  • Aïken Bruijn
  • Registratie: Februari 2019
  • Laatst online: 29-09-2022
Hi,
I recently started at uni and I quickly realized that I have to read quite a lot, so thought i'd simply get a EReader! except that there is so much choice... I would like an EReader that I could use for all the reports and stuff I need to read as well as other books and mangas in my free time. I'd also like to use it as a notepad so that I dont have to waste so much paper on writing excersises for my Kanji (which is a bit the main point). I know what I want but the sad thing isd that I don't know what it's called and where to get it for a reasonable price... so I was thinking about getting the 'Kobo Libra 2'.
My question to you guys is: does this EReader fit the description I just gave? or do you have better suggestions?
Thanks in advance! :)
[ Voor 19% gewijzigd door rens-br op 30-09-2022 08:56 ]
  • rens-br
rens-br
Admin IN & Moderator Mobile
@Aïken Bruijn sorry for (all) the notificatons. We had a discussion about the fact that your post is in English. As per our terms and conditions this is allowed, as long as people can also react in dutch.
That being said. I have the Kobo Libra 2 and I won't use it for taking notes. The devices is not responsive enought for that, also the export possibilities are limited.
Normally when you are talking about taking notes with epaper ReMarkable is what you are looking for.
[ Voor 34% gewijzigd door rens-br op 30-09-2022 10:28 ]
  • Ayazis
  • Laatst online: 18:48
I believe ReMarkable is designed for exactly this purpose.
There are also E-readers that run on Android, which will give you a lot more usability. But I am unaware about note-taking capabilities on them. But they might be worth a look.
[ Voor 90% gewijzigd door Ayazis op 30-09-2022 09:09 ]
  • vanaalten
  • Laatst online: 13:54
Aïken Bruijn schreef op donderdag 29 september 2022 @ 23:41:I would like an EReader that I could use for all the reports and stuff I need to read as well as other books and mangas in my free time.
Might be good to be aware that most e-readers have a black/grey/white display, so if you want to read mangas and color is important...
If you also want to use it as a notepad, then the Kobo Libra 2 is not suitable (but, Kobo Elipsa Pack may be...)
This PriceWatch overview provides some options:
categorie: E-readers
And, as said, the Remarkable 2 tablet can also be considered - I think that one is a bit popular on universities.
[ Voor 40% gewijzigd door vanaalten op 30-09-2022 11:13 ]
  • swhnld
  • Laatst online: 14:22
swhnld
Ja, Kindle Scribe is net gelanceerd. Hier staat het artikel wat Tweakers gisteren er over schreef:
nieuws: Amazon presenteert eerste Kindle-tablet met pen om op te schrijven
Remarkable is al een langer bestaande oplossing, echter zit een deel van de functies daar achter een maandelijks abonnement.
Een andere optie is om een tablet aan te schaffen met een oled scherm erin. Zet daar dan e-book apps op, en verander de kleur naar zwart met witte letters. Daarmee beperk je de backlight effecten die het lezen erg vermoeiend maken, doordat zwarte pixels uit staan en alleen de witte pixels licht geven. En je behoud de optie om bijvoorbeeld Manga in kleur te lezen, al dan niet via je favoriete aanbieder die mogelijk niet compatible is met een specifiek merk e-Reader.
