Thermal Pad of Thermal Grease?
  • eheijnen
NVT.
Ik heb ChatGPT eens gevraagd:
VRAAG:
For CPU cooling what is the difference between Thermal Pads and Thermal grease considering heat conduction, easy to clean and is it reusable?
ANTWOORD:
Thermal Pads and Thermal Grease are both used to improve heat transfer between the CPU and the heatsink.
Thermal Pads are pre-cut sheets of solid, flexible material that are placed between the CPU and the heatsink. They are generally easier to install and clean compared to thermal grease, but they have lower thermal conductivity. Thermal pads also may have a lower lifespan and may need to be replaced after some time.
Thermal Grease is a conductive paste that is applied to the surface of the CPU before attaching the heatsink. It has a higher thermal conductivity compared to thermal pads, which results in better heat transfer. Thermal grease can be difficult to apply evenly, and it can be messy to clean. However, it is reusable and can be removed and reapplied if necessary.
In summary, if ease of installation and cleaning is a priority, thermal pads are the way to go. If maximum thermal conductivity is the goal, thermal grease is the better choice.
VRAAG:
What are the sources for this answer
ANTWOORD:
This information is based on common knowledge and practices in the computer hardware industry and is not derived from any specific source. The information is widely available in various computer hardware forums, websites, and technical documents, and is considered general knowledge among computer enthusiasts and professionals.
Ik denk, gooi het ook hier in de groep dan kunnen we het vergelijken.
Mijn vraag
Ik kwam Thermal Pads tegen en vroeg me af wat de ervaringen hiermee zijn.
- Heb je hier minder (kans op) geknoei mee?
- Hoef je dit niet meer schoon te maken als je bv. een andere koeler monteert?
- Is er veel verschil in de warmte overdracht?
[ Voor 12% gewijzigd door eheijnen op 04-02-2023 08:43 ]
Wie du mir, so ich dir.
Beste antwoord (via eheijnen op 04-02-2023 10:44)
  • sapphire
  • Laatst online: 01:38
sapphire
Die-hard pruts0r
Pads gebruik je om een ruimte te overbruggen van bv 0,5~2mm.
Grease/pasta gaat tussen 2 harde opervlakte die strak op elkaar zitten en doordat het semi-vloeibaar is vult het alleen de minescule ruimtes daartussen. De rest word er tussenuit geperst (als het goed is :p ).
Pasta heeft over het algemeen een veel groter vermogen om warmte door te geven en heeft daarmee de voorkeur voor CPU’s en GPU’s waar je veel vermogen wilt afvoeren.
Pads worden gebruikt tussen geheugenchips en koeling (bv videogeheugen, nand op een ssd) maar ook tussen fet’s en een koellichaam.
[ Voor 5% gewijzigd door sapphire op 04-02-2023 09:43 ]
Gabriël AM5
  • dragonhaertt
  • Laatst online: 22:23
dragonhaertt
@_'.'
Ja, minder geknoei maar slechtere warmte overdracht
Dat is voor het koelen van bijvoorbeeld een SSD niet zo veel verschil, maar bij een processor is dat echt geen optie.
  • Beste antwoord ✓
  • sapphire
sapphire
Die-hard pruts0r
Gabriël AM5
  • eheijnen
Duidelijk betere/uitgebreidere antwoorden dan ChatGPT .
