Palomino's op thunder k7 mobo
Wie heeft er misschien al geprobeerd om 2 athlon's 1,5 ghz op een thunder k7 te zetten?
Volgens het interview hier: http://www.aceshardware.com/Spades/read.php?article_id=25000213
Zou dit moeten kunnen, het kan ook met thunderbirds, maar daar kunnen ze niets garanderen, en dit wordt dit ook afgeraden.
Hier is het stukje waar ik het over heb:
As you can see in AMD's roadmap, AMD will introduce a SMP capable Palomino in second quarter for the workstation and server market. This Palomino has, of course, the same core as the desktop Palomino, which will be introduced in the third quarter. The only difference between Palomino desktop and Palomino Server seems to be that the server version has some typical "server" features (extra monitoring on die?). Both versions have 384 KB of cache (L1 + L2).
There is good and bad news for those who dream of a powerful dual CPU workstation. The bad news is that AMD does not support dual Thunderbird systems. Running two Thunderbirds on a motherboard based on the AMD-760MP might work, but AMD advises against it.
