slackware 8.0 + NVidia drivers
  • DaFearLess
ik heb een klein probleempje met het instaleren van de Nvidia drivers
als ik de kernel probeerd te instaleren
doe ik eerst
make install
en dan krijg ik de error
root@slackware:~/video/NVIDIA_kernel-1.0-1251# make install
rm -f nv.o os-interface.o os-registry.o Module-linux NVdriver
cc -c -Wall -Wno-unknown-pragmas -Wno-multichar -O  -D__KERNEL__ -DMODULE -D_LOOSE_KERNEL_NAMES -D_X86_=1 -Di386=1 -DUNIX -DLINUX -DNV4_HW -DNTRM -DRM20 -D_GNU_SOURCE -DRM_HEAPMGR -D_LOOSE_KERNEL_NAMES   -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=1251  -I. -I/lib/modules/2.2.19/build/include nv.c
/tmp/ccPRUYZV.s: Assembler messages:
/tmp/ccPRUYZV.s:9: Warning: Ignoring changed section attributes for .modinfo
cc -c -Wall -Wno-unknown-pragmas -Wno-multichar -O  -D__KERNEL__ -DMODULE -D_LOOSE_KERNEL_NAMES -D_X86_=1 -Di386=1 -DUNIX -DLINUX -DNV4_HW -DNTRM -DRM20 -D_GNU_SOURCE -DRM_HEAPMGR -D_LOOSE_KERNEL_NAMES   -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=1251  -I. -I/lib/modules/2.2.19/build/include os-interface.c
cc -c -Wall -Wno-unknown-pragmas -Wno-multichar -O  -D__KERNEL__ -DMODULE -D_LOOSE_KERNEL_NAMES -D_X86_=1 -Di386=1 -DUNIX -DLINUX -DNV4_HW -DNTRM -DRM20 -D_GNU_SOURCE -DRM_HEAPMGR -D_LOOSE_KERNEL_NAMES   -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=1251  -I. -I/lib/modules/2.2.19/build/include os-registry.c
/tmp/ccyUxKll.s: Assembler messages:
/tmp/ccyUxKll.s:16: Warning: Ignoring changed section attributes for .modinfo
ld -r -o Module-linux nv.o os-interface.o os-registry.o
ld -r -o NVdriver Module-linux Module-nvkernel
size NVdriver
   text    data     bss     dec     hex filename
 523235   29312   52364  604911   93aef NVdriver
depmod: *** Unresolved symbols in /lib/modules/2.2.19/video/NVdriver
/lib/modules/2.2.19/video/NVdriver: unresolved symbol __global_cli
/lib/modules/2.2.19/video/NVdriver: unresolved symbol tqueue_lock
/lib/modules/2.2.19/video/NVdriver: unresolved symbol __global_save_flags
/lib/modules/2.2.19/video/NVdriver: unresolved symbol __global_restore_flags
/lib/modules/2.2.19/video/NVdriver: insmod /lib/modules/2.2.19/video/NVdriver failed
/lib/modules/2.2.19/video/NVdriver: insmod NVdriver failed
make: *** [package-install] Error 255
weet iemand hoe ik dit opkan lossen?
specs : http://specs.tweak.to/7435
Je moet waarschijnlijk de kernel source ergens hebben staan(/usr/src/linux). Die moet dezelfde configuratie hebben als de kernel die je nu draait(make menuconfig, make dep).
het gaat fout met modprobe niet met compileren zo te zien. In de kernel heb je een aantal opties:
- enable loadable module support
- set version information on all module symbols
- Kernel module loader
Staan deze aan in de kernel of niet ? Volgens mij moeten ze allemaal aanstaan, tenminste zo kan ik altijd wel alsa sound modules maken en laden.
  • DaFearLess
ik heb mijn kernel aan gepast en ik heb de drivers nu geinstaleerd..
maar het ziet er niet uit!!!!
het beeld is nuheel erg pixeler
ik zie op mijn gewone blouwe achtergrond allemaal puntjes staan nu
iemand enig idee wat ik er aankan doen?
ik heb in /ect/X11/XF86Config het volgende aangepast
     Section "Device"
    Identifier  "VESA Framebuffer"
    Driver  "nvidia"
    VideoRam    32768
    # Insert Clocks lines here if appropriate
EndSection
    Load      "dbe"   # Double buffer extension
# This loads the font modules
    Load      "type1"
    Load      "freetype"
    Load      "speedo"
# This loads the GLX module
    Load     "glx"
EndSection
Op donderdag 30 augustus 2001 19:55 schreef dafearless het volgende:
VideoRam 32768
Volgens mij moet je die bij nvidia kaarten weglaten (dus een "#" ervoor zetten). Maar ik vrees dat dat niet helpt met je probleem :{
  • Kippenijzer
  • Laatst online: 03-09 09:21
Kippenijzer
McFallafel, nu met paardevlees
Bij mij draait hij perfect... Effe de Nvidia source opnieuw compileren onder kernel 2.4.9 hielp bij mij erg veel...
Waarschijnlijk heb je je kleurdiepte op 8bbp staan...
