Heeft iemand een idee hoe ik com21 van Casema in FreeBSD aan de praat kan krijgen ?
Mijn config-files zien er zo uit:
/etc/ppp/ppp.conf:
default:
set redial 1 0
set reconnect 3 10
nat same_ports yes
nat use_sockets yes
pppoe:
set device PPPoE:ed0:
set log Warning Error Alert
set log Warning Error Alert Phase lcp # Debugging
set cd 5
set dial
set login
set timeout 0
set authname <login_name>@wanadoo
set authkey <password>
set mtu 1492
/etc/ppp/ppp.linkup:
pppoe:
# Update interface and set routing
iface clear # Clear all other addresses from the
interface
add! default HISADDR # Should not be required
# Logging
bg /bin/echo "Connected. Using MYADDR as external address. (MYADDR --
HISADDR)"
bg /usr/bin/logger "LABEL - Connected. Using MYADDR as external
address. (MYADDR -- HISADDR)"
MYADDR --mx
MYADDR
/etc/ppp/ppp.linkdown:
pppoe:
bg /sbin/route delete default # Delete default route
bg /sbin/route add default -interface ed1 # Set default to internal
NIC
Ik neem aan dat de verbinding gemaakt kan worden met ppp -ddial -alias pppoe, maar als ik dat doe is er toch geen inetrnet activiteit. Slechts de reactie "ping: sendto: No Route to host" als ik een server ping.
In de log file staat het volgende:
Aug 29 15:50:06 epauli ppp[197]: Warning: -alias is deprecated
Aug 29 15:50:06 epauli ppp[197]: Phase: Using interface: tun0
Aug 29 15:50:06 epauli ppp[197]: Phase: deflink: Created in closed state
/etc/ppp/ppp.conf:
default:
set redial 1 0
set reconnect 3 10
nat same_ports yes
nat use_sockets yes
pppoe:
set cd 5
set dial
set login
set timeout 0
set mtu 1492
pppoe:
interface
# Logging
HISADDR)"
MYADDR --mx
MYADDR
pppoe:
NIC
