[RHL71] PROFTPD
  • 118 views sinds 30-01-2008
  • DPLuS
Waarom werkt deze conf-file niet?
Als ik inlog als anonymous, en een emailadres opgeef zegt 'ie: Login incorrect...
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
# This sample configuration file illustrates configuring two
# anonymous directories, and a guest (same thing as anonymous but
# requires a valid password to login)
ServerName          "MyServer"
ServerType          standalone
# Port 21 is the standard FTP port.
Port                21
# If you don't want normal users logging in at all, uncomment this
# next section
#<Limit LOGIN>
#  DenyAll
#</Limit>
# Set the user and group that the server normally runs at.
User                nobody
Group               nobody
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances              30
# Set the maximum number of seconds a data connection is allowed
# to "stall" before being aborted.
TimeoutStalled          300
# We want 'welcome.msg' displayed at login, and '.message' displayed
# in each newly chdired directory.
DisplayLogin            welcome.msg
DisplayFirstChdir       .message
# Our "basic" anonymous configuration, including a single
# upload directory ("uploads")
<Anonymous ~ftp>
  # Allow logins if they are disabled above.
  <Limit LOGIN>
    AllowAll
  </Limit>
  # Maximum clients with message
  MaxClients            5 "Sorry, max %m users -- try again later"
  User              ftp
  Group             ftp
  # We want clients to be able to login with "anonymous" as well as "ftp"
  UserAlias         anonymous ftp
  # An upload directory that allows storing files but not retrieving
  # or creating directories.
  <Directory /tmp/upload/*>
    <Limit READ>
    DenyAll
    </Limit>
    <Limit STOR>
    AllowAll
    </Limit>
  </Directory>
</Anonymous>
  • luc
luc
/etc/ftpusers
RTFM ?
  • B2
  • Laatst online: 10-09 09:54
B2
wa' seggie?
Op donderdag 23 augustus 2001 17:13 schreef luc het volgende:
/etc/ftpusers
RTFM ?
Slaat nergens op zo'n antwoord, ook jij hebt eens moeten beginnen.
Geef gewoon normale hulp, in plaats van direct beginnen te schelden |:(
Als er alleen RTFM stond was het misschien wat grof :)
Maar kijk in /etc/ftpusers en haal daar ftp weg :)
daar staat oa dit: # To enable anonymous FTP, remove the "ftp" user:
dussuh :)
  • Jordi
Jordi
#1#1
Je kunt nu wel boos worden, maar dit is _echt_ RTFM werk. Bovendien geeft hij nog antwoord ook.
Het zal wel niet, maar het zou maar wel.
  • B2
B2
wa' seggie?
Op donderdag 23 augustus 2001 19:03 schreef Jotti het volgende:
Kan wel, maar als _newbie_ wil je graag uitleg, en een oplossing, om direct te beginnen met rtfm vind ik een beetje vergaan.
zeg dan het staat in de manpages ofzo
  • Jordi
Jordi
#1#1
hij begint er toch ook niet mee :?
  • igmar
  • Laatst online: 09-09 19:53
igmar
ISO20022
Maar effe die config weggegooid..
UNIX machines loggen alles, in tegenstelling tot alles wat Windows is, dat logt namelijk niks of hetgeen wat totaal niet interessant is.
/var/log/messages is een handige eerste optie, en in denk dat je vergeten bent de user ftp uit /etc/ftpusers te gooien. Zover ik weet geeft ie dat ook netjes aan in de logfiles.
  • luc
luc
Op donderdag 23 augustus 2001 21:08 schreef postduif het volgende:
Als newbie moet je hier niet alles komen vragen, als newbie moet je gewoon de manual lezen!
Ik kom hier toch ook niet de meest simpele dingen vragen ? En ik weet ook niet veel van linux hoor.. maar wat ik niet weet zoek ik wel ff op.
Als newbie hoor je ook te weten dat je het gezellig moet houden hier.
RTFM roepen is best maar *niet* op deze manier, doe het dan op de jotti-manier met een verwijzing naar welke manual hij moet lezen en een iets vriendelijkere noot s.v.p. op deze manier jaag je de newbies alleen maar weg en is dat wat je wilt bereiken?
spellen blijft moeilijk
  • Apache
  • Laatst online: 09-09 15:09
Apache
amateur software devver
Op zaterdag 25 augustus 2001 12:43 schreef beelzebubu het volgende:
RTFM roepen is best maar *niet* op deze manier, doe het dan op de jotti-manier met een verwijzing naar welke manual hij moet lezen en een iets vvriedenlijkere noot s.v.p. op deze manier jaag je de newbies alleen maar weg en is dat wat je wilt bereiken?
luc deed toch niets verkeerd?
en hij gaf eerst het antwoord en vroeg zich daarna af of dit geen rtfm vraag was ...
If it ain't broken it doesn't have enough features
Op zaterdag 25 augustus 2001 12:45 schreef Apache het volgende:
op een compleet nutteloze manier ja.... De gemiddelde newbie weet hjopelijk sowieso wat RTFM betekent maar schiet er niks mee op als hij niet weet wat een manual is, wat voor manual hij moet hebben etc.
Help ze een beetje op de goede weg - je hoeft ze niet alles voor te kauwen maar zo heeft de gemiddelde newbie er ook niks aan...
  • DPLuS
Nog mooier: Ik heb helemaal geen /etc/ftpusers bestandje...
Doet 'ie het daarom helemaal niet?
De directory die ik gedefinieerd heb in mijn config heb ik wel al aangemaakt...
