Wargames (1998 RTS) crashes
  • 5pë©ïàál_Tèkén
  • Laatst online: 13:16
Voor de oudjes onder ons - ik heb hulp nodig bij het spel Wargames uit 1998.
Afbeeldingslocatie: https://tweakers.net/i/MRrXhTnGiHbQcbxSAmGUlmv4VDI=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/jvuJFVD74I1IzJYiGnqY7g7A.jpg?f=user_large
Wanneer ik een hacker/agent in een commancenter stop om te hacken crasht het spel. In de event viewer staan dan twee meldingen;
De 1e melding;
Faulting application name: WarGames.exe, version: 1.0.0.1, time stamp: 0x3642cf17
Faulting module name: WarGames.exe, version: 1.0.0.1, time stamp: 0x3642cf17
Exception code: 0xc0000096
Fault offset: 0x001200b9
Faulting process ID: 0x1580
Faulting application start time: 0x01d8ad9dbfa7a29b
Faulting application path: D:\WarGames.exe
Faulting module path: D:\WarGames.exe
Report ID: bd2be74b-d7d4-403e-a8be-b785bf19cc12
Faulting package full name:
Faulting package-relative application ID:
29
30
31
32
33
34
35
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>100</Task>
  <Opcode>0</Opcode>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2022-08-11T16:17:19.2347854Z" />
  <EventRecordID>80264</EventRecordID>
  <Correlation />
  <Execution ProcessID="0" ThreadID="0" />
  <Channel>Application</Channel>
  <Computer>Desktop</Computer>
  <Security />
  </System>
- <EventData>
  <Data>WarGames.exe</Data>
  <Data>1.0.0.1</Data>
  <Data>3642cf17</Data>
  <Data>c0000096</Data>
  <Data>001200b9</Data>
  <Data>1580</Data>
  <Data>01d8ad9dbfa7a29b</Data>
  <Data>D:\WarGames.exe</Data>
  <Data>bd2be74b-d7d4-403e-a8be-b785bf19cc12</Data>
  <Data />
  <Data />
  </EventData>
  </Event>
De 2e melding;
Windows cannot access the file for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program wargames because of this error.
Program: wargames
File:
The error value is listed in the Additional Data section.
User Action
1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
2. If the file still cannot be accessed and
- It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted.
- It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer.
3. Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER.
4. If the problem persists, restore the file from a backup copy.
5. Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance.
Additional Data
Error value: 00000000
Disk type: 0
- <System>
  <EventID Qualifiers="49152">1005</EventID>
  <Level>2</Level>
  <Task>100</Task>
  <Opcode>0</Opcode>
  <TimeCreated SystemTime="2022-08-11T16:17:19.2357862Z" />
  <EventRecordID>80265</EventRecordID>
  <Correlation />
  <Security />
  </System>
- <EventData>
  <Data />
  <Data>wargames</Data>
  <Data>00000000</Data>
  <Data>0</Data>
  </EventData>
  </Event>
EDIT: hier nog een crash log;
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
14716 18:34:41.081 Starting DxWrapper v1.0.6334.21
14716 18:34:41.081 Gigabyte Technology Co., Ltd. X570 AORUS XTREME -CF (Desktop)
14716 18:34:41.081 Gigabyte Technology Co., Ltd. X570 AORUS XTREME Default string (Desktop)
14716 18:34:41.081 NVIDIA GeForce RTX 3090
14716 18:34:41.081 Windows 10 64-bit (10.0.19041)
14716 18:34:41.081 "WarGames.exe" (PID:16380)
14716 18:34:41.085 Utils::WriteMemory::WriteMemory Failed verification for memory write!
14716 18:34:41.085 Disabling High DPI Scaling...
14716 18:34:41.085 Loaded library: user32.dll
14716 18:34:41.085 Loaded library: shcore.dll
14716 18:34:41.085 Loading 'ddraw.dll'...
14716 18:34:41.085 Hooking ddraw.dll APIs...
14716 18:34:41.086 Enabling ddraw wrapper
14716 18:34:41.086 Enabling d3d9 wrapper
14716 18:34:41.086 Loading 'd3d9.dll'...
14716 18:34:41.088 DxWrapper loaded!
14716 18:34:41.128 dd_DirectDrawEnumerateA
14716 18:34:41.128 Redirecting 'Direct3DCreate9' ...
14716 18:34:41.152 Creating device m_IDirect3D9Ex::m_IDirect3D9Ex(057B3488)
14716 18:34:41.152 dd_DirectDrawCreate
14716 18:34:41.152 dd_DirectDrawCreateEx
14716 18:34:41.152 Redirecting 'DirectDrawCreate' IID_IDirectDraw to --> 'Direct3DCreate9'
14716 18:34:41.152 Creating device m_IDirectDrawX::m_IDirectDrawX(059F4A40) converting device from v1 to v9
14716 18:34:41.152 Redirecting 'Direct3DCreate9' ...
14716 18:34:41.154 Creating device m_IDirect3D9Ex::m_IDirect3D9Ex(057B3208)
14716 18:34:41.214 Creating device m_IDirect3DDevice9Ex::InitDirect3DDevice(09DFB5D0)
14716 18:34:41.222 m_IDirectDrawX::~m_IDirectDrawX(059F4A40) deleting device!
14716 18:34:41.226 m_IDirect3DDevice9Ex::~m_IDirect3DDevice9Ex(09DFB5D0) deleting device!
14716 18:34:41.226 m_IDirect3D9Ex::~m_IDirect3D9Ex(057B3208) deleting device!
14716 18:34:41.226 m_IDirectDrawSurfaceX::CleanupSharedEmulatedMemory Deleting 0 emulated surfaces!
14716 18:34:41.227 Redirecting 'DirectDrawCreate' IID_IDirectDraw to --> 'Direct3DCreate9'
14716 18:34:41.227 Creating device m_IDirectDrawX::m_IDirectDrawX(09CEECA0) converting device from v1 to v9
14716 18:34:41.227 Redirecting 'Direct3DCreate9' ...
14716 18:34:41.228 Creating device m_IDirect3D9Ex::m_IDirect3D9Ex(09D541E8)
14716 18:34:41.271 Creating device m_IDirect3DDevice9Ex::InitDirect3DDevice(09FD0170)
14716 18:34:41.279 m_IDirectDrawX::~m_IDirectDrawX(09CEECA0) deleting device!
14716 18:34:41.283 m_IDirect3DDevice9Ex::~m_IDirect3DDevice9Ex(09FD0170) deleting device!
14716 18:34:41.283 m_IDirect3D9Ex::~m_IDirect3D9Ex(09D541E8) deleting device!
14716 18:34:41.283 m_IDirectDrawSurfaceX::CleanupSharedEmulatedMemory Deleting 0 emulated surfaces!
14716 18:34:41.284 m_IDirect3D9Ex::~m_IDirect3D9Ex(057B3488) deleting device!
14716 18:34:43.128 Redirecting 'DirectDrawCreate' IID_IDirectDraw to --> 'Direct3DCreate9'
14716 18:34:43.128 Creating device m_IDirectDrawX::m_IDirectDrawX(09FF8A40) converting device from v1 to v9
14716 18:34:43.185 Creating device m_IDirect3DDevice9Ex::InitDirect3DDevice(0A255818)
14716 18:34:43.642 m_IDirect3DDevice9Ex::~m_IDirect3DDevice9Ex(0A255818) deleting device!
14716 18:34:43.965 Creating device m_IDirectDrawClipper::m_IDirectDrawClipper(0A25E5A0)
14716 18:34:43.965 Creating device m_IDirectDrawSurfaceX::m_IDirectDrawSurfaceX(09C4DDF8) converting device from v1 to v9
14716 18:34:43.965 Creating device m_IDirectDrawSurfaceX::m_IDirectDrawSurfaceX(09B830C0) converting device from v1 to v9
14716 18:34:43.965 Creating device m_IDirectDrawPalette::m_IDirectDrawPalette(0A49E398)
14716 18:34:43.965 Creating device m_IDirect3DTexture9::m_IDirect3DTexture9(09BF8378)
14716 18:34:43.965 Creating device m_IDirect3DTexture9::m_IDirect3DTexture9(09BF87D8)
14716 18:34:43.966 Creating device m_IDirect3DVertexBuffer9::m_IDirect3DVertexBuffer9(09BF83B0)
14716 18:34:43.970 Creating device m_IDirect3DTexture9::m_IDirect3DTexture9(09BF8650)
14716 18:34:44.253 Creating device m_IDirectDrawSurfaceX::m_IDirectDrawSurfaceX(09DA74F8) converting device from v1 to v9
14716 18:34:44.269 m_IDirectDrawSurfaceX::~m_IDirectDrawSurfaceX(09DA74F8) deleting device!
14716 18:34:47.718 m_IDirectDrawSurfaceX::~m_IDirectDrawSurfaceX(09ED2448) deleting device!
14716 18:34:48.288 m_IDirectDrawSurfaceX::~m_IDirectDrawSurfaceX(05B063B0) deleting device!
14716 18:34:58.157 Quiting DxWrapper
14716 18:34:58.157 Unloading libraries...
14716 18:34:58.157 Reseting screen resolution
14716 18:34:58.290 DxWrapper terminated!
Ik gebruik deze grafische patch omdat het spel anders niet speelt (kan wel in het hoofdmenu komen maar niet 'in game').
Ik heb admin rechten geprobeerd, opnieuw installeren, het spel in een Windows XP VM gedraaid maar op precies het zelfde moment crasht het spel.
Iemand die misschien weet hoe ik dit kan oplossen? Het is voor mij een 'gouwe ouwe' en zou 'm graag nog een keer spelen. Thx for reading!
[ Voor 32% gewijzigd door 5pë©ïàál_Tèkén op 11-08-2022 18:36 ]
Team anti-scalp - wauw..
