• jee_r
  • Laatst online: 10-09 17:37
Iemand raad hoe je best foto's en filmpjes kan maken met je Android smartphone bij het gebruik van een green screen?
Iemand tips? Apps?
Bedankt
  • jack zomer
  • Registratie: Oktober 2020
Druk op je camera app.
Selecteer foto of video.
Selecteer selfiecam
Druk op record.
Resultaat foto of filmpje van je zelf en je groene scherm
Graag gedaan.
[ Voor 6% gewijzigd door jack zomer op 27-12-2022 09:58 ]
  • jee_r
OK... en nu om het green screen aan te passen... om een andere achtergrond te krijgen?
  • 13art
  • Laatst online: 12:43
13art
Moderator Mobile
jee_r schreef op dinsdag 27 december 2022 @ 09:59:
Wat heb je zelf al gevonden en geprobeerd? Hier op GoT verwachten we ook wat eigen inzet van de gebruikers.
Enjoy the silence...
  • Montaner
  • Laatst online: 13:10
Het AI antwoord.. kan je wel wat eigen research mee doen :)
To use a green screen with an Android device, you will need to use a video editing app that has chroma key or green screen capabilities. Here are the steps to follow:
Set up your green screen background and position your Android device so that it is filming the subject in front of the screen.
Record the video with your Android device.
Transfer the video to your computer or use a video editing app on your Android device to edit the video.
Open the video in the video editing app and select the chroma key or green screen option.
Use the chroma key controls to adjust the sensitivity and remove the green screen from the video. You may need to experiment with the settings to get the best results.
Add a new background by selecting an image or video from your computer or using a built-in background in the video editing app.
Save the edited video with the new background.
Keep in mind that using a green screen can be challenging, as you need to ensure that the green screen is evenly lit and that there are no shadows or reflections on the screen. It may take some practice to get good results, but with patience and a little trial and error, you should be able to create professional-looking videos with a green screen and an Android device.
  • PaT
PaT
Moderator Mobile
Ja, dat mod
En als je in de play store 'chroma key video' intikt, krijg je videoleap editor als hit. Daar kan dat blijkbaar mee.
Daarmee zijn je vragen wel beantwoord en om die reden gaat dit topic dicht. Mocht je er niet uitkomen, dan kan je een nieuw topic aanmaken met daarin een duidelijke omschrijving van je probleem en vooral ook wat je zelf al geprobeerd heb.
