WD Blue SSD model WDS400T2B0A compatilel with HP PavilonDv6
  • 246 views
  • REDGUUZ
  • Registratie: Februari 2017
  • Laatst online: 20-02-2023
Hi,
I have an old HP Pavillon Dv6 laptop which runs on WIN7 SP1 64 bit.
Initially, it had a 500GB 2.5" 7 mm thickness HDD
Over the years, I have upgraded twice to 1TB and next to a 2 TB WD HDD's
Ideally, I would upgrade to a 4TB HDD, but common HDD's are not available in 7 mm thickness and hence do not fit into the Hard Disk Bay.
I have observed that WD markets a SSD 4T 2.5" 7mm ( model WDS400T2B0A ) which COULD fit into the HP Pavilon Dv6 HDD bay.
https://documents.western...blue-3d-nand-sata-ssd.pdf
[b[h2][h2]]Do you think this WD 2.5"4TB 7 mm SSD it would work into this old HP laptop.[/h2][/h2][/b]??
BTW
( I do have a new HP ENVY laptop) , but this HP Pavilion is still going strong).
Of course, I could swap a lot of data ( 1TB) to a separate USB SSD,to create space but I prefer to have everything on one spot.
Looking forard to advice
  • _Dune_
  • Laatst online: 20:00
_Dune_
RAID is geen BACKUP
@REDGUUZ Ik zie verder in het forum dat jij gewoon Nederlands kunt, GoT is een Nederlands/België’s georiënteerd forum, daarom is de voertaal Nederlands. Nu dan ook het verzoek jouw topic start te herschrijven in het Nederlands. Alvast hartelijk dank. 😄
Sinds 1999@Tweakers | Bij IT-ers gaat alles automatisch, maar niets vanzelf. | https://www.go-euc.com/
  • _Dune_
_Dune_
RAID is geen BACKUP
Geen correctie van de topic start, dan gaat deze op slot.
