Wie weet wat mprexe.exe eigenlijk precies is. Ik dacht altijd dat het iets te maken had met energiebeheer. Maar sinds kort heb ik AtGuard op mijn pc geïnstalleerd en nu zie ik dat daar mprexe.exe diverse x-en is geladen bij een netwerkconnectie.
kom er net achter dat er een letter verschil zit in de exe's maar had dit gelezen....
misschien evengoed wel intressant ;-)
_____________________________________________
For anyone who actually finds the subseven trojan on their system, DELETE IT!! When you start Windows afterwards, you will get messages about being unable to find a program blah blah blah. It is started in a number of ways, in the win.ini, the system.ini and also in the registry. Please be careful and check out that you aint infected. It really is a nasty piece of work, I had the fortun to have a copy passed over to me from a friend of mine, so I have both ends of the program here. They can do allsorts with it, steal your passwords, hack into your ICQ, yahoo messenger etc and watch all your messages, enable a keyboard logger, disable your keyboard, watch your screen, CONTROL your screen, edit/delete fiels from your machine, get any personal information you have entered(im not sure where they pull this from but trust me they do, but not on all machines). It is a REAL nasty piece of work. I have a copy of the Trojan and the controller here, as it has it's uses if a friend cannot do something with their pc or if they are having problems, don't ask me for a copy unless you have a very genuine reason as I will not give it out, there are certain trustworthy people on here that I would give it to(they might know who they are) but please, no-one, if you do have the controller program don't pass it on, and please *ALL* of you check out your windows directory for MSREXE.EXE it really is a KILLER!
*EDIT*
The following are taken off his website, I dont know how true they are but I'd say it soudns about right...
"The author of SubSeven backdoor calls himself Mobman. His backdoor can be considered to be the most advanced one at the moment."
-Alexey Podrezov, Data Fellows
SubSeven Risk Assessment: High
- Network Associates (McAfee)
"Someone standing over your shoulder, being able to see all of your personal information and perform malicious acts of vandalism on your computer or corporate network."
- Dyan Dyer (CEO), Command Software Systems
gelezen op:
http://www.sysopt.com/forum/Forum1/HTML/003311.html
*EDIT*
gelezen op:
tijd voor verandering.
