack during Rush
  • Attacks.
  • Grand Slash: Hitting an opponent that is falling from a Grand Slash with another
  • Grand Slash will now cause them to be blown away spinning.
  • Rush Ki Blast: You will no longer be able to perform a High-Speed Evasion when
  • being hit.
  • Smash Ki Blast: You will now be easier to hit when firing while moving.
  • Super Counter: Time between being able to perform an input has been increased
  • after unsuccessfully performing the move.
  • Speed Impact: The timing for being able to input again after the move finishes has
  • been made later.
  • Chase Change: Damage from Giant Characters has been reduced when Chase
  • Changing into them.
Impact Recovery:
  • When blown back from Lift Strike, holding the button down will activate Impact
  • Recovery once you hit the ground.
  • Also, when blown back and spinning, holding the button down will activate Impact
Perception/Super Perception:
  • A certain amount of Ki will now be consumed upon activation.
  • After finishing the move, the time until the next action is able to be performed has
  • been increased.
Skill Adjustments
  • Overall Automatic Avoidance Skills (e.g., Wild Sense): The opponent will no longer
  • be able to use these skills when performing a combo and continuing the combo with a
  • Rush-In.
  • Wild Sense: Attack damage has been reduced.
  • Kaioken: Skill Count consumed has been reduced (only for Goku (Z - Early)).
  • Ta-dah!: Skill Count consumed has been reduced.
  • All I Need Is Five Seconds!: Ki will be fully recovered.
Other
  • User-friendliness and performance stability have been improved.
  • G_Dragon
G_Dragon
Ik vind het heel jammer dat dit spel zo weinig word gespeeld om mij heen, want zou zelf veel meer willen vechten Tegen anderen of vrienden. Maar die willen ook steeds niet of zijn bezig met andere spellen, had het mij echt veel anders voorgesteld toen dit spel nog niet uit was.
Zonde van z'n mooi spel :D
  • G_Dragon
G_Dragon
Nieuwe VJump scans
Afbeeldingslocatie: https://tweakers.net/i/rHAoP6QYjVM6gqbeHxIfhtPA1p0=/x800/filters:strip_icc():strip_exif()/f/image/MrheIS4zi9UzYEmwC9w98pgT.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/wz9ou5inN2ylhMzGzh5y_ijvFZY=/x800/filters:strip_icc():strip_exif()/f/image/bVaczhXygd3AJJquTtRvzFfr.jpg?f=fotoalbum_large
  • Aschtra
Had DBSZ al even op de wishlist en gisteren kunnen proberen. Manman redelijke leercurve zelfs in episode mode. Kon soms geen flikker tegen Vegeta (niet great ape die was easy) of Frieza doen terwijl de battles buiten hun vrij easy zijn.
Denk dat ik em laat liggen. Te weinig tijd om hier redelijk in te worden. Speel wss toch alleen maar storymode en dan laat ik hem verstoffen
Had wel íets makkelijker verwacht
Blijkbaar werken die ability items ook niet in episode mode..
[ Voor 7% gewijzigd door Aschtra op 28-04-2025 10:33 ]
  • G_Dragon
G_Dragon
Vanavond weer tegen mijn maatje gevochten, we zijn het nog steeds een beetje verleert maar proberen wel weer op niveau te komen;
  • G_Dragon
G_Dragon
En daar is de laatste dlc
  • G_Dragon
G_Dragon
Afbeeldingslocatie: https://tweakers.net/i/ZuvSqQ_PQaC6-e9HuQSLMe8sFPU=/800x/filters:strip_icc():strip_exif()/f/image/pOahL4MDalkXuHeYtkGOOe7u.jpg?f=fotoalbum_large
  • G_Dragon
G_Dragon
Afbeeldingslocatie: https://tweakers.net/i/oRc1lTjDdpFHB9_aTxwfGal1HVg=/800x/filters:strip_icc():strip_exif()/f/image/ZFmb2NLYdG7oKwXkdJIs6lKY.jpg?f=fotoalbum_large
[ Voor 61% gewijzigd door G_Dragon op 25-01-2026 03:33 ]
  • G_Dragon
G_Dragon
Afbeeldingslocatie: https://tweakers.net/i/v2iE6CgF9BqaT6DniHm6EvNuGMw=/x800/filters:strip_icc():strip_exif()/f/image/O11W7oLeppj3WMoZ03NHbgrg.jpg?f=fotoalbum_large
Nieuwe beelden van; Grandpa Gohan, Mercenary Tao, Pikkon,Champa!
  • G_Dragon
G_Dragon
Afbeeldingslocatie: https://tweakers.net/i/KK9EIofoTWazUB9rNvpCLhfyXKw=/800x/filters:strip_icc():strip_exif()/f/image/1Y0AK5mF0DG6RsE3jA3wEOTm.jpg?f=fotoalbum_large
  • G_Dragon
G_Dragon
Limit Breaker Journey ziet er erg intressant uit
Afbeeldingslocatie: https://tweakers.net/i/3KT2SrxkLhCO9Z5J4Wor73NsE58=/232x232/filters:strip_icc():strip_exif()/f/image/eHEqd3D1fYOWZdlKSI3xNXkh.jpg?f=fotoalbum_tileAfbeeldingslocatie: https://tweakers.net/i/BbBd-ai02kOf7B007Jf9B-j8gSk=/232x232/filters:strip_icc():strip_exif()/f/image/GWJaA5afHn8U87FZ7T5ZfkmL.jpg?f=fotoalbum_tileAfbeeldingslocatie: https://tweakers.net/i/Cw8ify_T6WwvH0PPfBa2pvVgzJs=/232x232/filters:strip_icc():strip_exif()/f/image/YeKMnWIEJvDuGqYWKEUTxuAr.jpg?f=fotoalbum_tile
Afbeeldingslocatie: https://tweakers.net/i/lJIxWbsnKt71xMielwXjmJhS1Vk=/232x232/filters:strip_icc():strip_exif()/f/image/EkpIkdnGZjBZQ89yD2DLwlhU.jpg?f=fotoalbum_tile
  • Deurstopper
Ik denk dat ik deze game ook eens ga proberen. Mijn laatste DB ervaring was op de Wii (budokai tenkaichi)
Zal grafisch wel een verschilletje zijn..
Steam/Epic: Deurstopper
  • G_Dragon
G_Dragon
Afbeeldingslocatie: https://tweakers.net/i/E7YUdC6EdPWp-YwcCTdCJtWhnEk=/800x/filters:strip_icc():strip_exif()/f/image/WmSyA9mCFTVYyCzocqJkdsXS.jpg?f=fotoalbum_large
  • G_Dragon
G_Dragon
  • G_Dragon
G_Dragon
Alle nieuwe content in een overzicht;
Afbeeldingslocatie: https://tweakers.net/i/8kR9idseQa9UfCE6sQ8noyW52Vw=/800x/filters:strip_icc():strip_exif()/f/image/THlNkTMM0WdlDaY8x69a3dXW.jpg?f=fotoalbum_large
  • G_Dragon
G_Dragon
Mooie cijfers;
Afbeeldingslocatie: https://tweakers.net/i/NlGkNMVwI2F4NRWWIBsuQhSCuXo=/x800/filters:strip_icc():strip_exif()/f/image/BgT3X6T7Uk6QWaTNGeqSUlA4.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/wn_VoY24D3zq2fQaeXu0civqflI=/x800/filters:strip_icc():strip_exif()/f/image/CpqMXxxxohwNNjneg6gUeas6.jpg?f=fotoalbum_large
  • G_Dragon
G_Dragon
Afbeeldingslocatie: https://tweakers.net/i/FcakloRBguMoSYazc_T7HCzuXCs=/800x/filters:strip_icc():strip_exif()/f/image/RL2HC7nKfLD2kZcSevzWRuH4.jpg?f=fotoalbum_large
  • G_Dragon
G_Dragon
Pagina: 1 2 3 Laatste
