Buderus/EMS/Nefit OpenTherm converter/Honeywell vraag
  • braisim
  • Registratie: December 2022
  • Laatst online: 28-12-2022
(dutch below)
Hello, I'm new to this forum but looking at some of the posts here I wanted to use some of your expertise ot help me with a problem. I have a Buderus G244 Logano boiler equipped with Buderus Logamatic MC10 with BC10 and RC35 control units. All the radiators in the house are fitted with Honeywell Evohome thermostat valves linked to the Evohome wireless Controller, then to Honeywell BDR91 wireless relay which sends on/off signal only to the boiler. This partly works, but the modulation of the evohome and RC35 are not compatbile and this means the heating is not as comfortable as it should be. There is EMS pin-out available on the MC10 and I intend to connect this to the NEFIT EMS-Open Therm adapter/converter (which I have read about on this forum) and then connect this to a Honeywell OpenTherm Bridge (replacing the BDR91) and which I can pair to the Evohome Controller. Connecting hte NEFIT EMS-OpenTherm converter to the MC10 EMS bus is simple enough, as is connecting the converter to the Honeywell OpenTherm bridge. My question is about what happens to the exisitng control units. Would I then need to disconnect the RC35? Would this unit still have any purpose? Is the RC35 control over the boiler automatically over-ridden when I connect up the new NEFIT converter to the EMS bus? If anyone could help me with this I'd be very grateful. Thanks in advance.
Hallo, ik ben nieuw op dit forum, maar toen ik naar enkele van de berichten hier keek, wilde ik wat van je expertise gebruiken om me met een probleem te helpen. Ik heb een Buderus G244 Logano-ketel uitgerust met Buderus Logamatic MC10 met BC10- en RC35-regeleenheden. Alle radiatoren in huis zijn uitgerust met Honeywell Evohome thermostaatkranen die zijn gekoppeld aan de Evohome draadloze controller en vervolgens aan het Honeywell BDR91 draadloze relais dat alleen een aan/uit-signaal naar de ketel stuurt. Dit werkt gedeeltelijk, maar de modulatie van de evohome en RC35 zijn niet compatibel en dit betekent dat de verwarming niet zo comfortabel is als zou moeten. Er is een EMS-pin-out beschikbaar op de MC10 en ik ben van plan deze aan te sluiten op de NEFIT EMS-Open Therm-adapter/converter (waarover ik op dit forum heb gelezen) en deze vervolgens aan te sluiten op een Honeywell OpenTherm Bridge (ter vervanging van de BDR91) en die ik kan koppelen aan de Evohome Controller. Het aansluiten van de NEFIT EMS-OpenTherm-converter op de MC10 EMS-bus is eenvoudig genoeg, net als het aansluiten van de converter op de Honeywell OpenTherm-bridge. Mijn vraag gaat over wat er gebeurt met de bestaande regeleenheden. Moet ik dan de RC35 loskoppelen? Zou deze eenheid nog een doel hebben? Wordt de RC35-aansturing van de ketel automatisch opgeheven als ik de nieuwe NEFIT-converter aansluit op de EMS-bus? Als iemand mij hiermee zou kunnen helpen zou ik zeer dankbaar zijn. Bij voorbaat bedankt.
