Wanadoo Premium en FreeBSD
Hoi,
Heeft iemand een idee hoe ik mijn casema com21 modem werkend krijg ik FreeBSD ?
  • axis
  • Laatst online: 26-01-2023
De com21 die ik hier heb staan is platform-onafhankelijk, hij stuurt TCP/IP pakketjes door een UTP kabeltje in je netwerkkaart...
Weet je niet hoe je je TCP/IP settings moet instellen?
Two advices for network troubleshooting.. learn to draw diagrams in Visio, and THINK IN LAYERS!
Op donderdag 30 augustus 2001 18:58 schreef axis het volgende:
Mijn configuratie-files zien er zo uit:
/etc/ppp/ppp.conf:
default:
set redial 1 0
set reconnect 3 10
pppoe:
set device PPPoE:ed0:
set log Warning Error Alert Phase lcp # Debugging
set cd 5
set dial
set login
set timeout 0
set authname "<login_name>@wanadoo"
set authkey "<password>"
set mru 1492
set mtu 1492
/etc/ppp/ppp.linkup:
pppoe:
# Update interface and set routing
iface clear
add! default HISADDR
# Logging
bg /bin/echo "Connected. Using MYADDR as external address. (MYADDR -- HISADDR)"
bg /usr/bin/logger "LABEL - Connected. Using MYADDR as external address. (MYADDR -- HISADDR)"
/etc/ppp/ppp.linkdown:
pppoe:
bg /sbin/route delete default # Delete default route
bg /sbin/route add default -interface rl0
NIC
Verbinding maak ik met ppp -background pppoe
/var/log/ppp.log ziet er zo uit:
Phase: Using interface: tun0
Phase: deflink: Created in closed state
tun0: Command: pppoe: set cd 5
tun0: Command: pppoe: set dial
tun0: Command: pppoe: set login
tun0: Command: pppoe: set timeout 0
tun0: Command: pppoe: set authname username@wanadoo
tun0: Command: pppoe: set authkey ********
tun0: Command: pppoe: set mtu 1492
tun0: Command: pppoe: set mru 1492
tun0: Phase: PPP Started (ddial mode)
tun0: Phase: bundle: Establish
tun0: Phase: deflink: closed -> opening
tun0: Phase: deflink: Connected !
tun0: Phase: deflink: opening -> dial
tun0: Phase: deflink: dial -> carrier
tun0: Phase: deflink: Disconnected !
tun0: Phase: deflink: carrier -> hangup
tun0: Phase: deflink: Connect time: 5 secs: 0 octets in, 0 octets out
tun0: Phase: deflink: hangup -> closed
tun0: Phase: bundle: Dead
Daar kom ik niet verder mee.
  • MediaZoo
  • Laatst online: 11:40
wat wil je met PPP op je ethernet controller ???
ik weet zeer weinig van linux maar dit slaat nergens op.
Op donderdag 30 augustus 2001 20:37 schreef Weps het volgende:
weps: dat heet PPoE oftewel Point-to-Point over Ethernet.
Ik heb simpelweg adsl-setup gedaan en eth1 en username enzow ingevuld.
zal 't binnenkort ook 's met FreeBSD proberen.
Het werkt allemaal door een paar regels te hebben toegevoegd aan /etc/rc.conf
Ik ben happy :)
Op donderdag 30 augustus 2001 23:44 schreef edwinpauli het volgende:
Ik ben happy :)
Ik kan het me voorstellen :)
Kun je me vertellen wat je precies hebt gedaan.
Ik heb namelijk mijn wanadoo broadband premium (com21) verbinding ook werkend alleen op mijn machine met Redhat Linux. Nu wil dat mijn op FreeBSD bak. In Linux kon ik het simpelweg met Roaring Penguin's PPPOE (adsl-setup, adsl-start etc). Maar deze tool was onder de FreebSD port nog niet beschikbaar (hij staat er wel bij maar was nog BROKEN).
Heb je het via kernel module gedaan of ook gewoon met een tool als rp-pppoe?
Tim.
tim@linuxonly.nl
Op vrijdag 31 augustus 2001 09:51 schreef hassebass het volgende:
Tim.
tim@linuxonly.nl
Tim, je hebt mail *D
Veel succes !
