[CS] - [KoF] Lightning - CS.dem naar CS.avi?
  • 115 views sinds 30-01-2008
Ik wil al een tijdje een .avi of .mpg of whatever maken van een cs demo. Tot zover ik weet kun je alleen opnemen in CS met behulp van demo's. Ik heb wel eens een .avi gezien van een counterstrike match.
Hoe maak je deze dingen? Een tijdje geleden stond er wel een topic over UT recorded demo, waarvan je een .avi kon maken, met behulp van het programma Camtasia, zie de quote hieronder.
Op woensdag 22 augustus 2001 16:21 schreef notgib het volgende:
Okay, prepare....
1) Go to: http://www.techsmith.com/products/camtasia/camtasia.asp and
download Camtasia. This is a screen capture program that wil record
everything in a window to an AVI. Install it and read the brief pop up help
window for how to operate it (it's pretty easy).
2) In the "capture" menu, set the capture type to "window".
3) Go into the Options\Preferences\AVI screen and uncheck "Auto Configure"
and set the frames/sec to 15 (or so). Go into the Video Setup and select
your favorite video codec to encode with. I recommend the "Microsoft MPEG-4
Video Codec V2".
4) Start UT and hit ALT+ENTER to shrink it to a window.
5) Go into the video options for UT and set the resolution to 320X240.
6) Hit the record button in Camtasia once and it will alow you to select
which window to record. Click on the UT window.
7) Hit the '~' key to bring up the UT console and type "demoplay <name of
demo file>". Hit the '~' key again to close the console.
8) Hit ATL+TAB to switch the focus to any window other than the UT window.
This is important because, even though you can't see it now, the windows
pointer is in the middle of the UT window. If you skip this step, the
pointer will show up in the final AVI file.
9) Hit the record button in Camtasia again to begin recording.
10) When the demo is finished, hit the stop button in Camtasia. It will
prompt you for a name and location to save the AVI and then automatically
play it back for you.
If you want to further edit the AVI, Camtasia has a very basic editor also.
If you really want to do some editing (like croping, time compression,
etc.), use VirtualDub. You can pick that up at
http://www.geocities.com/virtualdub/ .
Nu zou je hem al in flash kunnen importeren. Je kunt hem ook openen in quicktime en wegschrijven als een serie images en dan importeren in flash. Je krijgt dat allemaal aparte frames die je b.v. om zou kunnen zetten naar curves (trace image). succeS! ;)
Je moet hier dus het venster voor verkleinen. Maar als ik een .dem file met geekplay afspeel, dan speelt hij het in volledig scherm af. Wat moet ik doen om een .avi te maken van een cs match? Plz help me..
Greetz,
[KoF] Lightning
Ik weet het alleen voor Q3A.
Maar volgens mij werkt dat hetzelfde.
Zet je options op 640X480.
En dan tik je in je console:
/cl_avidemo X
De X is het aantal frames per seconde. Ik zou 30 doen. Dat ziet er goed uit.
Nu speel je de demo af. door dit te tikken:
/demo (demonaam)
Nu speelt hij hem dus af en maakt screenshots.
Dat zijn allemaal TGA bestanden.
Die kan je met behulp van het proggie.
BMP2AVI naar een AVI maken.
Probeer dit eerst maar even.
Als het lukt zal ik het proggie ff online zetten want snel vinden doe je het niet.
  • Vos
  • Laatst online: 16:25
Vos
AFCA
voor cs worden die avi's d8 ik 20 MB per 5 sec (in die buurt)......dus worden errug grote avi's.....je kan ze maybe omzette naar divx.....dan is het maybe nog te doen
#36
Op dinsdag 28 augustus 2001 21:26 schreef Vos het volgende:
Daarom moet je hem ook in 640*480 maken
Dan word het een stukkie kleiner
En dit is trouwens in elk spel hoor dus niet alleen in CS
