A7V133 data-corruptie oplossing
  • 84 views sinds 30-01-2008
  • Ronnie_T
  • Laatst online: 07-08 12:59
Ronnie_T
Shangri-La
Well, I thought it was the "plextor 24x" that was very "picky" with which media I used, but I found out is was the VIA Corruption-bug AGAIN
I burned 15 disks in total, using 4 different types of media, and 5 of them had data-corruption on them.
I can only conclude that the 686b-southbridge -corruption bug has come to life because i use FAST IDE-devices on the VIA-IDE ports. The corruption didn't occur on my old 4x speed burner.
Ever since I own the a7v133 (rev. 1.05) I was struggling with corruption. I used both bios (1005a and 1006), tried tons of other things, like via 4-in-1 but the corruption didn't go away. It went away for a month or so when I disabled my USB-devices.
In the end I went back to the computerstore and bought a PENTIUM III 933 + new (TUSL-2) mainboard instead of my a7v AMD.
P.S. I like to search the internet for solution, but not when problems couldn't be solved and took ALL of my spare time. I just hope to enjoy my computer now and do other stuff, like gaming..etc...
Good luck to all those that suffers from corruption on the a7v(133).
Ronnie_t
Intel Forever. Specs. DKJJPQKU
  • BrZ
  • Laatst online: 30-07 09:36
BrZ
[topic=193190] :z
Probeer je nu nog een keer aandacht te trekken, maar dan in het engels? :P
  • Ronnie_T
Ronnie_T
Shangri-La
Op donderdag 23 augustus 2001 19:41 schreef BrZ het volgende:
[topic=193190] :z
Gaan we hier een FLAMEwar van maken?
Dat is in ieder geval nIET mijn bedoeling, mister...know it al??
  • lange
  • Laatst online: 26-08 10:38
lange
Boom Boom?
heb me brander gewoon in een andere pc zitten, das de oplossing ;)
  • lange
lange
Boom Boom?
Op donderdag 23 augustus 2001 19:47 schreef Ronnie_T het volgende:
last van de caps lock toets????
maarre waarom deed je het in engels?
  • Ronnie_T
Ronnie_T
Shangri-La
Op donderdag 23 augustus 2001 19:48 schreef lange het volgende:
does it matter? |:(
  • BrZ
BrZ
Op donderdag 23 augustus 2001 20:00 schreef Ronnie_T het volgende:
does it matter? |:(
Het maakt mij eerlijk gezegd wel uit...
Ik vind het redelijk loos dat je eerst tig topics over dit onderwerp opent in het Nederlands, en daarna in het Engels komt vertellen dat je een P3 hebt gekocht? :?
  • HermeS
  • Laatst online: 26-08 11:58
als je nou eens eerst een goed leest voordat je WEL probeert teflamen (iemand aanmerken dat ie wilt flamen, noem ik flamen >:) ), of weet je niet wat smile'ies zijn :?
en +1 opmerkzaak voor BrZ >:)
  • lange
lange
Boom Boom?
does it matter? |:(
jah, een beetje onnodig interesant gaan lopen doen vind ik het.
dit onderwerp is al zat aan bod gekomen en nuttig wordt dit ook niet echt meer
