Na een Elementary OS herinstallatie, voer ik volgende uit.
Staan hier dingen in die misschien niet nodig zijn of beter gedaan kunnen worden?
Ik ben nogal nieuw in Linux.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
sudo ufw enable
sudo dpkg --add-architecture i386
sudo ubuntu-drivers devices
sudo ubuntu-drivers autoinstall
sudo add-apt-repository ppa:philip.scott/pantheon-tweaks
sudo apt update
sudo apt install ubuntu-restricted-extras libavcodec-extra
sudo apt install libglib2.0-dev libgranite-dev libindicator3-dev
sudo apt install libwingpanel-dev indicator-application
sudo apt install neofetch
sudo apt install ncdu
sudo apt install gnome-usage
sudo apt install laptop-mode-tools
sudo apt install libc6-i386
sudo apt install timeshift
sudo apt install stacer
sudo apt install wine
sudo apt install menulibre
sudo apt install virtualbox-ext-pack
sudo apt install gnome-disk-utility
sudo apt install gdebi
sudo apt install ttf-mscorefonts-installer
sudo apt install software-properties-common
sudo apt install pantheon-tweaks
sudo apt install --reinstall linux-headers-$(uname -r) virtualbox-dkms dkms
sudo modprobe vboxdrv
sudo apt update
sudo apt upgrade
sudo apt autoremove
flatpak remote-add --user --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
flatpak install org.freedesktop.Platform
flatpak install org.freedesktop.Platform.openh264
flatpak install --user flathub org.remmina.Remmina
flatpak run --user org.remmina.Remmina
sudo flatpak upgrade
sudo flatpak --user upgrade
#download and install google
#download https://github.com/Lafydev/wingpanel-indicator-ayatana/blob/master/com.github.lafydev.wingpanel-indicator-ayatana_2.0.8_odin.deb
sudo dpkg -i ./com.github.lafydev.wingpanel*.deb
mkdir -p ~/.config/autostart
cp /etc/xdg/autostart/indicator-application.desktop ~/.config/autostart/
sed -i 's/^OnlyShowIn.*/OnlyShowIn=Unity;GNOME;Pantheon;/' ~/.config/autostart/indicator-application.desktop
sudo nano /etc/xdg/autostart/indicator-application.desktop
#Change OnlyShowIn value to:
  • pporrio
  • Laatst online: 12:51
Eerste stappen die ik ongeacht welke distro eerst doe na installatie:
  1. Updaten:
    sudo apt update && sudo apt upgrade
  2. GPU Proprietary Driver installeren in het geval van Nvidia GPU:
    Via de grafische interface van ElementaryOS via Software & Updates > Additional Drivers
  3. Gewenste pakketten installeren:
    Algemene tip: Al die 'sudo apt install pakketnaam' regels kun je ook in 1 regel uitvoeren, bijvoorbeeld:
    sudo apt install pakketnaam1 pakketnaam2 pakketnaam3
  4. Firewall aanzetten (ervan uitgaande dat je ufw hebt geïnstalleerd in stap 3):
    sudo ufw enable
Daarna finetunen, opleuken, etc.
[ Voor 18% gewijzigd door pporrio op 14-07-2022 00:13 ]
Mijn platencollectie
  • pporrio
Wat vooral van belang is met linux is dat je niet domweg commando's die je op internet tegenkomt in je terminalvenster plakt, zonder dat je weet wat deze doen. In het begin is dit lastig en zal je bij sommige regels wellicht ongeveer begrijpen wat ze doen. ;)
Onderstaande code installeert pakket 'pakketnaam1':
Merk op dat 'sudo' voor dit commando staat. Als je wilt weten waarom, voer het commando dan maar eens uit zonder sudo in een nieuw terminalvenster en kijk welke melding je krijgt (alweer een stapje verder qua kennis):
De regels om een extra repo(sitory) toe te voegen, doe je omdat in de standaardrepo's die bij je linux distro geleverd worden, de pakketten niet aanwezig zijn die je wilt installeren die wel in de extra repo aanwezig zijn. Let wel goed op welke niet-officiële repo's je toevoegt, er zit ook een hoop zooi bij. Even het voorbeeld uit jouw post:
Met de regel hierboven voeg je dus een extra repo (ppa:philip.scott/pantheon-tweaks) toe waarin (waarschijnlijk) een of meer pakketten staan die je (waarschijnlijk) nodig hebt. Nadat je de repo hebt toegevoegd, moet je de pakketlijsten weer updaten, zodat de pakketten in de net toegevoegde repo beschikbaar komen om te installeren. Dit updaten doe je dus met:
sudo apt update
Daarna kun je het pakket uit de extra repo installeren op de bekende manier:
Op deze manier moet je dus eigenlijk al je regels uit je eerste post analyseren. 'Wat doet de regel en heb ik dit nodig op mijn systeem en waarom?' is iets dat je dan per regel moet bepalen voor jezelf.
Je kunt veel informatie vinden via google, maar probeer zoveel mogelijk te kijken op pagina's van de distro zelf.
[ Voor 7% gewijzigd door pporrio op 13-07-2022 18:49 ]
  • CR2032
  • Registratie: Juli 2016
Wat ik altijd doe is even zoeken op internet met 'what to do after installing <distro naam.'
Deze site is dan ook altijd handig. Maar kijk vooral wat je zelf nodig hebt en waarom. Zo heb ik liever ttf-liberation dan die microsoft core fonts. Heet nu fonts-liberation en fonts-dejavu.
https://itsfoss.com/thing...-installing-ubuntu-22-04/
