• Janvier1985
  • Registratie: December 2020
  • Laatst online: 21-07-2024
Hi,
Ik probeer nu al een tijdje te zoeken wat de "correcte" waardes zij om naar pvoutput te verzenden. Met het uitlezen van de inverter heb ik de volgende resultaten:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
vpv1:            PV1 Voltage = 0.0 V
ipv1:            PV1 Current = 0.0 A
ppv1:            PV1 Power = 0 W
pv1_mode:                PV1 Mode code = 0
pv1_mode_label:                  PV1 Mode = PV panels not connected
vpv2:            PV2 Voltage = 0.0 V
ipv2:            PV2 Current = 0.1 A
ppv2:            PV2 Power = 0 W
pv2_mode:                PV2 Mode code = 0
pv2_mode_label:                  PV2 Mode = PV panels not connected
ppv:             PV Power = 0 W
vbattery1:               Battery Voltage = 51.3 V
battery_status:                  Battery Status = 80
battery_temperature:             Battery Temperature = 15.0 C
ibattery1:               Battery Current = 0.0 A
pbattery1:               Battery Power = 0 W
battery_charge_limit:            Battery Charge Limit = 100 A
battery_discharge_limit:                 Battery Discharge Limit = 60 A
battery_error:           Battery Error Code = 0
battery_soc:             Battery State of Charge = 10 %
battery_soh:             Battery State of Health = 100 %
battery_mode:            Battery Mode code = 1
battery_mode_label:              Battery Mode = Standby
battery_warning:                 Battery Warning = 0
meter_status:            Meter Status code = 1
vgrid:           On-grid Voltage = 232.9 V
igrid:           On-grid Current = 0.3 A
pgrid:           On-grid Export Power = -433 W
fgrid:           On-grid Frequency = 49.94 Hz
grid_mode:               Work Mode code = 1
grid_mode_label:                 Work Mode = Inverter On
vload:           Back-up Voltage = 0.0 V
iload:           Back-up Current = 0.0 A
pload:           On-grid Power = 309 W
fload:           Back-up Frequency = 0.0 Hz
load_mode:               Load Mode code = 0
load_mode_label:                 Load Mode = Inverter and the load is disconnected
work_mode:               Energy Mode code = 2
work_mode_label:                 Energy Mode = Normal (On-Grid)
temperature:             Inverter Temperature = 24.1 C
error_codes:             Error Codes = 0
e_total:                 Total PV Generation = 1632.2 kWh
h_total:                 Hours Total = 6464 h
e_day:           Today's PV Generation = 0.7 kWh
e_load_day:              Today's Load = 16.8 kWh
e_load_total:            Total Load = 2870.5 kWh
total_power:             Total Power = -124 W
effective_work_mode:             Effective Work Mode code = 1
effective_relay_control:                 Effective Relay Control = 48
grid_in_out:             On-grid Mode code = 2
grid_in_out_label:               On-grid Mode = Importing
pback_up:                Back-up Power = 0 W
plant_power:             Plant Power = 309 W
meter_power_factor:              Meter Power Factor = 0.001
diagnose_result:                 Diag Status Code = 524294
diagnose_result_label:           Diag Status = Battery SOC low, Battery SOC in back, Self-use off
house_consumption:               House Consumption = 433 W
Ik kan het maar niet vinden wat de V1, V2, V3 en V4 moeten zijn. De rest is geen probleem
De pvoutput zegt:
V1 Energy Generation
V2 Power Generation
V4 Energy Consumption
V4 Power Consumption
Voorlig denk ik:
V1 = e_day * 1000 (wat de zon opbrengt)
V2 = e_load_day * 1000 (wat het huis verbruikt)
V3 ?
V4 ?
Info => https://pvoutput.org/help...ion.html?highlight=status
Kan iemand me helpen aub?
Thx
  • Janvier1985
Echt niemand?
  • dunklefaser
  • Laatst online: 20:32
dunklefaser
Point Of KnowReturn
@Janvier1985 Welke type Goodwe? Lijkt op een type met batterijmanagement.
Waarmee lees je de omvormer uit? HW en SW graag. (Ik zoek ook nog naar een mogelijkheid.)
Een suggestie:
Misschien kan je tegelijkertijd uitlezen en de waarden op semsportal bekijken
en vergelijken? Dit zou een match kunnen opleveren.
In "reports" op semsportal is het update-interval 1 minuut.
  • Janvier1985
Hi,
GoodWe GW5048D-ES
Ik lees deze uit via UDP => https://github.com/marcelblijleven/goodwe
UItlezen via de sems portal is echt een ramp, traag en onbetrouwbaar!
Om dingen nog moeilijker te maken, hebben ze alles een andere naam gegeven en NIKS komt overeen want in sems en un UDP staat, vandaar de vraag
  • Sebazzz
  • Laatst online: 16-08 16:44
Sebazzz
3dp
Als je Home Assistant gebruikt:
YAML:
shell_command:
  pv_output_live_curl: >-
    curl -d "d={{now().strftime("%Y%m%d")}}" -d "t={{now().strftime("%H:%M")}}" -d "v1={{states('sensor.today_s_pv_generation') | float * 1000 }}" -d "v2={{states('sensor.pv_power')}}" -d "v5={{states('sensor.inverter_temperature')}}" -d "v6={{states('sensor.bus_voltage')}}" -d "c1=2" -H "X-Pvoutput-Apikey: 00000000000000000000000000000000" -H "X-Pvoutput-SystemId: 00000000" https://pvoutput.org/service/r2/addstatus.jsp
  pv_output_daily_curl: >-
    curl -d "d={{now().strftime("%Y%m%d")}}" -d "g={{states('sensor.today_s_pv_generation') | float * 1000 }}" -H "X-Pvoutput-Apikey: 00000000000000000000000000000000" -H "X-Pvoutput-SystemId: 00000000" https://pvoutput.org/service/r2/addstatus.jsp
Zo te zien wil jij direct uitlezen, dus dan moet je kijken waar Home Assistant die waarden vandaan plukt.
  • Janvier1985
Het is de bedoeling om deze direct van de UDP naar PVoutput te sturen, niet via via via via
  • Sebazzz
Sebazzz
3dp
Janvier1985 schreef op dinsdag 31 januari 2023 @ 19:40:
Vandaar:
Sebazzz schreef op dinsdag 31 januari 2023 @ 19:39:
  • _Arthur
  • Laatst online: 21:22
_Arthur
blub
V1 = opbrengst tot op het moment van uploaden in Wh, (e_day in jouw overzichtje)
V2 = hoeveel Watt de installatie -op het moment van uploaden- genereerd (in jouw overzichtje is dat plant_power zo te zien)
En dat zijn eigenlijk ook gelijk de enige 2 waardes die echt noodzakelijk zijn; de rest is minder van belang.
Afbeeldingslocatie: https://tweakers.net/i/YuvMD4DYuO9Q5ERNcbf0lNi-IDk=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/tBablfS1eYA6CcoiHCWxISaP.png?f=user_large
  • royke
  • Laatst online: 01-05 18:38
royke
aan het typen....
V3 en V4 haal je van je slimme meter af, niet van je inverter.
Ik vind van niet......
  • Janvier1985
royke schreef op donderdag 2 februari 2023 @ 09:57:
Ohhhhh ok, thx
